Re: Buddys OLDS ran 12.80,, My car WONT HOOK,
[Re: MIKES_DUSTER]
#735275
06/28/10 06:29 PM
06/28/10 06:29 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
Well The car doesnt look the same as in my sig, cant remember how to change sig pictures. And the pinion angle is 3 degrees.
Kasey
Not enough, you need a good 6-7 degrees, especially with a stick car.
What about a auto??? My SS springs are going in tonight. My new front hangers JUST arrived!!!!
I'd say about -3,-4*, i run mine all the time at this, drive the 100 mile round trip to the track, make 3-4 passes & go home, the car is so smooth on the highway its comfee
Mike, you need to check your trans tailshaft angle to set the pinion angle currectly, mine is set at 0*, my pinion is down -3*.
[Re: Moparnut426]
#735278
06/28/10 09:27 PM
06/28/10 09:27 PM
Ok, been at work.
Car has /6 bars, and 90/10 front shocks.
I'LL SAY IT AGAIN, 90% OF MAKING ONE HOOK IS IN THE FRONT END ........Throw the CE shocks in the trash and buy some Cal-Trac front shocks.......Make sure it's got either urethane upper control arm bushings or heim joint control arms..........Use urethane bushings in the lower control arms...........and use heim joint strut rods.............
Soo You guys thing I need to loose my snubber, clamp the front of the springs, un clamp the rear springs,
Yes, AND install urethane front spring eye and shackle bushings........
Soft sidewall tires will be better than drag radials with a 4-speed, because they'll absorb the shock of dumping the clutch (as most know, shocking drag radials doesn't work).......BUT, it's not like you have a ton of power with the 360, so if it were me, I'd do all the suspension stuff (because you need that anyway) and go to a soft sidewall tire as a last resort.......
#735279
06/28/10 10:55 PM
06/28/10 10:55 PM
Posts: 3,420 Toronto
mshred
Toronto
Ok, been at work.
with a 4 speed you dont want soft sidewall tires, you want a stiffer sidewall, in fact as stiff as you can get...with a soft sidewall like a drag radial, the initial hit from the clutch wil cause less control and stability and therefore less traction...the stiff sidewall of the bias ply will help to absorb and plant the power while pointing the car straight...thats why stick guys are almost always running tubes as well, anything to help stiffen those sidewalls
#735280
06/28/10 11:06 PM
06/28/10 11:06 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
Im not running the 360 anymore, My stroker is done.
Im a bit confused on the side wall deal. I always thought the drag radial were stiffer on the side wall. The bias ply "wrinkle" walls are softer, flimsier???
Thats why the bias tires are so squishy down the road.
Kasey
[Re: Moparnut426]
#735281
06/28/10 11:15 PM
06/28/10 11:15 PM
mshred
Toronto
Kasey
the way the chords are wrapped inside a bias ply tire is different from that of a radial and favors itself more for stickshift driving...they are stiffer...look on a stickshift race car and guranteed you will not ever see a radial, always a bias ply
ive read of guys who have picked up a couple tenths just from switching from dr's to a bias ply...some even more than that...its pretty amazing actually
[Re: Moparnut426]
#735282
06/28/10 11:16 PM
06/28/10 11:16 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
kasey If you find the car still moves over during a burnout.. take more time setting tire pressure. and get a guage that reads in .25 pounds increments.. most times i find a car moves sideways during the burnout..its cause the tires arent air'd the same if you have a guage that only goes in full pound increments..you could be off from right tire to left tire..this will give you sideways burnouts and also kill any attempts to get traction.. get or borrow a large face gauge..with 1/4 or better 1/16 lb increments.. on the 6* pinon angle...id just be aware...that you street drive the car and down shift to engine brake...id be a little leary with 6* of pinion angle.. and down shifting.. if you go with 6* and find that it shakes under deceleration...you know were/what that issue is... fwiw.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: cheapstreetdustr]
#735284
06/28/10 11:28 PM
06/28/10 11:28 PM
Posts: 6,293 Northeast, Alpine, NY
9 Sec Phill
On a road near you
On a road near you
CSD, I would have to disagree with you on this, I know the air presure will very but the it has nothing to do with having the same presure in each tire. All tires are not the same hieght even if they are both 275/60/15's...One might be 28" and the other might be 29 1/2. He needs to check the roll out of each tire, take a tape measure and go around the tire and see if they are the same at 18 PSI, if not add air to one and let air out of the other, what ever it takes and to be safe with the presures till the tires have the same roll out or size. This will help the car launch straight and keep the car straigh in the BO box. My ...Phill
[Re: mshred]
#735285
06/29/10 02:18 AM
06/29/10 02:18 AM
joedust451
super gas
super gas
Branson, Mo.
Ok, been at work.
