Re: More Engine Problems
[Re: AdamR]
#72901
06/13/08 11:58 AM
06/13/08 11:58 AM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
First thing to do is buy a timing tape for the balancer. Check initial timing and total timing.
Is this a Mopar Perf. distributor or a factory one ?
no the first thing to do is buy a freakin timing light .
i can not believe how many people are timing their engines BY EAR ...
[Re: JohnRR]
#72902
06/13/08 12:09 PM
06/13/08 12:09 PM
Posts: 1,233 Eastern North Carolina
cyphre666
Timing by ear is Old School, and yes I have a timng light now. Way back when, no timing light. A lot of times timing numbers mean nothing, wear, cams, dist adv.all change your specs. We could have the exact same specs on the same engines and one will react differently. So, it is not all the nutty to time by ear. Quote:
[Re: cyphre666]
#72905
06/13/08 12:35 PM
06/13/08 12:35 PM
JohnRR
U.S.S.A.
thats silly , are you going to make parts for your car with a file and and a hacksaw because modern motor driven equipment isn't OLD SCHOOL ???
he has a timing light , so what if it's not inductive pickup , now you are just being silly ...
[Re: cyphre666]
#72907
06/13/08 12:44 PM
06/13/08 12:44 PM
Posts: 1,261 ILL
mark7171
ILL
So, you are saying you can build duplicate engines with all the same parts and they will all perform exactly the same, Not in a Million years
i missed the first part. but in class that is exactly what we did. used the same parts dynoed them at got the same results(within reason)..hmmmmm
[Re: bordin34]
#72908
06/13/08 12:54 PM
06/13/08 12:54 PM
Posts: 4,008 South Park, Pa.
68LAR
South Park, Pa.
I know you guys are probably getting tired of my engine problems but here it goes. My last problem was a combination of being too lean and a bad coil. The engine is a 73 400 originally a 2bbl, now has a Holley 670 Street Avenger, 452 heads, mild cam, and headers.
Now I have the engine running and barely drivable. The car refuses to idle below 1000rpm and tries to die when put in gear unless I feather the throttle, but once it is in gear for a couple seconds I can let go of the gas and it will run all day.
I am no expert so I set the timing by getting the engine to a steady 3000rpm with the vac advance disconnected then moving the dist until I got what i thought was the highest rpm by ear. The car revs fine with now load all the way to 4500rpm, which is as high as I want to rev it. When I suddenly let off the throttle it backfires.
I tried power braking to see how it performs under load. I hold both pedals to the floor and the car refuses to go above 2000rpm and runs very rough. i can't even get a tire to spin.
I then tried road-testing it. From idle to 3500rpm it runs really rough and makes no power at all. In "D" under WOT it shifts out of first at 3500rpm. If I put it in "1" the car screams from 4000rpm-5000rpm. I think I have an ignition timing problem but am not sure.
Thanks, Dan
Just from reading this, I might suggest 2 things to get you going. First, check the wires to the coil. It sounds like they are reversed. The wire from the distributor goes to the negative side of the coil. Second, buy a timing light if you don't want to use the one you have. Good luck, Larry
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: mark7171]
#72910
06/13/08 01:10 PM
06/13/08 01:10 PM
cyphre666
Sounds like you have a job waiting for you. Top Fuel, Funny car, Prostock, Nascar. Good luck and will I will await to see you on the winning teams. I know it has gotten off the man's problem. So, I will not post on this subject anymore Quote:
[Re: cyphre666]
#72911
06/13/08 02:03 PM
06/13/08 02:03 PM
DaytonaTurbo
Manitoba, Canada
There is no good reason for the average person to set timing by ear. It may work, but why not have the peace of mind that your timing is set correct? Going by ear, you don't even know beyond a reasonable doubt that you're in the ball park. Even dial back timing lights are cheap enough on that auction site.
Secondly, after you've got the timing confirmed, check to make sure your plug wires are routed correctly. Supposedly there's two wires on BB mopars that are easy to mix up but will still run. Never happened to me, but I thought I'd throw it out there. How new are your plugs/wires/rotor/cap?
Next after you're sure it's not an ignition timing problem, try manually disconnecting the secondaries on the carb. If it still runs poor to 3500rpm, then I suspect you can have a jetting problem there.
Another thing, you say you have a mild cam in there, what's the specs on it? I have to ask because a 73 400 will have low CR pistons in it. Also, was the cam degreed at all during installation or did you just line up the dots?
