Re: TOTAL ADVANCE-WHAT RPM [Re: cudaboone] #724803
06/30/10 04:15 PM
06/30/10 04:15 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
Contact the company. Msd can get you a better answer.
Nice going. 22 and the limiter should make 32. Don, can get the car in top shape.
Re: TOTAL ADVANCE-WHAT RPM [Re: mark7171] #724804
10/17/10 11:19 AM
10/17/10 11:19 AM
Maryland
cudaboone Offline OP
Maryland
Finally installed that MSD starter saver. Sure turns over easy. Also noticed that it sounds a lot tamer when it kicks over.
Re: TOTAL ADVANCE-WHAT RPM [Re: cudaboone] #724805
10/17/10 03:06 PM
10/17/10 03:06 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Great job on getting the right parts and installing them yourself. You should notice a nice performance and drivability improvement. You've taken the right path.
Now, you can adjust your carburator's air fuel screws to match them to your new timing and enjoy your ride. If you're still getting a gas knock, you can add some 110 octane race gas until it goes away. Start with 2 gallons a tank. It's cheap insurance.
