Re: Rear suspension lowering blocks?
[Re: SanityLost]
#73612
06/14/08 05:58 PM
06/14/08 05:58 PM
i prefer the steel ones to the aluminum ones for various reasons. wouldn't go much more then a 1" drop with blocks. also watch the pinion angle.. becouse it will change.
[Re: GoodysGotaCuda]
#73617
06/14/08 09:39 PM
06/14/08 09:39 PM
Posts: 304 Enfield, Ct
Moe
Enfield, Ct
I have the cheapo ones here, 1" blocks. No issues for a couple thousand mies. Then again, i dont lay down much for power either.
Where did you get yours? Do we have 3" or 3 5/8" u-bolts on an 8 ¾?
[Re: Moe]
#73618
06/14/08 09:45 PM
06/14/08 09:45 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
got mine through summit, came with u-bolts/nuts/washers. $20 or so.
#73619
06/15/08 09:15 PM
06/15/08 09:15 PM
Posts: 1,947 SINY
SanityLost
SINY
Would you happen to remember the part #? Was it aluminum or steel? ALSO what rear are you running in the cuda?
