Challenger dash pad removal question #73028
06/13/08 11:28 AM
06/13/08 11:28 AM
Waterloo, Wi
joedee Offline OP
joedee  Offline OP
Waterloo, Wi
I have 1970 dodge challenger that I am going to be replacing the dash pad on. The windshield is out of the car so getting to the top bolts is easy. Dash is currently complete with all the gauges, A/C vents and glove box installed. My plan is to remove the top bolts and loosen the side bottom bolts and tilt the dash foreward to get to the pad attaching bolts. Is there anything else I need to remove before I tilt the dash forward?
Re: Challenger dash pad removal question [Re: joedee] #73029
06/13/08 11:58 AM
06/13/08 11:58 AM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
It might be kinda hard to get to the nuts that secure the dashpad to the frame with everything in the way. (Going by memory on this though. I can find out for sure tonight, for I have a complete AC dash assembly sitting on my workbench that I recently put together for a friend.)
Re: Challenger dash pad removal question [Re: Blues_Cuda] #73030
06/13/08 12:22 PM
06/13/08 12:22 PM
Waterloo, Wi
joedee Offline OP
joedee  Offline OP
Waterloo, Wi
Hi,
That would be great. Thanks!
Re: Challenger dash pad removal question [Re: joedee] #73031
06/13/08 12:43 PM
06/13/08 12:43 PM
Zzyzx Road
beepbeep Offline
moparts member
beepbeep  Offline
moparts member
Zzyzx Road
IIRC the glove box and cluster is in the way.
Amazing how an unchallenged lie can become the absolute truth.
Re: Challenger dash pad removal question [Re: beepbeep] #73032
06/13/08 02:02 PM
06/13/08 02:02 PM
WI
RestoRick Offline
RestoRick  Offline
WI
You'll also want the 2 steering column support studs out if they're not already.
Rick
Re: Challenger dash pad removal question [Re: RestoRick] #73033
06/13/08 02:31 PM
06/13/08 02:31 PM
Waterloo, Wi
joedee Offline OP
joedee  Offline OP
Waterloo, Wi
Thanks for the input. It almost looks like it would be easier to just take the glove box and ash tray out and just reach up under the dash versus unbolting the dash and pulling it forward.
Also, why would I need to remove the steering wheel colum studs? I was just going to loosen them to bring the wheel down some so I could tip the dash.
Re: Challenger dash pad removal question [Re: joedee] #73034
06/13/08 03:28 PM
06/13/08 03:28 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
They can still get in the way...especially if the front seat or steering wheel are not letting the column drop far enough.
Come to think of it, I don't think you'd be able to swing the assembly down at all with them in place.
Re: Challenger dash pad removal question [Re: joedee] #73035
06/13/08 10:03 PM
06/13/08 10:03 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Remove the instrument cluster,the glove box,and ash tray. You can get to all the nuts then. Don't forget to remove the screws on the outside of each end. Also,if you're sending your old pad in for a core, don't forget to remove your VIN tag Grind the rivets off from the bottom. don't try to drill them out from the top! Good luck