Is it me or do you have it backwards, DRs have a stiffer sidewall, Slicks are Bias ply, they wrinkle, they do make a stiffer sidewall slick, but you do want a softer hit with a stick car, DRs (if under enough power) will not over-come the hit or shock when dumping the clutch & high RPM, ET streets or QTPs will work much better, they have a softer sidewall.
Many on here will tell you with SS springs you need more pinion angle, especially with a stick car, a good 5-7 down, now driving it on the street you may feel vibration with no load or costing/de-exec., your U joints won't last as long, but if you can control the wrap up on the springs (with clamps), then you can get away with less angle, you just don't want to go in the +. This will cause "wind-up" & will let the pinion snap back down, in turn cuaseing wheel hop/porpasing & or blowing the tires loose, more or less once your in the + (pinion up) you loose torque multiplacation through the DS & too the pinion, if this makes sence.
[Re: mshred]
#735286
06/29/10 08:29 AM
06/29/10 08:29 AM
In his case, I don't agree with that.......That would be OK IF the car was hooking........
That's backwards.......The drag radials he's running have much stiffer sidewalls than Hoosier Quick Time Pros.......
Stick guys run do run tubes to make the soft sidewalls last longer......
#735287
06/29/10 04:25 PM
06/29/10 04:25 PM
mshred
Toronto
i dont think i have it backwards...when a radial tire hits with a stick car, the way the chords are wrapped causes a rebound that is detrimental for traction...in a bias ply tire the way the chords wrap absorbs but allows the car to point straight and hook, so there is less "rebound"...Stick racers are always looking for a stiffer tire, which is why tubes are run in them...
i mean i could be wrong here, but this is what i have heard many stickshift guys say, stiffer is better...it is only from this that i can assume that bias plies are stiffer, especially if they have less recoil as compared to drag radials on the same application
[Re: 9 Sec Phill]
#735288
06/29/10 05:52 PM
06/29/10 05:52 PM
cheapstreetdustr
I wont agure/disagree with that....
[Re: mshred]
#735289
06/29/10 07:35 PM
06/29/10 07:35 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
Keep at it but it's not that way.
Wayne, you hitting your head on the wall yet?
Pinion angle, clamps, lower the rear if possible and work the crap out of the front end as suggested. It's a 12.40 ride with the current MPH with everything going your way..
[Re: JCCuda]
#735292
06/30/10 12:29 PM
06/30/10 12:29 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
Kasey... first things first.. Get the motor in the car and take it for a spin.. Your combo sounds an aweful lot like my old combo.. 410 stroker, 4-speed, 391 gears, wrong shocks, etc.. and I have to admit, I chased troubles and inconsistencies for a couple of years..
That combo you have should easily run low 12's and at upwards to 115-119 mph, all depending on how much spin you get at the line.. To put this all into perspective, my combo ran all over the 12's.. From low 12 to high 12 between back to back passes and then one day out of no where, popped in a mid 11..
Tired of fighting (and losing races) with the 4 speed, I got fed up and put in a reverse manual 727 and there has been no looking back.. First pass with the new tranny was a 11.6x and all weekend long, I was within a .25 seconds while learning shift points and etc..
My recommendation to you is to first put 20lbs of air pressure in those E/T's... screw the QTP's, screw the bias crap.. E/T's will work!!!
Next I would launch at 2000 rpm, then 3000 rpm, then 4000 rpm to see which rpm the car liked the best.. After that, play with shift points to see what how the motor works and then once you get that out of the way.. come back here and tell us what happened.. The fine tuning of the car/suspension/launch can only happen after you take the car on its maiden voyage..
[Re: JCCuda]
#735293
06/30/10 12:32 PM
06/30/10 12:32 PM
Posts: 1,260 Netherlands
72Challenger
Netherlands
Last years I've ran a 4-speed in my 10sec running street/strip car. 72 Challenger weighing in at around 3750lbs.
I got rid of the front sway bar (or just loosen the side links at the track), had some CE 90/10 shocks in the front, caltracks w/ oem leafs in the rear. D60 w/ 4.30 gears turning GY 30x11.5 slicks. Leaving at 5k of rpm I had no traction issues at all? Before with Hoosiers I had some but with the goodyears none. I guess if you just get some sticky tires you should be fine.
Now I have the same engine in a strip only challenger weighing in at 2700lbs with a GForce clutchless behind it and still have no problems hooking up with 1.3 60fts running 9's the 1st time out.
Stick to the stick, it's the most fun!!
[Re: Jeepmon]
#735294
06/30/10 12:39 PM
06/30/10 12:39 PM
Moparnut426
GREAT ADVICE!! Finally someone chimed in with a similar set up. I did forget I put a swey bar up front. Thats gonna go Bye Bye, or atleast make me some disconnects for it.
Thanks for the ideas.
Kasey
