what plugs on eddys with 11.1 comp in 512
#73359
06/13/08 08:58 PM
06/13/08 08:58 PM
Posts: 1,444 NEW JERSEY
dynamite
NEW JERSEY
Getting ready to fire up the 512 stroker and need some in put on what length plugs and what number and what brand . Has Eddy performer alum heads and is 11/1comp with 509 purple cam and M1 intake with 950cfm proform with msd ign and tti headers .Roller cam will come when $$$$ alow.what kind of power should I make??Its a four speed car.with 4:10gears @3800lbs..these heads are angle plug and have a deep thread for the plugs..I tried a j12y and it only went in 1/3 of the way..plugs would be fireing inside about 1/2 inch inside the threads...HUH ????
Re: what plugs on eddys with 11.1 comp in 512
[Re: ahy]
#73362
06/14/08 04:36 PM
06/14/08 04:36 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
What you need is a small block style plug. 3/4 reach w/ a 5/8's hex nut. I made the mistake of reusing my big block iron head plugs when I switched to the Eddy heads and let me tell you, It wasn't pretty
I run an Autolite Ar 3924
[Re: WILD BILL]
#73363
06/14/08 06:39 PM
06/14/08 06:39 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
RN9YC in Champion #12 heat range too hot for 11-1 comp engine.
Leave the gun.......take the Cannoli's....Mike