[Re: DaytonaTurbo]
#72912
06/13/08 02:29 PM
06/13/08 02:29 PM
Posts: 27,728 places
79powerwagon
places
He's been posting for a month or two now about basically the same thing. He is young, broke, and inexperienced with these cars.
He isn't following the information provided due to a number of reasons that we cannot pin down (doesn't understand what we are saying?, won't get help?, lazy?, perhaps dyslexic?, not enough time to invest in the project?, whatever the reason is).
Somebody needs to spend a couple of hours with him and SHOW him the proper way to tune an engine. He'll do it once, from start to finish, and he'll remember it forever!
I can't do it, but who is close enough that they can?
[Re: 79powerwagon]
#72913
06/13/08 03:33 PM
06/13/08 03:33 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
bordin, If you are indeed young and inexperienced, that's not a big deal. Just add "and open to suggestions". You can set the timing by ear all day long, it means nothing, as was said. It does sound like you may have more than a simple timing issue, but that's an easy one to fix. The factory distributor will continue to advance way beyond 3000 rpm. In fact, it's barely coming in at that point. So ear timing is a load of BS. BEsides, the engine's not under any laod. How can you think that's the same as full throttle? That's like setting tire pressure by eye. Sure, you know it's got enough, but too much looks the same as just enough. If you have non performance parts in terms of ignition, then dont try using performance settings for specs. I suggest until you can learn, adn invest ina timing light, you pay a place to set the timing and carb for you. It will be less money that the fuel and misc crud you will start buying trying to fix a non issue.
[Re: BobR]
#72915
06/13/08 04:31 PM
06/13/08 04:31 PM
dogdays
with BobR and others, your timing is way advanced. You want, on a bigblock, 38 degrees of mechanical timing in by 3000 rpm. To those of you who persist in thinking every engine is different, you're wrong. I would have said the same thing about 10 years ago, but after studying countless engine buildups I have come to the firm belief that every combustion chamber has its own ignition timing characteristics. The mostly quiescent open chamber bigblock Mopar heads nearly always make max power with 38 degrees mechanical timing, add vacuum to get mileage at part throttle. Smallblock Mopar open chambers like 35-36 degrees, get some squish going and you can go down nearer to 30 degrees. Chevy Vortec heads, their 062 or 906 heads, make best power at 32 degrees. If you twisted the timing for maximum engine speed you probably set the timing where it would be with mechanical and vacuum advance and it would be around 55 degrees. That's WAY too much ignition lead. So, first get a decent timing light. A good inductive light is about $30. Then get the MP timing tape, costs like $6. Set mechanical timing at engine speed of 3000 rpm to 38 degrees BTDC with the vacuum advance disconnected and plugged. Then reconnect the vacuum advance and drive the car. It will run as it is supposed to. R.
[Re: dogdays]
#72918
06/13/08 04:48 PM
06/13/08 04:48 PM
Posts: 7,365 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
The one thing I don't understand about timing is this. The whole point of timing is to give the flame front enough time to travel accross the chamber so you get max burn just after TDC. Why then do you want the total timing to be completely in by 3000RPM? Shouldn't the timing continue to increase with RPM? The higher the RPM, the less time it takes the piston to reach TDC. If the timing stays the same above 3000RPM, isn't the air/fuel mixture igniting way after the piston reaches TDC.
[Re: 71383beep]
#72920
06/13/08 06:57 PM
06/13/08 06:57 PM
Posts: 842 Urbana, MD
bordin34
Urbana, MD
I did not try to do a burnout I tried putting a load on the engine to see how it would perform. I was trying to get in the ballpark on the timing. Now I know that I need to use a timing light. Gary, I think his name is 383beepbeep, generously came over for a couple hours trying to nail the problem before to no avail last time. It had a bad coil. The wires have less than a couple hundred miles on them and the rotor and cap look like new. The plugs also have about 100 miles on them. It has 69 primary jets and stock in the secondaries. And 71383bee "The truly sad part is that it sounds to me that another 3rd gen big block charger is being beat to death for no reason... Go buy a nova or something for crying out load." Hey, it's not your car I will do whatever I please to this one. If it goes against what you think is "correct" I simply don't care. It is just a car. This is my second 3rd gen Charger. I bought my first with my own money at 14 and this one with my own money at 15. Who cares if it is a big-block, it is also the most produced classic Charger EVER. Do you also feel you are better than me because you are not "beating your charger to death." People like you make young guys like me shy away from mopars. Usually older people embrace the young guys and try to teach them, you simply are not one of those good guys in this hobby. People like you make me and many others stay away from moparts, which is a valuable resource. Do you get your jollies off by insulting people and calling them stupid. You were young at one point if some [Edited by Moparts - Keep it clean] told you that you are wrecking your car what would you do? Like I said it is just a car. I hope that one day you will realize this. BTW great looking Superbee!
