best replacement carb for a thermo quad
#739234
07/03/10 08:08 AM
07/03/10 08:08 AM
dartman366
Mt. Vernon, Ohio
got one on my motorhome/tow barge that need's a serious pitch in the junk pile and was curious what some of you guy's reccomend, I was thinking about a Holley spreadbore or even a Edelbrock performer,,, the holley I can work on, the Edelbrock works real good if tuned in correctly ,,,so I was told,,,,so let's hear it.
Re: best replacement carb for a thermo quad
[Re: dartman366]
#739236
07/03/10 09:15 AM
07/03/10 09:15 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Holley spreadbore would be my choice.The other thing I would consider is having the TQ you have now rebuilt or have one done up by DemonSizzler.
[Re: blownzoom440]
#739237
07/03/10 11:09 AM
07/03/10 11:09 AM
dartman366
Mt. Vernon, Ohio
wouldn't a 600 choke a 440 too much?,, Jeg's has a 650 spread bore, vac secondary,,I even thought about a 750 vac secondary.
[Re: dartman366]
#739238
07/03/10 11:11 AM
07/03/10 11:11 AM
Chris2581
Jacksonville, FL
I don't think it would at all.Remember the TQ you have now is rated at 800 or more cfm.I think the 650 spreadbore would do just fine.
[Re: Chris2581]
#739239
07/03/10 11:15 AM
07/03/10 11:15 AM
Posts: 5,160 Texas
dannysbee
Texas
A well built and tuned thermo quad would be the best choice for replacement in my opinion.
Getting old just means you were smarter than some and luckier than others.
[Re: dartman366]
#739243
07/03/10 12:04 PM
07/03/10 12:04 PM
Posts: 30,449 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
PITCH IT ....right over here ...I beez the Prez of the ThermoSquad !
[Re: dOoC]
#739244
07/03/10 12:13 PM
07/03/10 12:13 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Hey Bill I have a spread bore 600/650 Double pumper Holley I have $75 in...you can have it for that... its pretty clean, but I havent run it and it needs a kit. The carb is a single line side hung bowl 600- or 650 Double pumper... Havent seen many like this.. Came off a late 60's big block Pontiac..
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#739245
07/03/10 02:08 PM
07/03/10 02:08 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
The T-quad that is sposed tobe on there is an 850. If you put an 850 holley on there it will not run near as good. Just fix the t-quad, it will run better and get much better mpg. Remember under hood temp on a 440 running peadl to the metal in a MH is pretty high so the plastic carb will work wonders.
[Re: Thumperdart]
#739246
07/03/10 05:09 PM
07/03/10 05:09 PM
dartman366
Mt. Vernon, Ohio
I`ve built several of those for race cars,trucks and motorhomes and all worked well when tuned properly. There`s a trick to makin em work and not bog and it starts with the metering rods and ends w/the air door adjustement......and of course a few tricks in between.
That's the problem,,,I know nothing about a TQ, or the trick's to make them work right.
[Re: dartman366]
#739247
07/03/10 06:11 PM
07/03/10 06:11 PM
dOoC
Florida STAYcation
What are the probs you are having ?
[Re: dOoC]
#739250
07/03/10 08:48 PM
07/03/10 08:48 PM
dartman366
Mt. Vernon, Ohio
If it sit's more than a week you have to prime the carb with gas to start it, no amount of pumping the accelerator give's it enough gas to start,, act's like the bowl's are completely dry,,,won't go into 4 barrel mode when pedal is slammed to the floor, run's on 2 barrel only,,,idle adjustment screw's have no effect on idle quality,,,and it is just a scuzzy, scurvey, nasty looking mess,,I just want to make sure all is good and ready to go with the best economy that I can get from this barge.
[Re: dulcich]
#739252
07/03/10 10:04 PM
07/03/10 10:04 PM
dartman366
Mt. Vernon, Ohio
A better carburetor than the Thermoquad has yet to be invented. It was truely the finest moment for cabureted fuel delivery. -dulcich
Thank's Steve, now where is the best place to obtain info on how these thing's work and how to modify and tune them,,guess I need to start lern'in how.
