best replacement carb for a thermo quad #739234
07/03/10 08:08 AM
07/03/10 08:08 AM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
got one on my motorhome/tow barge that need's a serious pitch in the junk pile and was curious what some of you guy's reccomend, I was thinking about a Holley spreadbore or even a Edelbrock performer,,, the holley I can work on, the Edelbrock works real good if tuned in correctly ,,,so I was told,,,,so let's hear it.
Re: best replacement carb for a thermo quad [Re: dartman366] #739235
07/03/10 08:17 AM
07/03/10 08:17 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
a vac holley 600 comes to mind.mite be cost effective also.
Re: best replacement carb for a thermo quad [Re: dartman366] #739236
07/03/10 09:15 AM
07/03/10 09:15 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Holley spreadbore would be my choice.The other thing I would consider is having the TQ you have now rebuilt or have one done up by DemonSizzler.
Nautilus Racing-
Re: best replacement carb for a thermo quad [Re: blownzoom440] #739237
07/03/10 11:09 AM
07/03/10 11:09 AM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
wouldn't a 600 choke a 440 too much?,, Jeg's has a 650 spread bore, vac secondary,,I even thought about a 750 vac secondary.
Re: best replacement carb for a thermo quad [Re: dartman366] #739238
07/03/10 11:11 AM
07/03/10 11:11 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I don't think it would at all.Remember the TQ you have now is rated at 800 or more cfm.I think the 650 spreadbore would do just fine.
Nautilus Racing-
Re: best replacement carb for a thermo quad [Re: Chris2581] #739239
07/03/10 11:15 AM
07/03/10 11:15 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
A well built and tuned thermo quad would be the best choice for replacement in my opinion.
Getting old just means you were smarter than some and luckier than others.
Re: best replacement carb for a thermo quad [Re: dannysbee] #739240
07/03/10 11:19 AM
07/03/10 11:19 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ve built several of those for race cars,trucks and motorhomes and all worked well when tuned properly. There`s a trick to makin em work and not bog and it starts with the metering rods and ends w/the air door adjustement......and of course a few tricks in between.
Re: best replacement carb for a thermo quad [Re: Thumperdart] #739241
07/03/10 11:23 AM
07/03/10 11:23 AM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
put a Q-Jet on it and forget about it
Andrew Brough D372 1969 Dodge Dart GTS 1.43 60'best 6.82 1/8 98mph "the light came on and I ran out of talent"
Re: best replacement carb for a thermo quad [Re: StripeHOG] #739242
07/03/10 11:42 AM
07/03/10 11:42 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Nothing wrong with a Q-Jet, or a Holley but why settle for second or third best?
Re: best replacement carb for a thermo quad [Re: dartman366] #739243
07/03/10 12:04 PM
07/03/10 12:04 PM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
PITCH IT ....right over here ...I beez the Prez of the ThermoSquad !
Re: best replacement carb for a thermo quad [Re: dOOc] #739244
07/03/10 12:13 PM
07/03/10 12:13 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Hey Bill
I have a spread bore 600/650 Double pumper Holley I have $75 in...you can have it for that...
its pretty clean, but I havent run it and it needs a kit.
The carb is a single line side hung bowl 600- or 650 Double pumper...
Havent seen many like this..
Came off a late 60's big block Pontiac..
Re: best replacement carb for a thermo quad [Re: Bob_Coomer] #739245
07/03/10 02:08 PM
07/03/10 02:08 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The T-quad that is sposed tobe on there is an 850. If you put an 850 holley on there it will not run near as good. Just fix the t-quad, it will run better and get much better mpg. Remember under hood temp on a 440 running peadl to the metal in a MH is pretty high so the plastic carb will work wonders.
Re: best replacement carb for a thermo quad [Re: Thumperdart] #739246
07/03/10 05:09 PM
07/03/10 05:09 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
That's the problem,,,I know nothing about a TQ, or the trick's to make them work right.
Re: best replacement carb for a thermo quad [Re: dartman366] #739247
07/03/10 06:11 PM
07/03/10 06:11 PM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
What are the probs you are having ?
Re: best replacement carb for a thermo quad [Re: dOOc] #739248
07/03/10 06:16 PM
07/03/10 06:16 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
They are pretty straight forward. Floats and vaccum diaphrams were always a problem. Sold a few main bodies, too, so I'm not so sold on the MH cooking that deal. Probably ok. If it's a good core, try rebuilding it first.
Re: best replacement carb for a thermo quad [Re: dartman366] #739249
07/03/10 08:00 PM
07/03/10 08:00 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
See if a local shop can re-build it for you and if not, send it to me and I do it for ya. One major trick is to epoxy the jet wells in the plastic body as they leak and reak havock on the driving/tuning issues those carbs have.
Re: best replacement carb for a thermo quad [Re: dOOc] #739250
07/03/10 08:48 PM
07/03/10 08:48 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
If it sit's more than a week you have to prime the carb with gas to start it, no amount of pumping the accelerator give's it enough gas to start,, act's like the bowl's are completely dry,,,won't go into 4 barrel mode when pedal is slammed to the floor, run's on 2 barrel only,,,idle adjustment screw's have no effect on idle quality,,,and it is just a scuzzy, scurvey, nasty looking mess,,I just want to make sure all is good and ready to go with the best economy that I can get from this barge.
Re: best replacement carb for a thermo quad [Re: dartman366] #739251
07/03/10 09:33 PM
07/03/10 09:33 PM
dulcich Offline
dulcich  Offline
A better carburetor than the Thermoquad has yet to be invented. It was truely the finest moment for cabureted fuel delivery.
-dulcich
Re: best replacement carb for a thermo quad [Re: dulcich] #739252
07/03/10 10:04 PM
07/03/10 10:04 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
-dulcich
Thank's Steve, now where is the best place to obtain info on how these thing's work and how to modify and tune them,,guess I need to start lern'in how.
Re: best replacement carb for a thermo quad [Re: dartman366] #739253
07/03/10 10:23 PM
07/03/10 10:23 PM
dulcich Offline
dulcich  Offline
Unfortunately, if that's your aim, you've got a hard row to hoe my friend.
-dulcich
