70 roadrunner max rim width? #733983
06/26/10 02:21 PM
06/26/10 02:21 PM
SO. CAL.
70blackfish Offline OP
SO. CAL.
what is the max rim width on a 70 road runner...will a 10 wide rim fit
Re: 70 roadrunner max rim width? [Re: 70blackfish] #733984
06/26/10 04:49 PM
06/26/10 04:49 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
yes 4.5 back spacing.
Re: 70 roadrunner max rim width? [Re: Dodgem] #733985
06/27/10 11:37 PM
06/27/10 11:37 PM
SO. CAL.
SO. CAL.
thanks
Re: 70 roadrunner max rim width? [Re: 70blackfish] #733986
06/28/10 05:39 AM
06/28/10 05:39 AM
N.H.
mopar-addiction Offline
N.H.
There are several threads going asking the same thing about 68-69 Roadrunners/GTX, I believe 70 Roadrunner would be the same. There is slight differences in quarter panels between Dodge and Plymouth that effect the rim offset, what fits in the Dodge is not exactly the same for Plymouth. This is what I found between my 68 RR and my buddies 70 Charger.
https://board.moparts.org/ubbthreads/show...e=0#Post5725604
https://board.moparts.org/ubbthreads/show...rue#Post5237205
Re: 70 roadrunner max rim width? [Re: mopar-addiction] #733987
06/28/10 12:47 PM
06/28/10 12:47 PM
SO. CAL.
SO. CAL.
I know your right...thats why I asked about a 1970 road runners
any pictures of 1970 road runner with 10 wide rims?
Re: 70 roadrunner max rim width? [Re: 70blackfish] #733988
06/28/10 02:54 PM
06/28/10 02:54 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I think this info is in the Archive section.
IIRC, backspacing for a 10" wheel on '68-'70 Plymouth B bodies needs to be more like 5.5"; I have 15x8s on mine with 4.5" BS and it sure seems like the difference would need to be split an inch each side to fit a 10.
Re: 70 roadrunner max rim width? [Re: topside] #733989
06/28/10 04:55 PM
06/28/10 04:55 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
My wheels are 10" with 5.5" backspacing, I doubt if 4.5" backspacing would fit because there's not much room either side. The tyres in the pics are BFG g-force 275/60/15 and it was pretty tight. I now have the same size MT ET streets fitted which are a little narrower so I have a bit more clearance.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: 70 roadrunner max rim width? [Re: Mick70RR] #733990
06/28/10 04:56 PM
06/28/10 04:56 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
Another pic.
Re: 70 roadrunner max rim width? [Re: Mick70RR] #733991
06/28/10 05:07 PM
06/28/10 05:07 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Another pic.
Damn nice lookin ride....
