Re: 727 speedo gear housings?
[Re: AARCONV]
#72610
06/12/08 10:33 PM
06/12/08 10:33 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
I am not sure what you are calling a housing but the retainer that holds the gear in the tranny has marks on it for the differnet size gears. Install the retainer in the worng location and the gear will not mesh or it will not go in uness it is forced anf then it is damaged. I may be completely missing you question but I tried.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
[Re: AARCONV]
#72612
06/12/08 11:09 PM
06/12/08 11:09 PM
dfsmopars
Kentucky
There is a little raised mark on the tranny at the bottom of the hole. Line it up with the knotch on the retainer that coresponds with the number of teeth on you gear. If you have it right the gear and retainer will slip right in with no problem. It is funny because I replaced the gear in my 904 tonight. It is simple. I have done them in 727s as well.
[Re: AARCONV]
#72613
06/12/08 11:14 PM
06/12/08 11:14 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
...what's the chances of the rebuilt trans with no inside gear?...
zero
The gear that drives the plastic speedo gear is just a section of the outputshaft with teeth cut on it.
[Re: stumpy]
#72615
06/13/08 10:52 PM
06/13/08 10:52 PM
Posts: 5,193 NEW JERSEY
AARCONV
NEW JERSEY
if you bother to search a little.
a little snippy there stumpy? looks like u had a bad day... have a cold one on me buddy...
[Re: AARCONV]
#72618
06/14/08 09:38 PM
06/14/08 09:38 PM
RapidRobert
I had the plastic retainer & it didn't want to go in easily(& I had it aligned right) & later I had to change to the alum one to use a '66 dart cable to mate my 83 904 with my 65 dart speedo & teh alum one went right in easily. perfect fit.
