Re: Type F instead?
[Re: polkat]
#73410
06/14/08 12:39 AM
06/14/08 12:39 AM
Posts: 8,165 Left Coast
BobR
Left Coast
I have read that using Type F fluid (instead of Dexron) in torqueflites will slightly improve the firmness of shifts. Can anyone verify this? Thanks!
What year transmission? May not want to do that with a late model. For the older stuff this is a known shift improver-but don't expect miracles. -Bob
Re: Type F instead?
[Re: polkat]
#73412
06/14/08 01:28 AM
06/14/08 01:28 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
You should not mix the different types of fluid. The changeover is best when the tranny is fresh from the rebuilder and NO Dextron is in it. It does firm up shifts. The safest bet is fresh Dextron and a new filter.
Re: Type F instead?
[Re: 451Mopar]
#73414
06/14/08 08:05 AM
06/14/08 08:05 AM
RapidRobert
yes type F gives a slightly firmer shift but since you are up & running there's no way for you to change now without ending up mixing the 2 if mixing them would cause major problems. I remember those marv booth "the mad scientist" chrysler power articles & might still have one or 2 of them. I tried adding a qt or 2 of eng oil to the trans at that time. The trans didn't act any better but me thinking that I was helping my trans by giving it better "lubrication" made ME feel better.
Re: Type F instead?
[Re: RapidRobert]
#73415
06/14/08 08:44 AM
06/14/08 08:44 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
I did it on my B back in 78. Pulled the drain on the converter, and pan/filter. I didn't have a problem. 727 in my van has had type F in it since rebuild. Over 100K on it. Never heard the "jelly" thing.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Type F instead?
[Re: John_Kunkel]
#73417
06/14/08 06:43 PM
06/14/08 06:43 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
It's been running Dexron, but I just now read an article that said if you were running Dexron, you have to completely flush the tranny as adding Type F will make a jelly-like messif there is any Dexron still in the tranny.
Total nonsense!!! My favorite brew is a 50/50 mix of Dexron and type F.
All transmission fluid types can be mixed with no ill result in the fluid itself.
Same here, I had a converter full of Dexron when I went Type F, no Tranny Jelly here
