360 magnum head-Help
#73683
06/14/08 06:59 PM
06/14/08 06:59 PM
Posts: 148 Spring Grove, PA, US
Mr.Mopar
Hi, Does anybody know if the valves are a different size on the 360 magnum head compared to the 318 magnum head??? I know the regular syle heads are different and i know a lot about the old 318 and 360s but dont know about the 90's 318s and 360s. thanks Kevin
1996 cummins diesel ext cab, long bed 1966 Valiant 4dr(318- 3.55gears, 13.31@ 102mph), 1974 Duster(360- 13.63@ 99.96 w/3.23 gears), 1933 Dodge DP (201)
Re: 360 magnum head-Help
[Re: 540challenger]
#73685
06/14/08 07:12 PM
06/14/08 07:12 PM
Mr.Mopar
thanks, was wondering because i saw a 360 mag engine at a junkyard, but i have been forwarned to look for cracks in the head Kevin
[Re: RapidRobert]
#73687
06/14/08 10:23 PM
06/14/08 10:23 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
However the aftermarket heads like EQs, Pro-Topline and mppar aluminum mags have 1.625 seats. David
[Re: HotRodDave]
#73688
06/14/08 11:12 PM
06/14/08 11:12 PM
RapidRobert
yeah mine were brand new stockers & if I had to do it over again(& I probably will) I would have used .100" longer chebby valves(they're cheap enough).
[Re: RapidRobert]
#73689
06/16/08 07:57 AM
06/16/08 07:57 AM
Posts: 2,826 NY usa
540challenger
NY usa
very common problem from what people post. The ex is listed as 1.625" & I read that the seat is slightly smaller than that on them so I bought a single 1.6" chebby valve & my head man said perfect fit(reamed the guides to 11/32").
Are the crack visable all do you need to get them magnafluxed???
[Re: dogdays]
#73693
06/16/08 03:23 PM
06/16/08 03:23 PM
RapidRobert
& I was wondering also about having a head pressure checked which my machine shop is equipped to do.I would NOT like to sink a bunch of time/money into a set & find out later that's there's a problem. Might be overkill but peace of mind to me is priceless.
