Radiator Cap, Chassis Manual, Ground Strap - 68 Hemi RR #730310
06/21/10 11:31 AM
06/21/10 11:31 AM
San Antonio, Tx
bulletpruf Offline OP
San Antonio, Tx
Fellas -
A few random questions -
I have an 8# radiator cap on my car now. Looks factory, but 8# sure seems kind of light, and car seems to puke water/AF too easily. Was it 8# originally?
I recently purchased the shop manual for 68 B bodies, but shouldn't I also be able to find a chassis/assembly manual? Didn't see any on eBay. Anyone know where these can be found?
I purchased a repro engine ground strap (engine to firewall, I presume) from Mancini, but the car did not have one, so I'm unsure as to routing. Any clues on routing it correctly?
Thanks in advance for any info.
Scott
Please Check Out My YouTube Channel for Vintage Musclecar and Truck Rescues and Builds -- https://www.youtube.com/@THEBULLETPROOFGARAGE/videos
Re: Radiator Cap, Chassis Manual, Ground Strap - 68 Hemi RR [Re: bulletpruf] #730311
06/21/10 11:47 AM
06/21/10 11:47 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
My 68 Hemi RR is about 65 miles away at the moment, so I'm just gonna take a few shots from memory:
8# is low, thought they were more like 15#. I don't recall for certain what's on mine but it's the OEM reproduction.
Shop manual has the body info; no separate factory manual (as in GM cars) that I know of.
Ground strap runs from rt cylinder head to firewall, uses same fastener @ firewall as the other firewall items. IIRC, some repro straps are incorrect length but otherwise appear OK.
Re: Radiator Cap, Chassis Manual, Ground Strap - 68 Hemi RR [Re: bulletpruf] #730312
06/21/10 11:48 AM
06/21/10 11:48 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I believe 16lb is correct
1968 service manuals are all in 1 book
firewall grnd is pass side rear intake bolt to firewall near the voltage regulator,
in the hole to the left of the regulator in this pic
Re: Radiator Cap, Chassis Manual, Ground Strap - 68 Hemi RR [Re: gtx6970] #730313
06/21/10 12:53 PM
06/21/10 12:53 PM
San Antonio, Tx
San Antonio, Tx
Thanks, fellas. Much appreciated.
Scott
Re: Radiator Cap, Chassis Manual, Ground Strap - 68 Hemi RR [Re: bulletpruf] #730314
06/21/10 01:42 PM
06/21/10 01:42 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
pic
Re: Radiator Cap, Chassis Manual, Ground Strap - 68 Hemi RR [Re: ademon] #730315
06/22/10 07:16 AM
06/22/10 07:16 AM
San Antonio, Tx
San Antonio, Tx
pic
I looked at the engine last night and did see that there was a hole where the ground strap connects to the firewall. I think the choke cable is running through there now, but I can fix that.
My question is what type of fastener is used on the ground strap connection at the firewall? I can't tell from the picture. I figured it would be a stud and a nut, but that's not what it looks like to me.
Scott
Re: Radiator Cap, Chassis Manual, Ground Strap - 68 Hemi RR [Re: bulletpruf] #730316
06/22/10 08:32 AM
06/22/10 08:32 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Air grabber cable(or choke cable in your case) comes thru where the rubber grommet is in my picture above.Firewall ground hole is above and to the left of the regulator
Firewall ground fasteners TYPICALLY uses a fastener similar to this , but slightly shorter overall.As long as theres nothing it can hit inside, I guess it can be used as is.
it's a 1/4-20 thread pitch
Re: Radiator Cap, Chassis Manual, Ground Strap - 68 Hemi RR [Re: ademon] #730317
06/22/10 10:07 AM
06/22/10 10:07 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
The ground strap on '68 b-bodies typcially where further down the firewall near the heater hose inlet. You can vaguely see the attach bolt/screw just below the PVC hose under the ballast resistor.
Now, the later production '68 models could have had the ground strap closer to the ballast resistor which is the case for the '69 model year.
Troy
Houston Mopar Connection Club
Re: Radiator Cap, Chassis Manual, Ground Strap - 68 Hemi RR [Re: hemi68charger] #730318
06/22/10 10:51 AM
06/22/10 10:51 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Well, I've never noticed that one before. But I think you may be right
1968 Hemi Runner
Re: Radiator Cap, Chassis Manual, Ground Strap - 68 Hemi RR [Re: gtx6970] #730319
06/22/10 11:58 AM
06/22/10 11:58 AM
Houston, Tx
Houston, Tx
1968 Hemi Runner
Bill,, you're going to make me blush...
Troy
Re: Radiator Cap, Chassis Manual, Ground Strap - 68 Hemi RR [Re: hemi68charger] #730320
06/22/10 12:53 PM
06/22/10 12:53 PM
San Antonio, Tx
San Antonio, Tx
Fellas -
Really appreciate the pics and details. My car was built 25 September 1967, so I'll be looking for the ground strap mounting hole that's pictured. Don't recall seeing anything there, but that's not where I was looking last night.
Thanks again,
Scott
Re: Radiator Cap, Chassis Manual, Ground Strap - 68 Hemi RR [Re: bulletpruf] #730321
06/22/10 08:39 PM
06/22/10 08:39 PM
San Antonio, Tx
San Antonio, Tx
Fellas -
Thanks again,
Scott
Yep, there's a hole there - same place pictured above by Hemi68Charger and GTX6970.
I suppose I can get the correct fastener at Year One or some similar vendor?
Thanks,
Scott
Re: Radiator Cap, Chassis Manual, Ground Strap - 68 Hemi RR [Re: bulletpruf] #730322
06/22/10 08:44 PM
06/22/10 08:44 PM
Houston, Tx
Houston, Tx
Fellas -
Thanks again,
Scott
Thanks,
Scott
Or from Bill himself (GTX6970).. He's got a nice website and sells quality stuff. I've bought many things from him....
Troy
Re: Radiator Cap, Chassis Manual, Ground Strap - 68 Hemi RR [Re: bulletpruf] #730323
06/22/10 08:50 PM
06/22/10 08:50 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I'm sure Bill has those screws ......
Here's my brother's 9/27/67 '68 GTX (St. Louis assembled). I see the dimple where the HEMI cars above are shown, but this one is grounded 2" away.
I'll have to take a closer look next time I'm in Ohio.
Re: Radiator Cap, Chassis Manual, Ground Strap - 68 Hemi RR [Re: 6bblgt] #730324
06/22/10 09:03 PM
06/22/10 09:03 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I found an older picture of it with the firewall bare. I see 2 holes, guess I picked the wrong one.
Re: Radiator Cap, Chassis Manual, Ground Strap - 68 Hemi RR [Re: 6bblgt] #730325
06/22/10 09:23 PM
06/22/10 09:23 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Here's a spring '68 (St. Louis assembled) 383 2bbl with A/C Sport Satellite I had. It appears to also be above the last set of wire tabs on the firewall.
Re: Radiator Cap, Chassis Manual, Ground Strap - 68 Hemi RR [Re: hemi68charger] #730326
06/23/10 12:55 PM
06/23/10 12:55 PM
San Antonio, Tx
San Antonio, Tx
Fellas -
Thanks again,
Scott
Thanks,
Scott
You're right about Bill's site - just e mailed him with an order of stuff for my car.
Thanks,
Scott
