Re: Jegs disc brakes... [Re: DoctorDiff] #735544
07/01/10 10:23 AM
07/01/10 10:23 AM
tboomer Offline OP
tboomer  Offline OP
cass...Can you e-mail me some prices and pics?? My e-mail is in my profile...After today,I have a bad work schedule so I may not respond right away... Should be out at the farm trimming brush...
Re: Jegs disc brakes... [Re: codfish] #735545
07/01/10 10:38 AM
07/01/10 10:38 AM
AndyF Offline
AndyF  Offline
Does this kit fit the A bodies as well?
Description only says B and E bodies.
Scrapyards around here with available parts are non-existant too.
codfish
It can fit A body cars but the details are a little confusing so Jegs probably finds it easier to just skip that issue. Basically you need the later model ball joints mounted on the car in order to work with the later model knuckle. There are several ways to do that trick.
Re: Jegs disc brakes... [Re: AndyF] #735546
07/02/10 07:58 AM
07/02/10 07:58 AM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
codfish
So the kit isn't "complete" for an A-body. Just need to buy 4 ball joints too?
What about you're kit for an A-body with 10" drums Cass?
codfish
Re: Jegs disc brakes... [Re: tboomer] #735547
07/02/10 11:13 AM
07/02/10 11:13 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
tboomer: I don't have pictures, but I sell the same kit as pictured.
codfish: Pre '73 A-bodies require changing upper control arms and lower ball joints. I also make tapered bushings so you can re-use the early A-body upper control arms.
Re: Jegs disc brakes... [Re: DoctorDiff] #735548
07/02/10 11:28 AM
07/02/10 11:28 AM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
Don't you need a non-power disc/drum master cylinder as well?
Re: Jegs disc brakes... [Re: Jeff_383] #735549
07/02/10 11:48 AM
07/02/10 11:48 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We have tons of the Mopar disc and drum set ups remove from cars that were converted to after market brakes.We have everything from nine inch to 11 inch drum set ups and single and daul piston front disc brakes.Some of this stuff is like brand new and some well used but in good shape.Also have spindles and other related suspension parts if anyone is interested.
Re: Jegs disc brakes... [Re: B G Racing] #735550
07/02/10 01:34 PM
07/02/10 01:34 PM
Nazareth,Pa.
JACKSON Offline
JACKSON  Offline
Nazareth,Pa.
TBOOMER, im sure one of these great guys on here should be able to hook you up!
Re: Jegs disc brakes... [Re: JACKSON] #735551
07/02/10 02:59 PM
07/02/10 02:59 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Ted - If you can afford the wilwood caliper upgrade, I would go that route, especially for a race car that could stand to shed a few pounds. I
I picked up the Dr Diff kit for my 62 Savoy(that I no longer own) and it was perfect. It had Wilwood calpipers Andys brackets, spindles, braided hoses, stock rotors, etc. No missing parts and I'm pretty sure Cass shipped everything before he got the money! Your shipping results may vary, but point is Dr Diff is a super guy to do business with.
(he did the Dana also, which was sa-weet)
2 kids and a dog
Re: Jegs disc brakes... [Re: DoctorDiff] #735552
07/02/10 05:47 PM
07/02/10 05:47 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
tboomer:
Cass do you sell a basic (read cheap lol) kit that WILL fit my 10" drum spindles?
thanks
gary
Re: Jegs disc brakes... [Re: codfish] #735553
07/03/10 01:21 AM
07/03/10 01:21 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Gary,
I made a prototype brake kit that used A-body 10" drum brake knuckles, 5 x 4 1/2" Mustang rotors and GM metric calipers. Everyting fit, but the kit wouldn't be much cheaper than the other I sell.
Re: Jegs disc brakes... [Re: DoctorDiff] #735554
07/03/10 12:15 PM
07/03/10 12:15 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
Just looking to do a swap without changing out my spindles.
gary
