Rear suspension lowering blocks? #73610
06/14/08 04:24 PM
06/14/08 04:24 PM
SINY
SanityLost Offline OP
SINY
Where to get? Type of material? experience with them ETC.
Re: Rear suspension lowering blocks? [Re: SanityLost] #73611
06/14/08 05:32 PM
06/14/08 05:32 PM
florida
74fldart Offline
74fldart  Offline
florida
i would look into the truck customizing companies.i used to get catalogs from stylintrucks.com. they had them. as far as exp. with them and cant answere that . the blocks are either alum. or steel .
Re: Rear suspension lowering blocks? [Re: SanityLost] #73612
06/14/08 05:58 PM
06/14/08 05:58 PM
i prefer the steel ones to the aluminum ones for various reasons. wouldn't go much more then a 1" drop with
blocks. also watch the pinion angle.. becouse it will change.
Re: Rear suspension lowering blocks? #73613
06/14/08 06:09 PM
06/14/08 06:09 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Very simple to make with some 2.5 inch rectangle heavy gauge rectangle stock, a drill press, and a couple of drill bits. You will need longer u bolts too.
Re: Rear suspension lowering blocks? [Re: MoparforLife] #73614
06/14/08 08:59 PM
06/14/08 08:59 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
I think GregZ was selling some nice billet ones.
Re: Rear suspension lowering blocks? [Re: AdamR] #73615
06/14/08 09:22 PM
06/14/08 09:22 PM
Enfield, Ct
Moe Offline
Moe  Offline
Enfield, Ct
Apparently Mancini stop carrying them.
Re: Rear suspension lowering blocks? [Re: AdamR] #73616
06/14/08 09:29 PM
06/14/08 09:29 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I have the cheapo ones here, 1" blocks. No issues for a couple thousand mies. Then again, i dont lay down much for power either.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Rear suspension lowering blocks? [Re: GoodysGotaCuda] #73617
06/14/08 09:39 PM
06/14/08 09:39 PM
Enfield, Ct
Moe Offline
Moe  Offline
Enfield, Ct
Where did you get yours? Do we have 3" or 3 5/8" u-bolts on an 8 ¾?
Re: Rear suspension lowering blocks? [Re: Moe] #73618
06/14/08 09:45 PM
06/14/08 09:45 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
got mine through summit, came with u-bolts/nuts/washers. $20 or so.
Re: Rear suspension lowering blocks? [Re: GoodysGotaCuda] #73619
06/15/08 09:15 PM
06/15/08 09:15 PM
SINY
SINY
Would you happen to remember the part #? Was it aluminum or steel? ALSO what rear are you running in the cuda?
