Hemi Rocker shaft orentation help #735695
06/28/10 02:41 PM
06/28/10 02:41 PM
Rock Springs
Bob_Coomer Offline OP
Rock Springs
Look at these following pics. I was concerned that the rocker shafts might be oriented incorrectly resulting in burnt rocker arms and push-rod tips.
Now I know the oiling holes always face pointing toward the camshaft etc.
I cant recall were these shafts came from. When I picked these up off a board memeber there was a set of shafts missing. Either I purchased new Intakes, or new exhausts..
Anyways.
These have a oil hole on one side, and a banana groove and oil hole on the other. Note these hemi rocker shafts can only be installed one way. With this you either have them upside down, or correct. If you turn the shafts completely around the oil holes would be on the opposite side nowhere near the rocker arm, creating a severe Hemorrhage oil leak.
So we have two choices, I chose the banana groove facing up, and the single hole facing down. knowing that gravity and movement should work the oil down too... Look
The first pic would show how the banana groove would look n the engine this way. This is looking towards the center of the engine, and these Hemi's have a good angle on the heads, so all the oil here would IMO not do much good at the lowest most bottom portion of the heads/valve train.
Same way but shows the top hole with the banana groove still facing down as in the previous picture.
Here is the wy I installed them. banana groove facing up and oil hole facing down.
Not sure if these shafts are drilled correctly..
Re: Hemi Rocker shaft orentation help [Re: Bob_Coomer] #735696
06/28/10 03:18 PM
06/28/10 03:18 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Banana grooves go toward the engine(down).Many of the shafts have a flat or notch on one end and should face up.If not mark them so that you can visually see they are on in the correct position.
Post deleted by Defbob [Re: B G Racing] #735697
06/28/10 03:42 PM
06/28/10 03:42 PM
Re: Hemi Rocker shaft orentation help #735698
06/28/10 03:50 PM
06/28/10 03:50 PM
Rock Springs
Rock Springs
Well they must have been machined wrong as I was thinking. No way they can face towards the engine, at least not these...
They can either face up like in the pic, or face down.
Re: Hemi Rocker shaft orentation help [Re: Bob_Coomer] #735699
06/28/10 05:38 PM
06/28/10 05:38 PM
grooves go down so the bottom of the rocker gets oil from the banana groove all the way across, also look at the top hole and the holes in the rockers to oil the valve stem and on the other side to oil the pushrod tips
Re: Hemi Rocker shaft orentation help [Re: Cab_Burge] #735700
06/28/10 09:10 PM
06/28/10 09:10 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
