Left turn signal indicator light staying on #739007
07/02/10 08:49 PM
07/02/10 08:49 PM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
Guys,
When I turn the lights on in my '71 Charger, the left turn signal indicator on the instrument panel is on and steady.
The indicator will flash if I put the left turn signal or the flashers on. It goes off if I shut the lights off.
All the lights (headlights, high beams, side markers, tailights, brake lights, instrument panel lights, etc.) seem to be working fine. I also don't see any blown fuses.
I am assuming this is a warning light of some kind, but for what?
Thanks.
Greg
Re: Left turn signal indicator light staying on [Re: GregY] #739008
07/02/10 08:59 PM
07/02/10 08:59 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Tighten the phillips screws that hold left park-turn lamp into valance.
Re: Left turn signal indicator light staying on [Re: GregY] #739009
07/02/10 09:02 PM
07/02/10 09:02 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
It is almost certainly a ground problem at a left side turn signal/park lamp socket.
Although you think all the lights are "fine", if you inspect the left side 1157 bulbs closely, I predict that you will find that one of them is actually lighting BOTH filaments when only the park lights are on. This is the socket with the bad ground, and the park light filament is feeding back through the other filament (and your dash indicator) to get its ground.
Fix the ground at that socket.
Down to just a blue car now.
Re: Left turn signal indicator light staying on [Re: 68HemiB] #739010
07/03/10 12:22 AM
07/03/10 12:22 AM
Cen Fla
j3wbagell Offline
j3wbagell  Offline
Cen Fla
might be the indicator fuse should be 2 under the dash
Re: Left turn signal indicator light staying on [Re: j3wbagell] #739011
07/03/10 08:00 AM
07/03/10 08:00 AM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
Thanks guys, I will check these things.
Greg
Re: Left turn signal indicator light staying on [Re: GregY] #739012
07/03/10 10:33 AM
07/03/10 10:33 AM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Ground problem, probably at the front turn signal housing ground. Get right up to the lights and check with the lights on. You will see the light causing the problem will have the filament lightly glowing. Then remove bulb and clean socket and bulb. Recheck, if still a problem, check the socket to housing groung. Stake the rolled over lip if not making contact well. Then check the housing to body connection, clean and tighten as needed. Also, check the back lights for the same problem if not resolved.
Ron
