360 magnum head-Help #73683
06/14/08 06:59 PM
06/14/08 06:59 PM
Spring Grove, PA, US
Mr.Mopar Offline OP
Mr.Mopar  Offline OP
Hi,
Does anybody know if the valves are a different size on the 360 magnum head compared to the 318 magnum head??? I know the regular syle heads are different and i know a lot about the old 318 and 360s but dont know about the 90's 318s and 360s. thanks
Kevin
1996 cummins diesel ext cab, long bed
1966 Valiant 4dr(318- 3.55gears, 13.31@ 102mph),
1974 Duster(360- 13.63@ 99.96 w/3.23 gears),
1933 Dodge DP (201)
Re: 360 magnum head-Help [Re: Mr.Mopar] #73684
06/14/08 07:01 PM
06/14/08 07:01 PM
NY usa
540challenger Offline
NY usa
318 and 360 magnum heads all the same including the valves. 1.94 intake i can't remember the exhaut size
Re: 360 magnum head-Help [Re: 540challenger] #73685
06/14/08 07:12 PM
06/14/08 07:12 PM
Mr.Mopar Offline OP
Mr.Mopar  Offline OP
thanks, was wondering because i saw a 360 mag engine at a junkyard, but i have been forwarned to look for cracks in the head
Kevin
1933 Dodge DP (201)
Re: 360 magnum head-Help [Re: Mr.Mopar] #73686
06/14/08 09:11 PM
06/14/08 09:11 PM
Kevin
very common problem from what people post. The ex is listed as 1.625" & I read that the seat is slightly smaller than that on them so I bought a single 1.6" chebby valve & my head man said perfect fit(reamed the guides to 11/32").
Re: 360 magnum head-Help [Re: RapidRobert] #73687
06/14/08 10:23 PM
06/14/08 10:23 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
However the aftermarket heads like EQs, Pro-Topline and mppar aluminum mags have 1.625 seats.
David
Re: 360 magnum head-Help [Re: HotRodDave] #73688
06/14/08 11:12 PM
06/14/08 11:12 PM
yeah mine were brand new stockers & if I had to do it over again(& I probably will) I would have used .100" longer chebby valves(they're cheap enough).
Re: 360 magnum head-Help [Re: RapidRobert] #73689
06/16/08 07:57 AM
06/16/08 07:57 AM
NY usa
NY usa
Kevin
Are the crack visable all do you need to get them magnafluxed???
Re: 360 magnum head-Help [Re: 540challenger] #73690
06/16/08 11:07 AM
06/16/08 11:07 AM
magnafluxed
Re: 360 magnum head-Help [Re: RapidRobert] #73691
06/16/08 02:25 PM
06/16/08 02:25 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
magnafluxed
Some are visable, some aren't. Always magnaflux when looking for cracks.
Re: 360 magnum head-Help [Re: MarkZ] #73692
06/16/08 03:08 PM
06/16/08 03:08 PM
dogdays Offline
dogdays  Offline
Clean head thoroughly. Soak the surface between the valves with penetrating oil. Wipe off the surface. Sometimes you can see a little bleedout from the crack after you have cleaned the surface.
Of course a real dye-penetrant kit would be better, and a Magnaflux using the magnetic powder would be even better.
Now here's a problem that has been discussed from time to time: the engine ran with the crack before the engine was taken apart, what makes us think that it won't run now? Also, some of the cracks are shallow enough that cutting the head for hardened seats cuts out the crack. But you can't tell from the outside how deep the crack is, and you never know what a crack is going to do, except you can be sure that it won't join itself back together!
I'm sorry, this is not a good answer. But maybe it's the best answer there is at the time.
R.
Re: 360 magnum head-Help [Re: dogdays] #73693
06/16/08 03:23 PM
06/16/08 03:23 PM
& I was wondering also about having a head pressure checked which my machine shop is equipped to do.I would NOT like to sink a bunch of time/money into a set & find out later that's there's a problem. Might be overkill but peace of mind to me is priceless.