[Re: JohnRR]
#72921
06/13/08 07:15 PM
06/13/08 07:15 PM
must be cause thier all BLIND..yah..thats it.
[Re: 71383beep]
#72922
06/13/08 07:23 PM
06/13/08 07:23 PM
cyphre666
Let me get this straight...you set the timing by ear and then tested your car out by trying to do a burn out? I seem to recall this as your usual test method for troubleshooting.
Once again everybody has given good advice which will go nowhere and the usual excuses of, I'm too young, I'm too dumb, and My dad the mopar man said this will come
away man these posts are just turning into pure entertainment!
If you are not smart enough to set int. timing by ear, you need to go back to school. There is a point of load, no load and plain idle. If you think, I am referring to setting the timing going down the road at 3,000 RPM. go back to the stupid school from which you came from. I am just trying to help the guy, get some sort of initial timing. If you cannot comprehend this, go and drive your VW diesel. If you don't like that, well kiss me where the sun don't shine
[Re: cyphre666]
#72923
06/13/08 07:40 PM
06/13/08 07:40 PM
i for one understand your point BUT, sounds like this Kid is just learning, so timing it by ear is not the best way for him. The Best of the Best can do it, becouse thier familular with how there engine sounds/reacts. but they will still need to dial it in with a light, or take it down the 1/4 mile. But yah i agree, this kid has ALOT of problems with the car and should NOT be driving it. until its all sorted out. either that or go buy a NOVA
[Re: bordin34]
#72924
06/13/08 07:44 PM
06/13/08 07:44 PM
Posts: 3,333 MARYLAND
69Cuda340S
MARYLAND
Ok, get the light and set initial timing at 13 degrees advanced at idle with the vacuum disconnected. Degrease the vibration damper and put some timing tape on it so you can see what is going on. Also make sure you have 8 volts at the + side of the coil when then key is in the run position; check this with the engine off.
[Re: bordin34]
#72926
06/13/08 08:00 PM
06/13/08 08:00 PM
Posts: 8,165 Left Coast
BobR
Left Coast
Some time this week I will hook up my timing light and see what I find. Until then, I will be looking at Novas...
At least you have a sense of humor. Really, though, I would not try to fly a jet or have my wife do a tuneup on her Porsche. If you don't know the basics take some of your hard earned money and let someone tune it for you. Watch, if he will let you, and you will forever know. -Bob
[Re: bordin34]
#72927
06/13/08 08:09 PM
06/13/08 08:09 PM
Posts: 902 Seattle, WA
rss
Seattle, WA
Right on man!!! At least you've got a good sense of humor about it.
Keep at it and eventually you'll get it figured out and learn a bunch.
As some wise guy once said, "Experience is what you get when you don't get what you want."
[Re: 71383beep]
#72931
06/13/08 11:34 PM
06/13/08 11:34 PM
Bingo
I guess your a big meanie that's ruining the hobby for our precious youth just like me.
I could honestly care less about ruining the experience for this kid because from all of his posts he's barely smart enough to run a lawn mower.
Honestly just sell the car before you ruin a second one.
Ohh was that too harsh...reality bites man. You want someboddy to fix your car and wipe your [Edited by Moparts - Keep it clean] for you you are looking in the wrong place.
And don't label me as in inexperienced fool because I don't have the "old school wisdom" to time a motor by ear. Gimme a break this is laziness plain and simple. To hook up a timing light and check takes little to no effort...just common sense. An item seriously lacking here.
OK.... your a inexperienced fool because you don't have the "old school wisdom" to time a motor by ear. you've just been labeled
[Re: 79powerwagon]
#72932
06/13/08 11:46 PM
06/13/08 11:46 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Again, I have to throw out here, can someone in the know, and in the area, help this guy out so he can learn the right way to do these things?
Way too many things to check, and without the right tools you could spend days chasing what you think is a problem, only to find the problem is something else.
A long time ago, I spent a day messing with tuning the carburator on my friends '70 Challenger (because he insisted that must be the problem), just to find out his new "on-sale" sparkplug wires were junk! I finally convinced him to put his old spark plug wires back on as a "test", and the car ran great.
you could have a simular situation where you mess with the ignition system for a few days, then find out it might be a fuel system problem?
