Hydraulic Roller Cams/Lifters for 340 - Drop-in?
#726638
06/17/10 01:47 PM
06/17/10 01:47 PM
Posts: 1,240 Saline, MI
efisixpack
Saline, MI
I have to pull the 340 out of my demon to replace the clutch and rear main seal (and to repaint block) and was going to go with a different cam while it was out. Is there a manufacturer that makes a hydraulic roller cam and lifters that are a drop-in application? I don't want to take the engine apart to modify it for a roller cam and will stick to a hydraulic flat tappet if necessary. The engine is an early 70's 340 block. I would really like to know what's out there though and what works from your experiences. Any help would be greatly appreciated!
When I die I want to go like my Grandfather did, quietly in his sleep. Not screaming like the passengers in his car.
Re: Hydraulic Roller Cams/Lifters for 340 - Drop-in?
[Re: efisixpack]
#726639
06/17/10 02:52 PM
06/17/10 02:52 PM
Posts: 576 Escondido, CA
kick_the_reverb
Escondido, CA
Last time I check there was none, but Hughes Engines had a news item about something like that coming out, the release date has come and gone, and no new announcment, so I guess it's not ready yet. Better call and ask them? Brian from IMM user IMM/OU812 has worked on something like that in the past, but IIRC it never materialized. Better check with him to make sure.
Please update on your findings (I don't like to call about stuff I am not ready to buy just yet). Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto Finally - disc brakes on the front. In the plans - rear disc brakes, B&M 250 blower
[Re: mopars4ever]
#726641
06/17/10 05:01 PM
06/17/10 05:01 PM
Posts: 1,894 N of Detroit
DaveDudek
N of Detroit
If you use the Crane hyd roller re-fit lifters the hyd roller cam is a drop in, no modifications are necessary. If your valve springs have enough pressure your good to go...
Dave Dudek 1st Factory Stock legal car in the 10`s!!! [/b] FAST & Factory Stock Rules: www.fastraces.org FAST 69 Hemi RR 9.98@139
[Re: DaveDudek]
#726643
06/17/10 06:03 PM
06/17/10 06:03 PM
DaveDudek
N of Detroit
Every block is a tad different of course...
[Re: JUST_N_TIME]
#726646
06/17/10 07:41 PM
06/17/10 07:41 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
We are working on a deal with a manufacturer to use same bodies as our Solid Rollers and same offset link bars. Brian
Brian Hafliger
[Re: Brian Hafliger]
#726647
06/17/10 09:04 PM
06/17/10 09:04 PM
efisixpack
Saline, MI
Guys, thanks for all the responses. First, Dave congrats on the incredible runs your car has made in the FAST series. Second, Brian do you have any idea when you would have those available if in fact you get the deal done? I'd prefer to work through a moparts member because I trust all of your judjement and real-life experience. Thanks again!!!
#726649
06/18/10 04:13 PM
06/18/10 04:13 PM
efisixpack
Saline, MI
Thanks Brian, please keep me posted on your progress. I'm definately interested.
[Re: scratchnfotraction]
#726651
06/19/10 03:55 PM
06/19/10 03:55 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Thank you! I've been working with another guy, but they are really draging their feet. So I found a california company that will possibly use the same linkbars/bodies that we use for solid rollers to make these hyd. rollers. We will try some I hope in a month or less. Same basic engine we did for CC, but hyd. roller lifters/cam, and maybe some porting on the RHS heads to see what's there. I will keep you guys posted. Brian
Brian Hafliger
[Re: Ron Silva]
#726653
06/19/10 05:44 PM
06/19/10 05:44 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Yep I can do that. Same thing as we're using for our EM engine this year but ours will be limited travel...would you like limited travel Ron?
Brian Hafliger
#726654
06/19/10 07:09 PM
06/19/10 07:09 PM
Posts: 1,880 USA
Ron Silva
USA
Well, Brian, I would like my valvetrain quiet and long lasting. And, these tappets in my 406 Mopar crate motor are probably production pieces and seem to work very well. I am not looking for that last 10 HP or that last 300 RPM. I want quiet reliability, but with consideration that I have a race cam. So, probably not because I do not intend to zero lash them or lightly preload them. I want enough preload to account for any wear. So at least 1/2 turn, maybe one turn.
The tappets we are supposed to be getting for this motor are supposed to be here any day now, but as usual there is promise after promise being broken probably just to keep us on the hook. They were supposedly being assymbled on Tuesday June 8th and then red labled to me. Sure seems like a long time to put 16 tappets together.
Right now, I will use whatever I can get. This is beyond pathetic.
SRT DEMON ONE SEAT
[Re: Ron Silva]
#726655
06/20/10 01:02 AM
06/20/10 01:02 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
That is why I'm going in a different direction. Glenn is a good guy, but they've been promising me lifters for months now. I need them yesterday for our project. I'm hoping this new deal goes quickly and the end product is what we want. I'll probably order 20 sets of them once I've tested them. Ron, I can get you a set within a couple of weeks but I can't test them before that. You may want to wait I don't know. These will drop right in like our solid rollers do, as well as oil the bearings and pushrod oil. I'll be using a set in a RHS headed build as soon as I get them but the engine will take a couple of weeks to get on the dyno from where I'm at right now. I don't like to sell stuff unless I've ran it and checked it out after it's run. I won't stock any of the 48° stuff, it'll be custom order only.
Brian Hafliger
