Radiator Cap, Chassis Manual, Ground Strap - 68 Hemi RR
#730310
06/21/10 11:31 AM
06/21/10 11:31 AM
Posts: 757 Northern VA
bulletpruf
Northern VA
Fellas -
A few random questions -
I have an 8# radiator cap on my car now. Looks factory, but 8# sure seems kind of light, and car seems to puke water/AF too easily. Was it 8# originally?
I recently purchased the shop manual for 68 B bodies, but shouldn't I also be able to find a chassis/assembly manual? Didn't see any on eBay. Anyone know where these can be found?
I purchased a repro engine ground strap (engine to firewall, I presume) from Mancini, but the car did not have one, so I'm unsure as to routing. Any clues on routing it correctly?
Thanks in advance for any info.
Scott
Please Check Out My YouTube Channel for Vintage Musclecar and Truck Rescues and Builds -- https://www.youtube.com/@THEBULLETPROOFGARAGE/videos
Re: Radiator Cap, Chassis Manual, Ground Strap - 68 Hemi RR
[Re: gtx6970]
#730313
06/21/10 12:53 PM
06/21/10 12:53 PM
bulletpruf
Northern VA
Thanks, fellas. Much appreciated.
Scott
[Re: bulletpruf]
#730316
06/22/10 08:32 AM
06/22/10 08:32 AM
Posts: 21,441 It's a dry heat
gtx6970
It's a dry heat
Air grabber cable(or choke cable in your case) comes thru where the rubber grommet is in my picture above.Firewall ground hole is above and to the left of the regulator Firewall ground fasteners TYPICALLY uses a fastener similar to this , but slightly shorter overall.As long as theres nothing it can hit inside, I guess it can be used as is. it's a 1/4-20 thread pitch
[Re: ademon]
#730317
06/22/10 10:07 AM
06/22/10 10:07 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
The ground strap on '68 b-bodies typcially where further down the firewall near the heater hose inlet. You can vaguely see the attach bolt/screw just below the PVC hose under the ballast resistor.
Now, the later production '68 models could have had the ground strap closer to the ballast resistor which is the case for the '69 model year.
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: hemi68charger]
#730318
06/22/10 10:51 AM
06/22/10 10:51 AM
gtx6970
It's a dry heat
Well, I've never noticed that one before. But I think you may be right
1968 Hemi Runner
[Re: hemi68charger]
#730320
06/22/10 12:53 PM
06/22/10 12:53 PM
bulletpruf
Northern VA
Fellas -
Really appreciate the pics and details. My car was built 25 September 1967, so I'll be looking for the ground strap mounting hole that's pictured. Don't recall seeing anything there, but that's not where I was looking last night.
Thanks again,
Scott
[Re: bulletpruf]
#730322
06/22/10 08:44 PM
06/22/10 08:44 PM
hemi68charger
Houston, Tx
Fellas -
Thanks again,
Scott
Yep, there's a hole there - same place pictured above by Hemi68Charger and GTX6970.
I suppose I can get the correct fastener at Year One or some similar vendor?
Thanks,
Scott
Or from Bill himself (GTX6970).. He's got a nice website and sells quality stuff. I've bought many things from him....