A dial-back timming light would make easy work figuring the ignition timming and advance. A digital multimeter could be used to check spark plug resistance, but a diagnostic scope would be even better. And with those tools you can get an idea if the ignition system is functioning correctly, and it may be fine leading you to trouble shoot other possabilities like the fuel system. Do you have good fuel pressure? A split or loose fuel line may not alaways leak fuel, but it could allow air to be sucked into the fuel system. I had this problem with the rubber line that connects the hard line to the gas tank pickup. This was a bear to figure out! Same with fuel lines that are partly plugged up, or gas tanks that do not vent correctly, and I'm just talking fuel delivery issues, not carburator tuning issues, thats another can of worms....
[Re: bordin34]
#72934
06/14/08 12:24 AM
06/14/08 12:24 AM
In regards to the man that offered me the timing light, I don't feel that I need it. I am going to use the one I have right now. I am sure somebody else could use it instead of me having two.
Bingo
You must feel like a big man now. OOO AHHH you can hide behind a computer screen and call a 16 year old stupid. I hope someday you need help and all some [Edited by Moparts - Keep it clean] does it mock and ridicule you for not having the god-given knowledge of knowing how to expertly tune an engine. You continue to mock me, yet you can't get your own engine running right. I do not need your so called "help" so just [Edited by Moparts - Keep it clean] off. The point of a forum like this is to share our hobby and aid each other in the fixing of our own car. You obviously have adopted the "holier than thou" mentality. There are many asses in this world and you are one of them. If you are going to Carlisle, I look forward to meeting you. I truly hope that you are an [Edited by Moparts - Keep it clean] to the wrong person one day and get the ever loving [Edited by Moparts - Keep it clean] beat out of you.
now thats inexperiance talking.. anyways, i still think you have a valvetrain problem (i posted that MONTHS ago). valves/lifters/pushrod/rocker one of those arn't up to snuff. i don't think timing is the problem ( i based this on what YOU say). but i cannot STRESS this enough.. KEEP ENGINE runtime to a bare MINIMUM, otherwise you WILL make things worse. tear off the valvecovers, check the rockers, pushrods, springs, etc. then report back. BTW, did you fix the brakes before you did the 5000rpm backfiring engine test drive ?
#72935
06/14/08 08:30 AM
06/14/08 08:30 AM
bordin34
Urbana, MD
I have removed the valvecovers and there was no play that I could find in the rockers. I will take them off again to make sure. There was however a little bit of side to side play in them. I did not fix the brakes yet, they stop fine for what I need them to. I have tried putting PB Blaster and vice grips on the bleeder to no avail.
[Re: bordin34]
#72937
06/14/08 09:27 AM
06/14/08 09:27 AM
79powerwagon
places
Side to side movement is normal on a stock rocker set up. Are all of your push rods "in their right place", meaning that they are in the cup designed to receive them? Some times they pop off... Here is a trick for your bleeders (though it's too late now that you've already used the vice-grips): use a 6 point deep well socket. If you use a metric one, it'll be a bit too tight (only a bit). Take a hammer and carefully drive it right onto the bleeder. NOW, use the ratchet handle and unscrew the bleeder, and take it to your parts store and buy new ones. Since brake parts are so cheap, I'd just get a set of new slave cylinders and calipers and install them, instead of trying to get ancient parts to work. These cars aren't difficult to work on, and they are simple technology compared to todays cars. Yes, there is a lot to understand, but if you can understand, you'll be that much further ahead in the long run! Remember, all cars were like this for the first 70+ years of cars, so many of the "older" folks do understand them, as one had too in order to use these as daily drivers back then. Since computer controls and EFI have come into play, most people are forgetting what it was like before that, and some younger people have never been exposed to this. Hang in there, you'll get it with some patience!
[Re: bordin34]
#72938
06/14/08 11:40 AM
06/14/08 11:40 AM
Posts: 5,161 CT
GTX MATT
CT
Some of these older guys think that they are the word of God in human form and that they could do no wrong. Take no offense. You are 100 % correct, many of these older guys look for something to blame on you because of your age. I see it all of the time. I get questioned all of the time about stupid crap because people assume that me being a young kid I dont know what im doing. I love the people that tell me that my car doesnt have a 273 in it because the smallest engine they made was a 318. Yeah sure. They forget that some of them were very capable of working on a car when they were a teen ager. I have friends that dont know enough about their own car to tune it correctly. Instead of telling them to sell it because they will never be able to do it I show them how. I think youre too far away from me but Id love to come take a look at your car. It has the electonic ignition, correct?
