Re: Anyone Put A Zinc Anode In Waterpump Housing?
[Re: ResQ911]
#732337
06/23/10 10:22 PM
06/23/10 10:22 PM
Posts: 122 St. Paul, Mn.
Jim_S
St. Paul, Mn.
I used the 1/2" NPT ones in the block drain holes of a 383. I also got one from J.C. Whitney that hangs inside your radiator under the cap. Boat Zincs has all kinds of them, maybe something that will work in the pump housing. http://www.boatzincs.com/engine.html
69 Roadrunner 383 stock
[Re: ResQ911]
#732343
06/24/10 09:19 AM
06/24/10 09:19 AM
Andrewh
Anyone place them in the waterpump? Any concerns with this?
shouldn't be an issue. Just don't have a port to do it. I would make sure that it doesn't lead to the impeller, some of these zinc's are quite long.
