2006 Ram shudders #733531
06/25/10 07:37 PM
06/25/10 07:37 PM
Midwest
Chargerfan Offline OP
Midwest
I have a 06 Ram with the 5.7 Hemi. It is up to 71000. I have noticed in the last couple of months that when driving, the truck vibrates. It feels like more than a tire issue. Then today it vibrated horribly, especially around 30 up to 45 and even at 70 the motor just did not feel smooth. I don't think bad gas is it cause yesterday was the same fuel as today and it felt ok. Is there any known issues with these trucks or trans that would make it feel that way? Only thing I did today was change oil(not the brand). It is getting due for a trans filter and fluid change but will that help shuddering? Thanks
2011 Challenger R/T
2017 Ram 1500 BIG HORN Edition
Re: 2006 Ram shudders [Re: Chargerfan] #733532
06/25/10 07:57 PM
06/25/10 07:57 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Is the shudder felt in the steering wheel or whole truck? When you're on the throttle or coasting? Low engine RPM or high engine RPM?
2wd or 4wd?
- Stu Harmon
Re: 2006 Ram shudders [Re: feets] #733533
06/25/10 08:22 PM
06/25/10 08:22 PM
Midwest
Midwest
It can be felt a little in the steering wheel but mostly I can feel it with my butt. The seats and evrything inside shakes. Is worse accelerating but can still feel it when off of the gas. If I remember at 40-45 the rpm is 2500-2800 then comes down to 2000 at 65-70. In 2wd
2011 Challenger R/T
Re: 2006 Ram shudders [Re: Chargerfan] #733534
06/25/10 09:13 PM
06/25/10 09:13 PM
Catskill, NY
teflon Offline
teflon  Offline
Catskill, NY
Check your u-joints.
Re: 2006 Ram shudders [Re: teflon] #733535
06/25/10 10:47 PM
06/25/10 10:47 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Check the u joints. These newer dodge trucks eat u joints weather it be a 3/4 ton or 1/2 ton.
Re: 2006 Ram shudders [Re: Todd] #733536
06/26/10 01:29 AM
06/26/10 01:29 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
U joints? I had 165,000 miles on a 2002, NO u joint problems. 33,000 on a 2006 NO ujoint problems. Now, 75,000 on a 2007 with no u joint problems. I have towed with each truck, and I USE all the power these motors have. My previous u joint problems in other cars were most noticeable over 55 mph.
The shudder problem....My 2007 had a shudder that felt as if I were trying to accelerate on flat tires. It turned out to be a defect in the MDS system. One intake lifter went bad and played hell with the whole motor. It took 2 dealerships to figure it out at a cost of over $4000. A code reader might be of help to you. At least it may eliminate the motor as a possible problem.
Re: 2006 Ram shudders [Re: Kern Dog] #733537
06/26/10 08:19 AM
06/26/10 08:19 AM
Ohio
Todd Offline
Todd  Offline
Ohio
Why not start with the easiest things to check first? Hate to see someone tear down their engine or trans then find a bad u joint. JMHO.
Re: 2006 Ram shudders [Re: Todd] #733538
06/26/10 12:22 PM
06/26/10 12:22 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
First thing to look at are the wheels/tires.
Check for straightness, look for missing balance weights and check the tires for cord separation.
Best way check for separation is to jack it up, spin the tire and watch for any irregularities on the tread.
