Page 6 of 19 1 2 4 5 6 7 8 18 19
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: Pat_Whalen] #723598
06/28/10 09:37 PM
06/28/10 09:37 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Well finally got my other wire.Putting it on radiator tomorrow.Weather going to be 85.Will see or should i say feel what happens with the temp.I have a 180 themostat in it.Chamipon 3 core alum radiator.HHr fan.Pulling rad out and hooking mercedes fan and radiator on the bench.Then back into the gtx.I need to learn how to post a video.
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: gtx69] #723599
06/28/10 11:54 PM
06/28/10 11:54 PM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
Hey feets. Was just looking at your pictures again of the circuitry. I was wondering if you could tell me if there were a series of transistors underneither that board. There appear to be some resistor heads sticking out right around the 6 o'clock position, a little off to the right and left. Is that the case?
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: Pat_Whalen] #723600
06/29/10 08:59 AM
06/29/10 08:59 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
The board is secured to the base. I can't remove it without being destructive. There are a few pins poking through the board. Some round clips were pressed in then covered with epoxy to guarantee nothing moves.
There are a few black square components under the board that appear to have been epoxied to the case as well.
They really didn't want this thing to be opened up.
- Stu Harmon
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: feets] #723601
06/29/10 09:30 AM
06/29/10 09:30 AM
i muust have missed some info. you need the plastic plug, 2 heavy wires and 1 small wire. i only see 2 parts bags with numbers. which part # goes with which item(s)?
Re: Monster electric cooling fan upgrade. long. w/photos. #723602
06/29/10 10:28 AM
06/29/10 10:28 AM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
What are you using for an alternator? How many amps?
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: Kam*Kuda] #723603
06/29/10 11:34 AM
06/29/10 11:34 AM
gtx69 Offline
super gas
gtx69  Offline
super gas
000 540 38 05 small lead wire need one
000 540 36 05 heavy wire need two
220 545 03 29 pin bushing housing need one
Re: Monster electric cooling fan upgrade. long. w/photos. #723604
06/29/10 11:46 AM
06/29/10 11:46 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
We had the little wire in stock so I didn't get it in the bag. Gtx69 listed the correct numbers. I also posted them in the thread.
I'm running one of the 130 amp Denso alternators. You can upgrade the factory style alternators too. It's quick and easy. You can read about it half way down this page: http://www.allpar.com/history/mopar/electrical.html
- Stu Harmon
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: feets] #723605
06/29/10 12:13 PM
06/29/10 12:13 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Hey Feets... here is an FYI...
I have an 86 Mustang SVO that we recently did some mods to.. larger turbo, 4 into 1 header, 3" downpipe and etc..
When we first fired it up, the temps coming off the exhaust was incredibly hot.. 1100+ degrees off the header, 800+ off the downpipe..
We ended up having the header, turbo exhaust housing and downpipe ceramic coated and it made a world of difference regarding the under hood temp..
The ceramic coating not only looks better, but it was cheap too.. less than $200 for everything... well worth the money spent..
BTW.. thanks for the write up on the fan, when and if the HHR fan craps out, I will be re-reading this thread..
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: Jeepmon] #723606
06/29/10 12:20 PM
06/29/10 12:20 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I've often thought about ceramic coating my stuff. 10 years ago the coatings were stupid expensive and would not stick to turbos.
Now, it's more cost effective and durable. My manifolds are showing their age. If I clean them up or make new ones I'll have them coated.
- Stu Harmon
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: feets] #723607
06/29/10 01:19 PM
06/29/10 01:19 PM
San Antonio Texas
68 R/T Offline
68 R/T  Offline
San Antonio Texas
Would a 80 amp alt be enough to pull this fan. Thanks
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: 68 R/T] #723608
06/29/10 01:23 PM
06/29/10 01:23 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
I'll be running an 80 amp 50amps at startup. 39 ruinning. 40 amps to spare for other things
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: gtx69] #723609
06/29/10 01:34 PM
06/29/10 01:34 PM
San Antonio Texas
68 R/T Offline
68 R/T  Offline
San Antonio Texas
Thanks, now I can order everything to get this 493 stroker kooled down.
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: 68 R/T] #723610
06/29/10 03:36 PM
06/29/10 03:36 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Are you trying to tell me that it gets warm in San Antonio? If it wasn't for the river that place would be a desert.
I imagine one of these fans would do the trick.
- Stu Harmon
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: gtx69] #723611
06/30/10 04:05 PM
06/30/10 04:05 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Any update? Didja get it installed?
- Stu Harmon
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: feets] #723612
06/30/10 04:42 PM
06/30/10 04:42 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Had a oil leak been working on that.Will be doing fan tonight.
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: Andrewh] #723613
06/30/10 07:47 PM
06/30/10 07:47 PM
HAMILTON,ONTARIO,CANADA
RED73RALLYE Offline
RED73RALLYE  Offline
IS YOU MAGNUM IN YOUR CAR A FUELLY?
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: RED73RALLYE] #723614
06/30/10 11:20 PM
06/30/10 11:20 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Andrewh has a prototype (and stillborn project) Painless Performance EFI system. It's taken some tuning just like any other EFI setup but it runs great and gets really good mileage. There's plenty of get up and go in that 5.9 too.
- Stu Harmon
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: feets] #723615
07/02/10 01:46 PM
07/02/10 01:46 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Finally got fan mounted to radiator.The First one is of the hhr fan mounted which i replaced.
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: gtx69] #723616
07/02/10 01:47 PM
07/02/10 01:47 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
hhr fan again
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: gtx69] #723617
07/02/10 01:48 PM
07/02/10 01:48 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Mercedes fan
