hood pins #727264
06/18/10 01:02 AM
06/18/10 01:02 AM
Escondido CA.
mopar74 Offline OP
mopar74  Offline OP
Escondido CA.
Quick question What length hood pins for a 74 dodge Challenger? Thanks in advance.
Kevin
Re: hood pins [Re: mopar74] #727265
06/18/10 09:38 AM
06/18/10 09:38 AM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
It is up to personal preference, since the pins were never available on 72-74's. On my 73, the screws that attach the lanyards to the car are screwed into the radiator core support, and I'm using 22" lanyards. The length is perfect.
Your lanyard length is going to depend on where you attach the lanyard mounting screws. If you move the attachment points further forward, up near the the rubber hood bump stops, you will probably want 18" lanyards...
Re: hood pins [Re: mopar74] #727266
06/18/10 09:40 AM
06/18/10 09:40 AM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Kevin
I may have mis-read your question. Do you mean the pins, the clips, or the lanyards?
Re: hood pins [Re: 318 Stroker] #727267
06/18/10 05:32 PM
06/18/10 05:32 PM
Escondido CA.
mopar74 Offline OP
mopar74  Offline OP
Escondido CA.
the pins as in 3.5" 4" or 5" length
thanks for your input
Re: hood pins [Re: mopar74] #727268
06/18/10 05:39 PM
06/18/10 05:39 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
I didn't realize that there are different lengths on the posts. I'll look at the ones on my 73 tonight and let you know. I've bought two of the repro Mopar sets ovet the years and they both had the same stud length.
Re: hood pins [Re: 318 Stroker] #727269
06/18/10 08:36 PM
06/18/10 08:36 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Kevin, I measured mine, they are 4". The Mopar hood pin kit I bought shows instructions to use them on B & E bodies, so i'm guessing that the 4" was a universal length...
Re: hood pins [Re: 318 Stroker] #727270
06/18/10 09:45 PM
06/18/10 09:45 PM
Escondido CA.
mopar74 Offline OP
mopar74  Offline OP
Escondido CA.
Thank you very much 318stroker
