69 Ramcharger what do I need to mount it to the hood? #732219
06/23/10 06:35 PM
06/23/10 06:35 PM
Roscoe, IL
V
velocity2215rq Offline OP
V
Roscoe, IL
I am in the process of mounting the ramcharger box to my 69 superbee hood. I am not exactly sure what holds it to the hood (rivets...bolts?) since I am not the one who disassembled the car. Any advice & detailed pics would be greatly appreciated!
Re: 69 Ramcharger what do I need to mount it to the hood? [Re: velocity2215rq] #732220
06/23/10 08:22 PM
06/23/10 08:22 PM
S.E. Wis
a4runer Offline
a4runer  Offline
S.E. Wis
Plymouth uses rivots I would think Dodge is the same
Re: 69 Ramcharger what do I need to mount it to the hood? [Re: velocity2215rq] #732221
06/23/10 09:09 PM
06/23/10 09:09 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
hardware to attach the box to the hood
http://cgi.ebay.com/ebaymotors/Mopar-196...sQ5fAccessories
Re: 69 Ramcharger what do I need to mount it to the hood? [Re: gtx6970] #732222
06/23/10 09:17 PM
06/23/10 09:17 PM
Buffalo, NY U.S.A.
MrNormsTA Offline
MrNormsTA  Offline
Buffalo, NY U.S.A.
Weren't the originals mounted using full faced black solid head rivets, that had some sort of a cinch tool or press that flowered over the ends? What I always thought, or am I thinking just what holds the box together.
Re: 69 Ramcharger what do I need to mount it to the hood? [Re: MrNormsTA] #732223
06/23/10 10:09 PM
06/23/10 10:09 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Rick,
I think your thinking about the split rivet used to assemble the box sections themselves.
As far as I know the box itself is held to the hood ( center section only btw and 1969 only), with the large flange rivets as shown. Same rivets as the frame rail splash shields.
Each Outer section of the box uses screws
Re: 69 Ramcharger what do I need to mount it to the hood? [Re: gtx6970] #732224
06/24/10 08:07 AM
06/24/10 08:07 AM
Ft.Myers,Florida
Hemiruss Offline
Hemiruss  Offline
Ft.Myers,Florida
Sorry to cut in but what about the 70's I heard both ways....screws,rivots,etc....THANKS
Re: 69 Ramcharger what do I need to mount it to the hood? [Re: Hemiruss] #732225
06/24/10 08:40 AM
06/24/10 08:40 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Russ,
I've never seen a 70 with rivets.
Re: 69 Ramcharger what do I need to mount it to the hood? [Re: gtx6970] #732226
06/24/10 02:47 PM
06/24/10 02:47 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The rivets that were on mine were the same as those used to attach early Fox-body ('79, for example) Mustang front bumper covers.
Re: 69 Ramcharger what do I need to mount it to the hood? [Re: gtx6970] #732227
06/30/10 08:24 AM
06/30/10 08:24 AM
Houston, TX
Crunchy_Frog Offline
Houston, TX
That kit shows 6 rivets and 12 screws. Weren't they held on using 12 rivets and 8 screws (outside edge of ducts)? At least on all the original ones I have seen, granted I haven't seen too many originals, but the ones I have seen.....
Re: 69 Ramcharger what do I need to mount it to the hood? [Re: Crunchy_Frog] #732228
06/30/10 09:49 AM
06/30/10 09:49 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
John,
The one I took apart , was untouched and the only place the rivets were used was on the center section only. Both outer boxes were held on with all screws. I agree I haven't seen them all obviously either. I have an open mind and anythign is possibile. I'm always interested in learning more and offering an alternative kit if required
Re: 69 Ramcharger what do I need to mount it to the hood? [Re: gtx6970] #732229
06/30/10 11:32 AM
06/30/10 11:32 AM
Houston, TX
Houston, TX
Bill, I thought there might be variations there, plant, day of the week, sun spots, solar flares, planetary alignment. The parts guide and service manual show rivets and screws, but does not mention location and quantity. The "restoration guides" have a lot of incorrect data, so, like you, I try to see what's out there. I have a ? and comment bout a product you offer, I'll send a pm.
