727 speedo gear housings? #72609
06/12/08 10:24 PM
06/12/08 10:24 PM
NEW JERSEY
AARCONV Offline OP
AARCONV  Offline OP
NEW JERSEY
on a small block 727a speedo gear housings...are there different types...like length,size etc...i swapped a speedo housing and gear from one trans to another and with out removing it to look further..i would like to know if there were different sizes..because now it dosn't work or spin while in gear...what's the chances of the rebuilt trans with no inside gear?...just want to ask before i get underneath and look...
Re: 727 speedo gear housings? [Re: AARCONV] #72610
06/12/08 10:33 PM
06/12/08 10:33 PM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
I am not sure what you are calling a housing but the retainer that holds the gear in the tranny has marks on it for the differnet size gears. Install the retainer in the worng location and the gear will not mesh or it will not go in uness it is forced anf then it is damaged. I may be completely missing you question but I tried.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: 727 speedo gear housings? [Re: dfsmopars] #72611
06/12/08 10:56 PM
06/12/08 10:56 PM
NEW JERSEY
AARCONV Offline OP
AARCONV  Offline OP
NEW JERSEY
i remember seeing different numbers on the housing...but which way do i point it to?
Re: 727 speedo gear housings? [Re: AARCONV] #72612
06/12/08 11:09 PM
06/12/08 11:09 PM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
There is a little raised mark on the tranny at the bottom of the hole. Line it up with the knotch on the retainer that coresponds with the number of teeth on you gear. If you have it right the gear and retainer will slip right in with no problem. It is funny because I replaced the gear in my 904 tonight. It is simple. I have done them in 727s as well.
Re: 727 speedo gear housings? [Re: AARCONV] #72613
06/12/08 11:14 PM
06/12/08 11:14 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
zero
The gear that drives the plastic speedo gear is just a section of the outputshaft with teeth cut on it.
Re: 727 speedo gear housings? [Re: dave571] #72614
06/12/08 11:36 PM
06/12/08 11:36 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
From the tech archives. The link is at the top of every page. A lot of good info if you bother to search a little. http://www.moparts.org/Tech/Archive/auto/21.html
Re: 727 speedo gear housings? [Re: stumpy] #72615
06/13/08 10:52 PM
06/13/08 10:52 PM
NEW JERSEY
AARCONV Offline OP
AARCONV  Offline OP
NEW JERSEY
a little snippy there stumpy?
looks like u had a bad day...
have a cold one on me buddy...
Re: 727 speedo gear housings? [Re: AARCONV] #72616
06/13/08 11:07 PM
06/13/08 11:07 PM
Rustylvania
Mr_fixit Offline
Mr_fixit  Offline
Rustylvania
Chances of no gear inside the trans, none. Chances you installed the speedo housing incorrectly, 100%.
Re: 727 speedo gear housings? [Re: Mr_fixit] #72617
06/14/08 09:04 PM
06/14/08 09:04 PM
NEW JERSEY
AARCONV Offline OP
AARCONV  Offline OP
NEW JERSEY
fixed...thanks..does make a little mess when removing....
Re: 727 speedo gear housings? [Re: AARCONV] #72618
06/14/08 09:38 PM
06/14/08 09:38 PM
I had the plastic retainer & it didn't want to go in easily(& I had it aligned right) & later I had to change to the alum one to use a '66 dart cable to mate my 83 904 with my 65 dart speedo & teh alum one went right in easily. perfect fit.
