Is this an original direct-drive hemi 4-speed starter?
#733925
06/26/10 12:40 PM
06/26/10 12:40 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Is this an original direct-drive hemi 4-speed starter? More questions on my buddy's '68 Hemi 4-speed 'Runner.........
Thanks..
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: Is this an original drive-drive hemi 4-speed starter?
[Re: hemi68charger]
#733927
06/26/10 12:41 PM
06/26/10 12:41 PM
hemi68charger
Houston, Tx
Finally..
Thanks in advance all my fellow moparts brethren..
Re: Is this an original direct-drive hemi 4-speed starter?
[Re: hemi68charger]
#733929
06/26/10 08:40 PM
06/26/10 08:40 PM
Posts: 3,624 Fort Worth, Texas
xs29j8
Fort Worth, Texas
Thanks..
Not the best viewing angle, but it looks like a Hemi direct drive starter to me... see attachment.
[Re: xs29j8]
#733930
06/26/10 11:41 PM
06/26/10 11:41 PM
Posts: 2,483 Minneapolis, MN
hemi70se
Minneapolis, MN
XS29J Not sure if you have that correct with your pics. A Real direct drive HEMI starter has the threaded top bolt hole going straight into the solenoid arm. Also look for the HEMI only main (steel)case #'s. A lot of those got inadvertently switched to a 6 cyl case #'s. A true hemi case # is something like 2642930 vs. a 6 cyl case # 1888100.
[Re: hemi70se]
#733932
06/27/10 04:52 AM
06/27/10 04:52 AM
xs29j8
Fort Worth, Texas
XS29J
Not sure what you see wrong in the pics... but I have been known to make mistakes... Maybe you thought that the picture showed the threaded hole not aligned with the centerline of the solenoid housing? I was using an archive photo that was handy, and the picture line of sight was not ideal. The threaded hole does align with the solenoid, and the pictures were showing the flange contour outline: a straight edge near the flange hole for the 6 Cyl, and a radiused edge flange contour for the Hemi starter castings.
Here is a photo of the only Hemi starter that I had easy access to tonight... others are buried in my workshop. Note that the profile of the flange is radiused near the threaded hole.
Allen
