Type F instead? #73409
06/14/08 12:28 AM
06/14/08 12:28 AM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
I have read that using Type F fluid (instead of Dexron) in torqueflites will slightly improve the firmness of shifts. Can anyone verify this?
Thanks!
Re: Type F instead? [Re: polkat] #73410
06/14/08 12:39 AM
06/14/08 12:39 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Thanks!
What year transmission? May not want to do that with a late model. For the older stuff this is a known shift improver-but don't expect miracles. -Bob
Re: Type F instead? [Re: BobR] #73411
06/14/08 12:49 AM
06/14/08 12:49 AM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
It's an older 904. It's been running Dexron, but I just now read an article that said if you were running Dexron, you have to completely flush the tranny as adding Type F will make a jelly-like messif there is any Dexron still in the tranny. Glad I read this as the tranny is still in the car. Or, is there any truth to this?
Re: Type F instead? [Re: polkat] #73412
06/14/08 01:28 AM
06/14/08 01:28 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
You should not mix the different types of fluid. The changeover is best when the tranny is fresh from the rebuilder and NO Dextron is in it.
It does firm up shifts.
The safest bet is fresh Dextron and a new filter.
Re: Type F instead? [Re: sthemi] #73413
06/14/08 03:46 AM
06/14/08 03:46 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The old 904/727 are really forgiving on what fluids were in them. Back in the 80's Chrysler power Magazine ran some 727 hop-up articles by (I believe) Marv Booth who would run type-F for the friction, and add a quart or two of straight 30w (non-detergent) motor oil for lubrication.
Re: Type F instead? [Re: 451Mopar] #73414
06/14/08 08:05 AM
06/14/08 08:05 AM
yes type F gives a slightly firmer shift but since you are up & running there's no way for you to change now without ending up mixing the 2 if mixing them would cause major problems. I remember those marv booth "the mad scientist" chrysler power articles & might still have one or 2 of them. I tried adding a qt or 2 of eng oil to the trans at that time. The trans didn't act any better but me thinking that I was helping my trans by giving it better "lubrication" made ME feel better.
Re: Type F instead? [Re: RapidRobert] #73415
06/14/08 08:44 AM
06/14/08 08:44 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
I did it on my B back in 78. Pulled the drain on the converter, and pan/filter. I didn't have a problem. 727 in my van has had type F in it since rebuild. Over 100K on it.
Never heard the "jelly" thing.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Type F instead? [Re: polkat] #73416
06/14/08 06:19 PM
06/14/08 06:19 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Total nonsense!!! My favorite brew is a 50/50 mix of Dexron and type F.
All transmission fluid types can be mixed with no ill result in the fluid itself.
Re: Type F instead? [Re: John_Kunkel] #73417
06/14/08 06:43 PM
06/14/08 06:43 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Same here, I had a converter full of Dexron when I went Type F, no Tranny Jelly here
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Type F instead? [Re: GoodysGotaCuda] #73418
06/14/08 06:48 PM
06/14/08 06:48 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
In the end I did exactly what John mentioned. A 50/50 mix, and the tranny runs nicely! While doing this, I adjusted the bands (both) and the flair I mentioned in an earlier post is gone. Good deal all the way around.
Re: Type F instead? [Re: polkat] #73419
06/14/08 10:37 PM
06/14/08 10:37 PM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
Marv Booth got that issue somewhere.
Re: Type F instead? [Re: Y3 70 BEE] #73420
06/14/08 11:03 PM
06/14/08 11:03 PM
yeah adding eng oil to a trans was so far off the norm it was scary so I just had to try it.
