Ye ol 383 finally got a snail !!!!!!!! #729822
06/20/10 09:35 PM
06/20/10 09:35 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Well i pulled a all nighter on friday and finnaly got a snail on the old worn out 383 in the Belvedere.
Setup so far.
Really tired and abused 383 smokes bad, but still held its own when needed !!!!!!
280/480 Comp Cam.
Edy Torker 383.
Mallory dual point dizzy.
Holley 750 with Proform body modified by yours trully for Blowthru.
Specter carb hat.
One GT45 Y2004K turbo with a 1.05 A/R housing, I have 2 but didnt think the poor tired 383 could spool both, both bought off of Ebay.
I know you guys are gonna rip on me for useing Ebay stuff but from the sources I have I acquired verry good info about what I bought that have been on a car for over a year now.
A set of stainless block hugger headers, Also from Ebay, thay have verry thick flanges and look to good for the motor being all shiny and stuff!!!!
I plumbed the turbo with 2.5 pipe I bent up myself that y together and poke up thru the hole in the K member.
One 4" Hooker U bend I had layin around worked good for the Turbo to carb pipe.
Ebay silicone couplers.
4 hose clamps witch hold it together but dont work verry well, like i said it was a allnighter.
I have 2 53mm BOV and 2 60mm wastegates all bought from Ebay from Wyntomn.
I dont have the wastegate or BOV installed yet, Allnighter again 6:30 saturday morning it was runnin.
I dont have a boost refrenced pump yet either, just the old mechanical Holley.
It has a 3400 Precision converter that was already in the car.
3.91 gear with 29/9 Goodyear slicks.
As for the test results we had today in the back alley, it shure does get after those 29/9 Goodyear slicks and blows lots of black smoke!!!!!!!!!!!
No boost guage yet either.
Ill try to get the vid working, my buddy recorded some of the foolishness!!!!!!
If you guys have anny tips i can use for a budget turbo deal give me a shout.
Re: Ye ol 383 finally got a snail !!!!!!!! [Re: RockChip] #729823
06/21/10 09:26 AM
06/21/10 09:26 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
You fired up the engine and did a burnout with no form of boost control? Brave man! I'd get that wastegate on ASAP before you scatter the engine.
Other than that, good job!
- Stu Harmon
Re: Ye ol 383 finally got a snail !!!!!!!! [Re: feets] #729824
06/21/10 09:27 AM
06/21/10 09:27 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
cool, drive it like you stole it.
Coming soon!!!!
Re: Ye ol 383 finally got a snail !!!!!!!! [Re: feets] #729825
06/21/10 03:31 PM
06/21/10 03:31 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
And get that fuel pump boost-referenced!
Keep your sacrificial lamb together so you can learn as much as possible on the first engine!
OTH - congrats!
Re: Ye ol 383 finally got a snail !!!!!!!! [Re: Fury Fan] #729826
06/21/10 11:33 PM
06/21/10 11:33 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Yea i know im playin on thin ice without a wastegate and boost guage but its a MOPAR BABY !!!! and they can take the abuse better than annything i know.
I did get the BOV on it tonight.
Boost guage and wastegate commin soon!!!!!
Re: Ye ol 383 finally got a snail !!!!!!!! [Re: feets] #729827
06/22/10 07:49 AM
06/22/10 07:49 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
When I first played with my motor, I had the blow off valve reference plumbed wrong. Turbos made funny noises
Re: Ye ol 383 finally got a snail !!!!!!!! [Re: Defbob] #729828
06/22/10 10:22 PM
06/22/10 10:22 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
BOV works grate!!! but thanks for the concern
Still trying to figure out the vid.
It runs like a scalded cat !!!!!!!!!
I got the boost guage today but no time to install it.
Re: Ye ol 383 finally got a snail !!!!!!!! [Re: RockChip] #729829
06/23/10 09:29 AM
06/23/10 09:29 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Yeah I ran an e-bay bousch (for an Audi) $38 BOV on my s/c'd 440. Worked fine...but I was only pushing 6psi of boost. You might want to look into Meth injection.
Re: Ye ol 383 finally got a snail !!!!!!!! [Re: Mr.Yuck] #729830
06/23/10 11:44 PM
06/23/10 11:44 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Yea i was thinking a bout meth injection, i got a cheater plate under the carb at the moment but its not hooked up yet.
Is thare anny cheap ways to do a meth injection deal?
I dont want to buy a premaid kit.
Re: Ye ol 383 finally got a snail !!!!!!!! [Re: RockChip] #729831
06/24/10 07:21 AM
06/24/10 07:21 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I guess you could rig something but the pre-made kit is only $249 and works as your boost hits. Shipping was free.
I just bought this kit yesterday for my 440-6
http://cgi.ebay.com/ebaymotors/ws/eBayIS...RK%3AMEWNX%3AIT
guy has good prices.