Sounds like an improperly timed engine, fouled plugs, a crossed wire, or maybe a combo of those three as well as possibly a poorly tuned carb. If you ignore these Mopar Police who are trying to make you go buy a Chevy (so that they could then complain about the Chevy tools with all of their chrome) you will get the correct information.
DO you have a good manual (like a Chiltons) to help you trouble shoot? Most trouble shooting stuff will be the same on alot of cars, but a manual is always nice for suggestions.
[Re: GTX MATT]
#72939
06/14/08 01:51 PM
06/14/08 01:51 PM
bordin34
Urbana, MD
The brake bleeder was stripped by some previous owner. I would hate to buy all calipers and MC because I couldn't get a bleeder out. The engine has NGK XR5 plugs in it with accel wires with less than 100 miles on them, but I did buy suppression core, I don't know why. I have a Haynes manual and a book titled "Automotive Mechanics: Seventh Edition" circa 1975. From looking at the rockers before I didn't notice the push rods not in the cup. I have no cam specs all the last owner said was it had a "mild cam." Edit-Also I don't think it was a valvetrain problem. When I thought I had a bad ballast I bypassed it with my old coil and the car ran like a champ. Then the rotor fried. It could be a combo of weak ignition and a bad tune.
[Re: bordin34]
#72940
06/14/08 02:26 PM
06/14/08 02:26 PM
Posts: 5,161 CT
GTX MATT
CT
Bypassing the resistor? That will burn your coil out. The first things Id invest in would be a new balast resistor and a coil.
[Re: bordin34]
#72942
06/14/08 04:07 PM
06/14/08 04:07 PM
Posts: 5,161 CT
GTX MATT
CT
Are the new coil and ballast resistor brand new from a parts store/catalog/internet vendor?
[Re: bordin34]
#72945
06/14/08 06:02 PM
06/14/08 06:02 PM
hmmmmm. not to sound crasp, but everytime somebody asks you the same question.. we get a different answer. perhaps after you try something, write it down, that way you can keep track of what your doing and stop chasing your own tail. you NEED to get yourself ORGANIZED.
#72946
06/14/08 08:39 PM
06/14/08 08:39 PM
bordin34
Urbana, MD
On Monday I will solder the leads back onto my voltmeter. Here is a list of this I have done stuff to. ECU -Put a known working one in, still ran the same -Made another ground with 2 12awg wires to the firewall Cap and Rotor -Replaced, still ran the same -I did not feel and excessive play Ballast -Put a known good one in, MSD 0.8ohm ran worse -Put old Standard one in ran the same -Bypassed, before screwing with timing, car ran great MSD Coil -Tried 4 different ballasts, backfired with all -Ran worst with MSD ballast -After checking all the ballasts I bypassed them OEM 30 year old coil -Car no longer backfired, made less power than usual -One day the car randomly would not rev above 2000rpm, so I fooled with the timing Plug Wires -Has Accel 8mm suppression core wires with less than 100 miles on them Plugs -Has NGK XR5 plugs with less than 100 miles -Replaced champions -Gapped at .35 Valvetrain -Visual inspection and pushing with hand showed nothing. -Some side to side play Ignition Timing -Really screwed up Carb -Float levels are correct -69 primaries -Stock secondaries -Holley 670cfm street avenger Distributor -30 year old stock unit
[Re: bordin34]
#72949
06/15/08 11:38 AM
06/15/08 11:38 AM
Posts: 1,586 Tampa, FL
tpabayflyer
Tampa, FL
Looks like an ignition problem to me. If it ran great with full power to the coil than I would say that rules out all other problems right????? Concentrate on why full power is not getting to the coil using the regular wiring and take it from there. TBF
[Re: bordin34]
#72952
06/16/08 07:38 AM
06/16/08 07:38 AM
79powerwagon
places
Today I hooked up my timing light and with the help of my uncle we got it in the correct area. It was way too far advanced. He thinks that a valve may be hanging up or burnt and there is a misfire as well as running rich. Tomorrow I will beck out the ignition system and look at the color of the spark.
Now yer talkin'!
Did you ever hook up the vacuum gauge and tell us what it read? If you do, in fact, have a burnt valve, it would show up on the vacuum gauge immediately.
