stock stroke 440's #723460
06/13/10 09:33 PM
06/13/10 09:33 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
hey guy's can y'all post your 3.75 stroke 440 combo's and how fast..........thanks
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: stock stroke 440's [Re: 67mprfan] #723461
06/13/10 09:55 PM
06/13/10 09:55 PM
tboomer Offline
tboomer  Offline
Re: stock stroke 440's [Re: tboomer] #723462
06/13/10 10:10 PM
06/13/10 10:10 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Mine
72 440 block bored .030 decked so pistons are .010 in the hole
Wiesco Pro Tru pistons 12.05-1 compression
K1 rods
Facotry forged crank balanced.
Cam
Comp cams Magnum series
Duration at .050" Lift 262 int./262 exh
Actual lift using 1.6 intake and 1.5 exh 578 int and 555 exh.
Installed at 108.5*'s
Edelbrock heads
Milled to .064 cc chambers
Hand ported By Scott Koffel
Flow data.....
Lift/int/exh
.100/83.05/69.55
.200/161.46/113.46
.300/230.23/143.98
.400/280.46/178.41
.500/312.75/200.32
.600/317.25/214.40
.700/319.50/222.23
.800/319.50/228.49
Team G intake worked and matched to heads
APD built 950HP alky carb
2 1/8 hooker SC w/ 3.5 collectors
MSD dist W/ Fircore 50's
Not really sure how fast it can push the Blue Beast though as we had some issues earlier this season.
Hope to find out soon
Re: stock stroke 440's [Re: 67mprfan] #723463
06/13/10 10:53 PM
06/13/10 10:53 PM
Adrian, Mi
P
pro6pakRR Offline
mopar addict
pro6pakRR  Offline
mopar addict
P
Adrian, Mi
Mine
71 stock 440 block,SLP 11-1 piston's,stock steel crank,eagle H beam rod's,mopar 557 cam,out of the box Edelbrocks RPM'S,1.6 crane gold roller rockers,6pack with 500cfm carb in center,out boards have jet's installed,PTC 8in convertor,4.10 gears,car weight 3800lbs best [Email]11.53@117[/Email] Changeing a few thing's this year,up date's later.
Re: stock stroke 440's [Re: pro6pakRR] #723464
06/13/10 11:31 PM
06/13/10 11:31 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
Thankx tboomer that was the thread i was lookin 4.........keep the post coming guy's
Re: stock stroke 440's [Re: tboomer] #723465
06/13/10 11:47 PM
06/13/10 11:47 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Re: stock stroke 440's [Re: BradH] #723466
06/13/10 11:56 PM
06/13/10 11:56 PM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
.030 over
pistons .050 in the hole
flat top's
MP .528 solid 1.5 crane rollers
915 head's w/ max wedge port "very questionable area of my combo "
950 ProForm carb
Torker intake w/ 2" open spacer
car probably weigh's 3250-3350 w/ me
4.30 gear has ran a best of 11.139@117.??
Andrew Brough D372 1969 Dodge Dart GTS 1.43 60'best 6.82 1/8 98mph "the light came on and I ran out of talent"
Re: stock stroke 440's [Re: BradH] #723467
06/13/10 11:57 PM
06/13/10 11:57 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
.030 over 440
TRW flat tops .020 out of the deck
LY rods
Stock crank
Crane roller (280@.050/.670 lift)
260 cfm 906 heads
M1
Stock 1050 Dom
2 1/8 Headers
Not exactly the best matched combo...LOL!
The rest was the "usual": back half, ladders/coils, 14x32's, 8" converter, etc...
3250 lbs, best of 10.38 @ 128
Re: stock stroke 440's [Re: cudadoug] #723468
06/14/10 12:15 AM
06/14/10 12:15 AM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
anyone use srp piston and if so how do you like them good or bad was looking at a set of them
Re: stock stroke 440's [Re: 67mprfan] #723469
06/15/10 01:26 AM
06/15/10 01:26 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
.030 over 440 with all stock bottom end other then KB pistons.
906 heads I home ported that are 10.0 comp with the KB quench pad pistons.
MP .557 solid cam and Comp dual valve springs.
Holley Street Dominator intake with 850 DP.
Mallory dist and orange MP ECU.
Hedman 1-3/4 tube headers and 3" pipes.
This is in my 63 Sport Fury with 4.30's and a Dynamic 9.5 convertor using 30 x 9 tires. At just over 3700 lbs and street driven all the time its best is 11.49 @ 116.
Nothing fancy but a nice solid low buck 92 pump gas 11 second street driver. Ron
Re: stock stroke 440's [Re: 67mprfan] #723470
06/15/10 02:39 AM
06/15/10 02:39 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
i have the SRP,s in my 440 + 0.055
1978 block,stock rods,eagle stock stroke crank.stealth heads,pocket ported,78cc chamber - 10.78ish comp.M1 single plane,825 mighty demon
3.9 gears in a strange dana,tf727,dynamic 9 1/2 converter.flashes to 5000 according to the tach.
best of 11.332@118.25.
