dumb question-- Rims drilled for slicks? #729529
06/20/10 12:12 PM
06/20/10 12:12 PM
MA
440beeper Offline OP
MA
Once rims are drilled for slicks, does that mean than can only be used for strip duty?
Re: dumb question-- Rims drilled for slicks? [Re: 440beeper] #729530
06/20/10 12:23 PM
06/20/10 12:23 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
No.
Re: dumb question-- Rims drilled for slicks? [Re: 440beeper] #729531
06/20/10 12:26 PM
06/20/10 12:26 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
i'd like to know too.. I have a nice set of steelies from a D150 that I used as drag wheels for my car. drilled, tubed, etc...
I measured the width 15 x 8. they are nice and wide and look similar to the late 60's steelies, but better size.
probably wouldn't be too hard to weld up the holes, but what, if anything, would that do to the wheel balance?
Re: dumb question-- Rims drilled for slicks? [Re: Pool Fixer] #729532
06/20/10 12:31 PM
06/20/10 12:31 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Why would you need to weld them up?
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: dumb question-- Rims drilled for slicks? [Re: HealthServices] #729533
06/20/10 12:43 PM
06/20/10 12:43 PM
Az
Crizila Offline
Crizila  Offline
Az
Screws in or out,tube or tubeless, they shouldn't leak. I'd just run some fancy screws in the holes and letem rip. Good conversation piece too
Fastest 300