[Re: 79powerwagon]
#72953
06/16/08 01:48 PM
06/16/08 01:48 PM
bordin34
Urbana, MD
Here is a video of the vacuum reading from when these series of problems first started in April. I no longer have the vacuum gauge as I borrowed it from my teacher and this is the last week of school. For the voltmeter it looks as if I need a pencil tip for my soldering iron or a new voltmeter. http://s80.photobucket.com/albums/j172/Charger34/?action=view¤t=PICT5756.flvEdit-I just checked my spark and directly from the coil the spark is a nice bright purple and I can move the wire about 1cm to 3/8" from the ground and it still sparks. Now I am going to check the spark from the distributor to plugs.
Re: Points or Elec. Ignition?
[Re: rdagw]
#72962
06/18/08 04:07 PM
06/18/08 04:07 PM
bordin34
Urbana, MD
Wow I just cleaned the spark plugs nearly all of them, except maybe 4, were fouled Its like I injected steroids into it. The power is mostly back. I am still bringing it to the sop on Monday to make sure though.
[Re: bordin34]
#72963
06/18/08 05:40 PM
06/18/08 05:40 PM
Posts: 992 Simi Valley, CA
MoparJ
Simi Valley, CA
Sounds like something in the cylinder heads or rings is causing the plugs to foul. Were the plugs oily? That compression test will tell all. It is more than likely in the head/s, especially if they were just put on.
Was the cam properly broken in and is the proper oil being used with a greater amount of zinc? Maybe a lobe is worn down.
You are on the right track and learning, so hang in there.
In regards to those who are immaturely badmouthing the op, back it down a click or two. This is a harder to find problem for someone learning and sometimes things are hard to figure out, even when explained. If it hurts the motor, it can be replaced, which isnt the ideal solution, but it can be done if it is shot. Remember, this is his car and NO ONE needs to tell him to drive something else. I was once a younger Mopar enthusiast (now 23) and went through similar learning processes when I was in my teens. I have great knowledge now and can fix many Mopar related problems and build motors myself. It took time and I feel good now, but still, no one is going to put down my knowledge or my cars and have it bother me. I simply ignore that arrogance, or combat it with my knowledge. Some individuals need to realize that being rude and unaccomadating is not very neighborly in a great Mopar community such as this. Lets respect each other hear and help out, regardless of the fact that it is sometimes difficult to get the message through to some individuals with issues.
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
[Re: bordin34]
#72965
06/18/08 07:06 PM
06/18/08 07:06 PM
MoparJ
Simi Valley, CA
The plugs were oil, while some were almost all oil/carbon, others were oil, carbon, with white on the ground strap. The motor was "rebuilt" by the last owner about 3000 miles ago I think. I don't trust the previous owner anymore though. I do not know if the cam was broken in properly but I did take apart the oil filter from 100 miles ago and it seemed fine.
Is it using any oil that you can tell, or is that normal? How many miles to one quart usage of oil? Seems like a valve issue to me. if you get some compression numbers, PM me or post them. I will try to divulge what you've got. The only other way plugs could be this fouled is not from firing much at all to burn off the oil, but for only the right side plugs to be like this is a bit suspicious.
[Re: MoparJ]
#72966
06/18/08 07:19 PM
06/18/08 07:19 PM
bordin34
Urbana, MD
Both sides had oily ones randomly thrown in. I have only driven this car 100 miles since I have owned it. On startup it burns oil for about 30 seconds, but not much then it goes away. I couldn't get a compression gauge today because of rain. Edit-Here is a picture of the best plug before cleaning, one had a sludge-like compound on some parts of it. I am running 15w-40 Rotella T with a bottle of STP blue stuff. Now I'm mad I didn't do the compression check while changing the plugs I used 7 different techniques to get all the plugs out and it takes about and hour and a half.
[Re: bordin34]
#72967
06/18/08 07:36 PM
06/18/08 07:36 PM
MoparJ
Simi Valley, CA
If its burning any oil on startup, something isnt right internally. Bad valve seals fouling the plugs would be my first guess, if not, poorly sealing rings. Is the smoke blue? Could also be a bad set of intake gaskets, but lets get the compression test first.
With a little time, we will get to the bottom of this.
[Re: bordin34]
#72969
06/18/08 08:47 PM
06/18/08 08:47 PM
Posts: 5,161 CT
GTX MATT
CT
Your plugs are probably carboned up like that from being too far advanced with the timing. When I advanced the timing on my GTX from its stock initial location at 6 degrees to 15 you could see the black smoke start to pour out of the pipes. Try putting it to stock for a while and it will probably clean the plugs up pretty good. Pull them after its run for a while and if they look good you should be good to go. It might be hard to burn all of the carbon off though.
