Is this an original direct-drive hemi 4-speed starter? #733925
06/26/10 12:40 PM
06/26/10 12:40 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Is this an original direct-drive hemi 4-speed starter? More questions on my buddy's '68 Hemi 4-speed 'Runner.........
Thanks..
Troy
Houston Mopar Connection Club
Re: Is this an original drive-drive hemi 4-speed starter? [Re: hemi68charger] #733926
06/26/10 12:41 PM
06/26/10 12:41 PM
Houston, Tx
Houston, Tx
another..
Troy
Re: Is this an original drive-drive hemi 4-speed starter? [Re: hemi68charger] #733927
06/26/10 12:41 PM
06/26/10 12:41 PM
Houston, Tx
Houston, Tx
Finally..
Thanks in advance all my fellow moparts brethren..
Troy
Re: Is this an original direct-drive hemi 4-speed starter? [Re: hemi68charger] #733928
06/26/10 03:14 PM
06/26/10 03:14 PM
Virginia
rm23j8g Offline
rm23j8g  Offline
Virginia
It looks just like the one on my '68 4 speed hemi RR.
Protect that rubber boot on the solenoid, as mine fell apart years ago, and I can't find another one!
Re: Is this an original direct-drive hemi 4-speed starter? [Re: hemi68charger] #733929
06/26/10 08:40 PM
06/26/10 08:40 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
Thanks..
Not the best viewing angle, but it looks like a Hemi direct drive starter to me... see attachment.
Re: Is this an original direct-drive hemi 4-speed starter? [Re: xs29j8] #733930
06/26/10 11:41 PM
06/26/10 11:41 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
XS29J
Not sure if you have that correct with your pics.
A Real direct drive HEMI starter has the threaded top bolt hole going straight into the solenoid arm. Also look for the HEMI only main (steel)case #'s. A lot of those got inadvertently switched to a 6 cyl case #'s. A true hemi case # is something like 2642930 vs. a 6 cyl case # 1888100.
Re: Is this an original direct-drive hemi 4-speed starter? [Re: hemi70se] #733931
06/27/10 01:03 AM
06/27/10 01:03 AM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
Yeah that's it. Heres a close up of an original, the part # is one off the actual casting number-common with Mopar stuff.
Re: Is this an original direct-drive hemi 4-speed starter? [Re: hemi70se] #733932
06/27/10 04:52 AM
06/27/10 04:52 AM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
XS29J
Not sure what you see wrong in the pics... but I have been known to make mistakes... Maybe you thought that the picture showed the threaded hole not aligned with the centerline of the solenoid housing? I was using an archive photo that was handy, and the picture line of sight was not ideal. The threaded hole does align with the solenoid, and the pictures were showing the flange contour outline: a straight edge near the flange hole for the 6 Cyl, and a radiused edge flange contour for the Hemi starter castings.
Here is a photo of the only Hemi starter that I had easy access to tonight... others are buried in my workshop. Note that the profile of the flange is radiused near the threaded hole.
Allen
Re: Is this an original direct-drive hemi 4-speed starter? [Re: xs29j8] #733933
06/27/10 04:57 AM
06/27/10 04:57 AM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
An archive picture showing the flange profile difference...
Re: Is this an original direct-drive hemi 4-speed starter? [Re: xs29j8] #733934
06/27/10 05:01 AM
06/27/10 05:01 AM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
The correct number on my rebuilt Hemi direct drive starter "snout" housing...
Re: Is this an original direct-drive hemi 4-speed starter? [Re: xs29j8] #733935
06/27/10 05:05 AM
06/27/10 05:05 AM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
But, as with many rebuilt Hemi starters, a 6 Cyl barrel was used...
Re: Is this an original direct-drive hemi 4-speed starter? [Re: xs29j8] #733936
06/27/10 05:12 AM
06/27/10 05:12 AM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
Here is a composite picture for comparison showing the various photos posted earlier in this thread... note that the snout housing number and barrel number are different on the eBay obtained archive picture at the bottom of a 1966 Hemi direct drive starter...
