2006 Ram shudders
#733531
06/25/10 07:37 PM
06/25/10 07:37 PM
Posts: 1,558 Midwest
Chargerfan
Midwest
I have a 06 Ram with the 5.7 Hemi. It is up to 71000. I have noticed in the last couple of months that when driving, the truck vibrates. It feels like more than a tire issue. Then today it vibrated horribly, especially around 30 up to 45 and even at 70 the motor just did not feel smooth. I don't think bad gas is it cause yesterday was the same fuel as today and it felt ok. Is there any known issues with these trucks or trans that would make it feel that way? Only thing I did today was change oil(not the brand). It is getting due for a trans filter and fluid change but will that help shuddering? Thanks
2011 Challenger R/T 2017 Ram 1500 BIG HORN Edition
Re: 2006 Ram shudders
[Re: Chargerfan]
#733532
06/25/10 07:57 PM
06/25/10 07:57 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Is the shudder felt in the steering wheel or whole truck? When you're on the throttle or coasting? Low engine RPM or high engine RPM? 2wd or 4wd?
[Re: feets]
#733533
06/25/10 08:22 PM
06/25/10 08:22 PM
Chargerfan
Midwest
It can be felt a little in the steering wheel but mostly I can feel it with my butt. The seats and evrything inside shakes. Is worse accelerating but can still feel it when off of the gas. If I remember at 40-45 the rpm is 2500-2800 then comes down to 2000 at 65-70. In 2wd
[Re: Todd]
#733538
06/26/10 12:22 PM
06/26/10 12:22 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
Why not start with the easiest things to check first? Hate to see someone tear down their engine or trans then find a bad u joint. JMHO.
First thing to look at are the wheels/tires. Check for straightness, look for missing balance weights and check the tires for cord separation. Best way check for separation is to jack it up, spin the tire and watch for any irregularities on the tread.