[Re: bordin34]
#72975
06/19/08 09:07 AM
06/19/08 09:07 AM
79powerwagon
places
Hey there Bordin, please remember that it is very easy to blame a carb for engine problems. Most people think that way, actually. But 9 out of 10 times the carb is suspect, it's actually something else. You are on the right track. You have a wobbly vacuum gauge reading, which indicates a bad valve, and that is likely. The compression test will verify/deny the suspicion. Once you have the mechanical aspect of the engine in good shape, THEN you can start blaming ignition and carb for your issues, but the engine must be sound first and foremost. You're getting there!
[Re: 79powerwagon]
#72976
06/19/08 12:14 PM
06/19/08 12:14 PM
MoparJ
Simi Valley, CA
I agree. With the oily plugs and the backfiring through the carb, it sounds like either a major intake leak or a bad valve/s. I would almost wonder if the owner knew about this when he sold it to you and just cleaned the plugs before he sold it to you.
Mudslinging aside, you are getting close to a diagnosis.
[Re: bordin34]
#72978
06/19/08 01:18 PM
06/19/08 01:18 PM
MoparJ
Simi Valley, CA
I was definitely played when I bought the car. He said it had new brakes, rebuilt engine, a new interior with one seat needing recovering. All it had a was a very good interior. The brakes look like they could be original and the engine looks like a "new" set of heads and paint. The owner conveniently can't find the receipts. The car is very solid however.
No doubt the car is solid, but if it is just a new set of heads (if new) on a seasoned block with old rings and a bigger cam, then cylinder pressure may change and the rings may not be happy right now; or the heads. What is the oil pressure when hot at idle and cruise?
Also, is the smoke that you notice out of the tailpipes and is it blue? Does it only do it on startup, or does it last for a few moments. Some detail on that could be useful, or post a recording of the smoke. Are there any noises coming from the engine (ie knocks or clicks)?
[Re: bordin34]
#72980
06/19/08 02:01 PM
06/19/08 02:01 PM
bordin34
Urbana, MD
Ok, I just took a video of start-up. After I started it, I took it off fast-idle, revved it, then when it went back down to idle it stalled. The car usually smokes more on start-up. Edit-Here is another taken 10 seconds after start-up. There was blue smoke in the sun. Then as fast idle is automatically taken off, it stalls. A second or two before it stalled, the smoke went away. So that's about 20 seconds of smoke.
[Re: bordin34]
#72981
06/19/08 02:18 PM
06/19/08 02:18 PM
MoparJ
Simi Valley, CA
Hmmm, definately seems like bad valve seals or valve guides at the least. Did you see any hardened plastic remnants of the valve seals under the valve covers, or can you see the seals down the valve springs.
The problems is definately internal; either heads or rings. Definately not rebuilt, or at least a very poor one.
Another question is do you have proper ventilation, such a functional breather on one valve cover and a pcv on the other? Also, is there baffle plates underneath each of those on the underside of each valve cover?
[Re: MoparJ]
#72982
06/19/08 02:34 PM
06/19/08 02:34 PM
bordin34
Urbana, MD
I could not see any remnants. I just removed the driver side cover and didn't see anything. I have a breather and a PCV, but the PCV may be bad so I disconnected the hose and plugged it. The valve covers do have the baffles.I tried looking for the seals, but it looks like it has an inner and an outer valve spring and I can't even see the valve stem. I called the auto parts store and they wanted $46 for a compression tester, which seems high to me. So I will try to bum one off somebody.
[Re: bordin34]
#72983
06/19/08 02:46 PM
06/19/08 02:46 PM
79powerwagon
places
You need to have your PCV connected and working. It's a $2.00 part, get a new one, or wash out your old one with brake cleaner. You should hear the little ball inside rattle if you shake it. If not, it's stuck and should be cleaned. If you do, then hook it back up as it should be. You need to have this working, it's very essential. Here is what it does- while your engine operates, the oil in there gets hot and gives off vapors, vapors that form pressure. By bleeding that vapor pressure out of the engine internals, your engine will run as it was engineered to do. If that pressure builds up, it strains everything and you can blow seals and gaskets, and sometimes, much worse. The PCV system was engineered to burn these vapors and pressures, as opposed to letting them vent into the atmosphere (as was normal from about 1964 and earlier). OK, back to your issues now!