All with a purple 509 cam
1968 Satellite,about 3726lbs with driver
Oh and this is my daily driver
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: stock stroke 440's [Re: tex013] #723471
06/15/10 07:40 AM
06/15/10 07:40 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
HillBilly Conquest in this board has been 5.40's in the 8th mile all motor with a stock block and crank.
Re: stock stroke 440's [Re: Bob_Coomer] #723472
06/15/10 08:01 AM
06/15/10 08:01 AM
NJ
440challenger Offline
NJ
Fun street combo i been running in my challenger for six years.
446
cast crank
cat rods
ross 82008's
eddys @ 77cc chambers
mp 557 soild
crane 1.5s
eddy perf rpm
950 holley
1 7/8 headers
3.91s
3900 lbs
11.36 with more to go
Re: stock stroke 440's [Re: 67mprfan] #723473
06/15/10 08:18 AM
06/15/10 08:18 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
we had a 448 in the duster that went as quick as 9.95 at 3300 lbs..
440- .040 over
stage VI heads (non MW)
mopar .557 cam
crane 1.52 roller rockers
Ross 12.5 pistons
stock steel crank
LY rods
all assemblies balanced
Edlebrock intake w/spacers
1050 Dominator
was shifted at 6600-6800
kept throwing stock rods...its how we got it
was a rev happy little guy
Re: stock stroke 440's [Re: smokinwoody] #723474
06/15/10 12:38 PM
06/15/10 12:38 PM
Ohio
rck850 Offline
rck850  Offline
Ohio
I have the SRP's in a .030 over 440. one question are they a zero deck piston. I didn't build the motor but all the online calculators say it will be at zero deck. My combo is a low 12 in my 73 duster, 528 cam, 3.73, stock 906 heads.
Re: stock stroke 440's [Re: 67mprfan] #723475
06/15/10 07:27 PM
06/15/10 07:27 PM
Chattanooga,Tn
Mopar Racer Offline
Mopar Racer  Offline
Chattanooga,Tn
I had a stock stroke 440 that was a runner before the crankshaft broke..030 over/Ross flat tops.Manley H beam rods.Milodon windage tray & 7 quart low profile pan.Edelbrock RPM's ported by Todd Marsh at Marsh Performance.305 @.700 on intake/ 245 @.700 on Exhaust.Milled to 73 cc chamber.Piston down .014 in the hole.11.16 to 1 compression.Comp solid lift cam.Profiled by Todd Marsh..600 lift on intake and exhaust.269@.050 on Intake.273@.050 on Exhaust.Victor 440 intake.825 cfm Demon carb.1 7/8 TTi headers.727 T.F.with PTC 8 inch. Dana 60 w/4.56's.13x31 phoenix slicks.1966 Dodge Coronet 3,250 lbs. full of fuel and no driver.Steele,Al dragway best time.Fall weather,50 degrees,sunny,low humidity.230 lb. driver=6.62 @102 mph with 1.42 60 ft.eighth mile/footbraking.
Re: stock stroke 440's [Re: 67mprfan] #723476
06/15/10 07:30 PM
06/15/10 07:30 PM
BradH Offline
BradH  Offline
I don't like pistons w/ symmetrical valve reliefs (SRP, Wiseco Pro Tru, Probe). IMO the KB / Icon forged stuff is a better choice for the $$$.
Re: stock stroke 440's [Re: Mopar Racer] #723477
06/15/10 07:35 PM
06/15/10 07:35 PM
BradH Offline
BradH  Offline
An OEM crank? How many runs on it before it let go?
Re: stock stroke 440's [Re: 67mprfan] #723478
06/15/10 07:59 PM
06/15/10 07:59 PM
BradH Offline
BradH  Offline
Let's see if I can do this w/o turning it into a novel-ette:
- 440 w/ Ross f-t pistons, Eagle rods & OEM crank, 452 c.i.
- MP Stage VI heads (305/235 @ .600"), Victor intake, BG 825 carb, 10.8 CR
- Comp XX 266 @ .050" x .600" solid on 108 LSA
- TTI 2" headers w/ full 3" x-pipe system
- 3750# E-body (w/ driver), 4.10s, 9.5" Dynamic
- 10.5s @ 126 MPH w/ 1.45 60-ft
Re: stock stroke 440's [Re: BradH] #723479
06/15/10 08:08 PM
06/15/10 08:08 PM
ny
greenmcode Offline
greenmcode  Offline
ny
This is my stock stroke 440-6..
[image][/image]
1969 A12 R.R. 11.61 117.96 F.A.S.T. STOCK STROKE..
