who's got 4.500 pistons? #728689
06/20/10 12:30 AM
06/20/10 12:30 AM
glendora, ca.
Deepockets Offline OP
glendora, ca.
i'm ready to order my pistons for my new build. who's got really nice pistons that you would recommend for a 4.150 stroke with 7.100 chevy rods. this will be for drag racing and maybe a trip around the block. i'm sure that i'll be ordering flat tops to acheive 12.1 comp. thanks for any sugestions
Re: who's got 4.500 pistons? [Re: Deepockets] #728690
06/20/10 04:51 AM
06/20/10 04:51 AM
K&Q va.
BIGBLOCK_KAT Offline
K&Q va.
I've got 4.5 bore pistons from J&E and Diamond with 7.100 rods one is a 4.5 stroke and the other a 4.25 stroke. Depends what you're trying to do. consult with the manufacturer.
Re: who's got 4.500 pistons? [Re: Deepockets] #728691
06/20/10 08:29 AM
06/20/10 08:29 AM
NC
440Jim Offline
440Jim  Offline
NC
With 4.150" stroke and 4.500" bore, I take it you will be using heads with around 84cc chambers to get that CR. Are you trying to make a pump gas motor? IMO, that CR is almost no-man's-land. Pretty high for pump gas, and not high enough to take advantage of running high octane fuel. If you are planning race fuel, consider more CR (mill the heads).
Re: who's got 4.500 pistons? [Re: 440Jim] #728692
06/20/10 10:59 AM
06/20/10 10:59 AM
glendora, ca.
glendora, ca.
i'm sure i'll be useing race gas mixed with premium. i know i really want to run more comp, if so i'll run all race gas. i've been doing that for quite some time allready. 3 gallons of 110 to 2 galllons of premium.
Re: who's got 4.500 pistons? [Re: Deepockets] #728693
06/20/10 11:50 AM
06/20/10 11:50 AM
AndyF Online content
AndyF  Online Content
Most anyone can provide those pistons. Diamond, JE, Wiseco, etc. I usually use Diamond for my engines but JE makes nice stuff also.
Re: who's got 4.500 pistons? [Re: AndyF] #728694
06/20/10 11:51 AM
06/20/10 11:51 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Dont forget CP, very nice parts.
Re: who's got 4.500 pistons? [Re: Al_Alguire] #728695
06/22/10 12:42 AM
06/22/10 12:42 AM
Somewhere Over the Hill
Mr. Dodge Offline
Mr. Dodge  Offline
I have JE's In my 588 Hemi.....
"The advantage of being armed the Americans possess over the people of all other nations,which are carried as far as the public resources will bear, the governments are afraid to trust the people with arms."(James Madison) 69 Hemi Coronet R/T 70 456 Dart Swinger