[Re: 79powerwagon]
#72984
06/19/08 02:56 PM
06/19/08 02:56 PM
MoparJ
Simi Valley, CA
This is absolutely correct. It is imperative to have this component. Get a good one and make sure it is working properly.
-Justin
[Re: 79powerwagon]
#72987
06/19/08 03:01 PM
06/19/08 03:01 PM
MoparJ
Simi Valley, CA
Give it a shake. If you hear the ball rattle, you're golden! If not, it's clogged (and defective). 3 second test!
Lol...exactly. Seems small, but this thing does wonders when it is functional. If it ran well with it plugged, check the hose running to the carb for cracks as well (possibly a vacuum leak).
-Justin
[Re: bordin34]
#72991
06/19/08 04:47 PM
06/19/08 04:47 PM
wow, this is getting ridiculous already. TIME TO TEAR INTO THE ENGINE. poppin through the exhaust, oil on the plugs, stalls, dies, takin it to 5000+rpm on a sick engine. TOLD YAH before, you're chasin your tail. park it, and fix it right.
[Re: bordin34]
#72992
06/19/08 04:48 PM
06/19/08 04:48 PM
MoparJ
Simi Valley, CA
I just took another test drive and all the car wants to do is die. The engine practically dies then I give it a touch of gas and it comes back to life in gear then when I let off the throttle it tries to die. Also, when I get on it the car really stumbles like somebody was playing with the ignition switch.
Now is the time that I would say hold backon driving it for now until the problem is solved. If it is a valve issue, you do not want to risk dropping one of them, especially with all of the backifiring going on.
#72993
06/19/08 04:55 PM
06/19/08 04:55 PM
MoparJ
Simi Valley, CA
In a kind sense, I would agree, but you can't fix anything until you diagnose. Just don't push it too hard. We had to get a little furthur though. At the very least, it looks like a valve job at best and possibly rings. It is time to find a shop to let them dissect it.
It is not completely ridiculous. He is young and inexperienced and trying to fix the damn thing, so give him a break. Remember, this will serve as good education to him in the future and he will get better. Constructive criticism is key.
[Re: MoparJ]
#72994
06/19/08 05:11 PM
06/19/08 05:11 PM
Dr. Phill in the house I see. anyways, the way i see it.. he's getting to many different responces here to be of any help, hence chasing his tail. IF he really wants to learn. get a good rebuild book, take your time and if your stumped.. ask here.
"DO OR DO NOT... THERE IS NO TRY!"~ yoda (wise green thing)
#72996
06/19/08 05:37 PM
06/19/08 05:37 PM
MoparJ
Simi Valley, CA
No Dr. Phil here; I cannot stand that hypocrit. Lmao. Cmon', if I wasn't level headed, I may have been insulted by that comment, but afterall, this is just a forum. Just trying to speak with a little reason and help him out,sir. I do agree with now being the time to take the thing to a REPUTABLE shop, since we have exhausted everything trying to help him out.
To the OP: Taking it to the shop is a good move. Good luck; it will soon be back on the road and healthy. Keep us updated. At the very least here, you learned a lot about the world of automotive troubleshooting.
[Re: MoparJ]
#72997
06/19/08 06:16 PM
06/19/08 06:16 PM
don't mis-interpret my sanctimonious, obtuse responces.. embrace them.
PS, good move bordin34
#72998
06/19/08 06:24 PM
06/19/08 06:24 PM
MoparJ
Simi Valley, CA
LOL.....hahaha, if you say so...
[Re: MoparJ]
#72999
06/19/08 06:37 PM
06/19/08 06:37 PM
i believe i just did...
#73000
06/19/08 06:39 PM
06/19/08 06:39 PM
MoparJ
Simi Valley, CA
ok
[Re: MoparJ]
#73001
06/19/08 11:42 PM
06/19/08 11:42 PM
Posts: 4,576 Sarcoxie, MO, USA
MoPar Jamie
Sarcoxie, MO, USA
One more thing to check, the Timing chain. If that sucker hasnt been replaced it probably has a mile of clearance right now. That can cause all sorts of problems and it can jump time. Not to mention the plastic breaks off the gear and can cause a clogged pickup tube. Is it backfiring out the exhaust or the carb?
Also when you crank it does it sound like R-R-R-REEER-R-R-REEER like it has a spot where it wants to spin faster for a moment? If it does that thats usually an indication that a valve is dropped. There is low ompression on that cylinder and the starter speeds up because of that.
- MoPar Jamie
1972 Fury III 4dr 1986 D-150 LWB Royal SE