Re: Ye ol 383 finally got a snail !!!!!!!! [Re: RockChip] #729832
06/24/10 06:47 PM
06/24/10 06:47 PM
Turbo383 Offline
Turbo383  Offline
Make sure you externally reference the power valve if it's a suck thru setup - if you run lean under boost, you will cook it quick!
I have a 70 383 Challenger w/ AC, that I turbo'd in '79 and I had to cobble together / cut /weld parts from other kits to make it work and look right. It used TRW forged pistons for the 2bbl 383 (8.25 comp)It ran incredibly strong - had water/methonal injection above the carb airhorn, allowed me to run 34-36 degrees advance, but you had it bring it in a litle later.
I used a an oil cooler just for the Turbo, and a homebuilt hydraulic accumulator to feed it after shutdown - though it would still coke up the turbo bearings after awhile.
AT first I ran it w/o a wastgate, but I had a boost gauge to monitor. Most boost ever was about
22lbs, but finally installed wastegate w/ 11 lbs
and it worked well
Re: Ye ol 383 finally got a snail !!!!!!!! [Re: RockChip] #729833
06/24/10 08:16 PM
06/24/10 08:16 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
you can boost ref the pump by hammering a 1/8" flaired fitting into the top. That's what I did on my old S/C'd 440. There should be a small hole on the top or side of the fuel pump, I think it's a vent. Get a piece of tubing and just tap it in, atttach the vaccum line and you're done.
Re: Ye ol 383 finally got a snail !!!!!!!! [Re: RockChip] #729834
06/24/10 08:20 PM
06/24/10 08:20 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
like this....
Re: Ye ol 383 finally got a snail !!!!!!!! [Re: Mr.Yuck] #729835
06/24/10 11:29 PM
06/24/10 11:29 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
It's a blow thru setup not suck thru, but thanks for the concern.
Yea I boost referenced my pump, What the max boost i can run with my mechanical pump?
I havent installed the guage yet but I will be puttin in some time on it tomorow night.
After what a difference one turbo can do to this old 383 I cant waight till I hang my 80s on my Indy wedge!!!!
Re: Ye ol 383 finally got a snail !!!!!!!! [Re: Mr.Yuck] #729836
06/24/10 11:37 PM
06/24/10 11:37 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Hey Mr Yuck !!!!!
Let me know how that meth kit works.
I dont plan on intercooling my Belvedere for a while and that kit you showed me just fits in the budget.
Re: Ye ol 383 finally got a snail !!!!!!!! [Re: RockChip] #729837
06/25/10 08:30 AM
06/25/10 08:30 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Hey Mr Yuck !!!!!
will do. The guy told me he picked up 67hp on a 427 3x2 vette with it. And that's on pump gas. make sure you get the boost kit and not the one for N/A. One runs of the vaccum signal one runs of a boost signal.
Re: Ye ol 383 finally got a snail !!!!!!!! [Re: Mr.Yuck] #729838
06/25/10 10:49 PM
06/25/10 10:49 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
So I finnaly got the boost guage hooked up and to my suprise I can get 20 psi of boost with this ol heap !!!!!!
She really starts motivatin at 12 psi then the engine flares and 20 shows on the dial, its time I get that wastegate hooked up
I bidnt get to test much due to bad storm rolling threw but Ill beat on it a bit tomorow.
Ol 383 seems to like it, it quit smokin !!!!!!
What you guys think the ol heap is capable of for horsepower with this kind of boost?
How long and how much boost you guys think the cast pistons will withstand?
I have it runnin on E85, Timing set at 30.
Re: Ye ol 383 finally got a snail !!!!!!!! [Re: RockChip] #729839
06/26/10 12:44 AM
06/26/10 12:44 AM
Grande Prairie, Alberta, Can.
CW25 Offline
CW25  Offline
I had a 383 in my old truck and it had a stone stock long block with a 270* .470" comp cam. It only had 110 lbs of cranking compression. I ran up to 15 lbs of boost on 91 pump gas and ran a best of 12.64@110. Thought that MPH was pretty good for a full size truck with a nearly stock engine... Minus the turbo.
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
Re: Ye ol 383 finally got a snail !!!!!!!! [Re: CW25] #729840
06/26/10 07:50 AM
06/26/10 07:50 AM
IN
ahy Offline
ahy  Offline
IN
If it doesn't detonate the cast pistons should live for a while. If it does detonate, they may last a few minutes. Sustained operation beyond 5-7 lb they will probably get iffy.
Re: Ye ol 383 finally got a snail !!!!!!!! [Re: ahy] #729841
06/26/10 07:08 PM
06/26/10 07:08 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
He has it on E85 which should help stave off detonation. Make sure it doesn't lean out either. Melted cast pistons aren't any better than detonated ones.
Kevin
