Clutch??????? #72481
06/12/08 07:02 PM
06/12/08 07:02 PM
Prescott Az
73 SSP Offline OP
73 SSP  Offline OP
Prescott Az
Which Clutch do you recommend????? 72 Ply RR w/ 340 4spd daily driven
Re: Clutch??????? [Re: 73 SSP] #72482
06/12/08 08:37 PM
06/12/08 08:37 PM
Prescott Az
73 SSP Offline OP
73 SSP  Offline OP
Prescott Az
Please
Re: Clutch??????? [Re: 73 SSP] #72483
06/12/08 08:46 PM
06/12/08 08:46 PM
Idaho
Runner Offline
Runner  Offline
Idaho
im new to the 4 speed car stuff so i dont have ay good info, but i did put a 10.5 ram replacment clutch in my 68 383 roadrunner with 323 gears when i converted it to a 4 speed. it does a decent job, but it absolutly wont hold if i have a full tank of gas and 4 200 pound plus guys in the car and i do any spirited driving. i really wish i would have gone with something else now.
i emailed spec clutches and they recomended a spec stage 2 clutch. ive also thought about a centerforce. i know i wasnt much help sorry
Re: Clutch??????? [Re: Runner] #72484
06/12/08 08:54 PM
06/12/08 08:54 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
if its mainly a stock street driven car I have had great luck with LUK clutchs I have even put them in stock BB with good results
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Clutch??????? [Re: dusturbd340W5] #72485
06/12/08 09:05 PM
06/12/08 09:05 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I have always liked the Mcleod clutches.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Clutch??????? [Re: 70sixpkrt] #72486
06/12/08 09:21 PM
06/12/08 09:21 PM
kalispell montana
jwilson 61 Online happy
jwilson 61  Online Happy
kalispell montana
I vote Mcleod , great clutches
70 cuda 440 6bbl Auto with a dana 60
68 road runner QQ1 383 auto
1970 6 barrel 4 speed Superbird FY1 number matching
15 Challenger 6.4 SRT pearl White 6 Speed
72 Cuda 440 5 speed
71 Road Runner 440 4 speed
Re: Clutch??????? [Re: 73 SSP] #72487
06/12/08 09:53 PM
06/12/08 09:53 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
What RAM clutch did you get? I've got a PowerGrip HD in my Valiant behind a 300hp 340, and it works great. Plus, I've had good dealings with RAM's tech dept. The PG HD kit I got from Summit, and it engages smoothly and holds tight on my 3600# (with me) Valiant. Sticky tires ahd 3.23's out back.
Clair
Re: Clutch??????? [Re: Clair_Davis] #72488
06/12/08 11:12 PM
06/12/08 11:12 PM
Idaho
Runner Offline
Runner  Offline
Idaho
Clair
i just got the premium stock replacment clutch. the powergrip hd looks like it would be a much better clutch.
Re: Clutch??????? [Re: Runner] #72489
06/13/08 01:07 AM
06/13/08 01:07 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
I just put a ram power grip in my barracuda 440-6 car, It has no issues and is taking a good beating a few times already. But 450 bucks
Re: Clutch??????? [Re: Mopar-Al] #72490
06/13/08 03:19 AM
06/13/08 03:19 AM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
I started with a Ram Power Grip in my 83 Ram w/360, always held good but was a bit touchy on starts with a heavy trailer behind. Recently put in a Centerforce DF and very happy so far, much smoother on loaded starts is the big issue, also seems to hold just great - never did make either of them slip.
Mike
Re: Clutch??????? [Re: 1E2C] #72491
06/13/08 11:28 AM
06/13/08 11:28 AM
Prescott Az
73 SSP Offline OP
73 SSP  Offline OP
Prescott Az
anyone know about zoom clutches
Re: Clutch??????? [Re: 73 SSP] #72492
06/13/08 11:35 AM
06/13/08 11:35 AM
Eastern North Carolina
cyphre666 Offline
cyphre666  Offline
Really test my memory here,
I had a 440+6 in a 67 Coronet.
I think it was the Zoom Purple clutch.
Never a problem, do they make them anymore ?
Did ya have the flywheel resurfaced ?
Maybe not disc at all, maybe not enough of a pressure plate.
Re: Clutch??????? [Re: cyphre666] #72493
06/13/08 12:00 PM
06/13/08 12:00 PM
Prescott Az
73 SSP Offline OP
73 SSP  Offline OP
Prescott Az
OOOhhhhh I had plenty of pressure plate the flywheel has to be resurfaced or heaven forbid replaced as the exotic friction plate did a number on it. I was running a copper-ceramic plate done by az brake and clutch.
Re: Clutch??????? [Re: 73 SSP] #72494
06/13/08 09:27 PM
06/13/08 09:27 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Give Jamie Passon a call on a good Mcleod clutch.I have always used Mcleod clutches and they have always delivered great performance.
Gus
64 Plymouth Savoy
Dana 60
Re: Clutch??????? [Re: fourgearsavoy] #72495
06/13/08 09:46 PM
06/13/08 09:46 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
mcleod single disc semi metallic w/ belvelle finger style plate. should hold and last.
tghe semi metallic will allow many launches as it is softer material.
