50% Black #733382
06/25/10 02:16 PM
06/25/10 02:16 PM
Sacramento CA
Morty426 Offline OP
Morty426  Offline OP
Sacramento CA
Guys (and Gals),
I see people referring to parts painted 50% (or some other %) black. I understand it's a reduction in the gloss but how are you achieving it?
Is it with a flattner? Additional thinner.
I'm using PPG DL for most of my black parts but they don't list a flattner on the spec sheet.
Re: 50% Black [Re: Morty426] #733383
06/25/10 03:42 PM
06/25/10 03:42 PM
Northern Indiana
mr_belvedere Offline
super gas
super gas
Northern Indiana
Flattening agent
Re: 50% Black [Re: mr_belvedere] #733384
06/25/10 03:46 PM
06/25/10 03:46 PM
Sacramento CA
Morty426 Offline OP
Morty426  Offline OP
Sacramento CA
Flattening agent
Do you have the magic PPG part number?
Re: 50% Black [Re: Morty426] #733385
06/25/10 05:15 PM
06/25/10 05:15 PM
Northern Indiana
super gas
super gas
Northern Indiana
Morty, its best to have your local PPG supplier recommend a flattening agent for the paint system you are going to use.
Not all flattening agents are the same, be positive you are getting the right stuff.
I once used DX 265 to flatten a gallon of black urethane (paint shop said it would be fine) and wasted a gallon of paint. Paint store found the mistake they made, replaced the paint and DX 265. I know DX 265 is compatible with Delstar and Duracryl.
Re: 50% Black [Re: mr_belvedere] #733386
06/25/10 06:32 PM
06/25/10 06:32 PM
Sacramento CA
Morty426 Offline OP
Morty426  Offline OP
Sacramento CA
Mr Belvedere,
I would do that, but you see DL isn't really legal in CA
I have to order it or drive out of state.
Re: 50% Black [Re: Morty426] #733387
06/25/10 09:25 PM
06/25/10 09:25 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Call your local paint supplier. They will tell what flatning agent you need and give you the ratio needed to acheive the desired degree of gloss
Re: 50% Black [Re: Dougsmopars] #733388
06/27/10 11:18 AM
06/27/10 11:18 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Morty, what parts are you painting 50% black?
Re: 50% Black [Re: ScottSmith_Harms] #733389
06/28/10 08:13 PM
06/28/10 08:13 PM
Sacramento CA
Morty426 Offline OP
Morty426  Offline OP
Sacramento CA
Scott - I'm not painting anything 50% black. I was just using that as an example. However I think that most everything that is black laquer is flattened a little.
If you have a recommended reduction ratio I'd love to see it
Re: 50% Black [Re: Morty426] #733390
06/28/10 08:16 PM
06/28/10 08:16 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I don't because I don't believe ant of it was intentionally flattened to any degree. I believe it was all gloss black but due to the low quality of the paint, application methods, and possibly thinning agents used, it often resulted in a less than glossy or a "dull gloss" finish.
Re: 50% Black [Re: ScottSmith_Harms] #733391
06/28/10 10:24 PM
06/28/10 10:24 PM
Sacramento CA
Morty426 Offline OP
Morty426  Offline OP
Sacramento CA
I would guess they thinned it down to save money, but that doesn't seem to work well for me
Re: 50% Black [Re: Morty426] #733392
06/28/10 11:20 PM
06/28/10 11:20 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I was told that naptha was used as a thinning agent for some paints.
Re: 50% Black [Re: ScottSmith_Harms] #733393
06/29/10 02:30 AM
06/29/10 02:30 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
i've been trying to find a paint that will give the right look also, even a semi gloss black looks to glossy from the original black parts i have, the one that looks the best to me (maybe a bit less glossy than original) is the Krylon satin black.
