what plugs on eddys with 11.1 comp in 512 #73359
06/13/08 08:58 PM
06/13/08 08:58 PM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
Getting ready to fire up the 512 stroker and need some in put on what length plugs and what number and what brand . Has Eddy performer alum heads and is 11/1comp with 509 purple cam and M1 intake with 950cfm proform with msd ign and tti headers .Roller cam will come when $$$$ alow.what kind of power should I make??Its a four speed car.with 4:10gears @3800lbs..these heads are angle plug and have a deep thread for the plugs..I tried a j12y and it only went in 1/3 of the way..plugs would be fireing inside about 1/2 inch inside the threads...HUH ????
Re: what plugs on eddys with 11.1 comp in 512 [Re: dynamite] #73360
06/14/08 07:16 AM
06/14/08 07:16 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Edelbrock recommends Champion RC12YC with those heads.
Re: what plugs on eddys with 11.1 comp in 512 [Re: bobby66] #73361
06/14/08 07:35 AM
06/14/08 07:35 AM
IN
ahy Offline
ahy  Offline
IN
Mancini's site has plug recommendations by compression ratio for aluminum heads. I've done fine running their recommended NKG's. There are recommended Champion's also.
Re: what plugs on eddys with 11.1 comp in 512 [Re: ahy] #73362
06/14/08 04:36 PM
06/14/08 04:36 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
What you need is a small block style plug. 3/4 reach w/ a 5/8's hex nut. I made the mistake of reusing my big block iron head plugs when I switched to the Eddy heads and let me tell you, It wasn't pretty
I run an Autolite Ar 3924
Re: what plugs on eddys with 11.1 comp in 512 [Re: WILD BILL] #73363
06/14/08 06:39 PM
06/14/08 06:39 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
RN9YC in Champion #12 heat range too hot for 11-1 comp engine.
Leave the gun.......take the Cannoli's....Mike
Re: what plugs on eddys with 11.1 comp in 512 [Re: dynamite] #73364
06/14/08 09:03 PM
06/14/08 09:03 PM
AndyF Offline
AndyF  Offline
Use the plugs that Edelbrock recommends in the instructions.
Re: what plugs on eddys with 11.1 comp in 512 [Re: AndyF] #73365
06/14/08 10:48 PM
06/14/08 10:48 PM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
Andy F ..the car owner called Eddy and spoke to.Mr Stinson...Like the head honcho and he said rj12y plugs ...but they don't fit...I will try to call him Monday and explain what I see..It for sure needs long reach small block type plugs..Thanks
Re: what plugs on eddys with 11.1 comp in 512 [Re: dynamite] #73366
06/15/08 10:44 AM
06/15/08 10:44 AM
AndyF Offline
AndyF  Offline
Why call, just read the instructions.
Re: what plugs on eddys with 11.1 comp in 512 [Re: dynamite] #73367
06/15/08 04:12 PM
06/15/08 04:12 PM
NY
W
WICKD6PK Offline
WICKD6PK  Offline
W
NY
I'm runnin that 512 kit with a 6pk set up & use RC9YC4's. The ones Edelbrock recommends are toooooo hot like was said earlier in this thread.
