Re: stock stroke 440's
[Re: tboomer]
#723462
06/13/10 10:10 PM
06/13/10 10:10 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Mine
72 440 block bored .030 decked so pistons are .010 in the hole Wiesco Pro Tru pistons 12.05-1 compression K1 rods Facotry forged crank balanced.
Cam Comp cams Magnum series Duration at .050" Lift 262 int./262 exh Actual lift using 1.6 intake and 1.5 exh 578 int and 555 exh. Installed at 108.5*'s
Edelbrock heads Milled to .064 cc chambers Hand ported By Scott Koffel Flow data.....
Lift/int/exh .100/83.05/69.55 .200/161.46/113.46 .300/230.23/143.98 .400/280.46/178.41 .500/312.75/200.32 .600/317.25/214.40 .700/319.50/222.23 .800/319.50/228.49
Team G intake worked and matched to heads
APD built 950HP alky carb
2 1/8 hooker SC w/ 3.5 collectors
MSD dist W/ Fircore 50's
Not really sure how fast it can push the Blue Beast though as we had some issues earlier this season.
Hope to find out soon
[Re: 67mprfan]
#723463
06/13/10 10:53 PM
06/13/10 10:53 PM
Posts: 1,153 Adrian, Mi
pro6pakRR
mopar addict
mopar addict
Adrian, Mi
Mine
71 stock 440 block,SLP 11-1 piston's,stock steel crank,eagle H beam rod's,mopar 557 cam,out of the box Edelbrocks RPM'S,1.6 crane gold roller rockers,6pack with 500cfm carb in center,out boards have jet's installed,PTC 8in convertor,4.10 gears,car weight 3800lbs best [Email]11.53@117[/Email] Changeing a few thing's this year,up date's later.
[Re: BradH]
#723466
06/13/10 11:56 PM
06/13/10 11:56 PM
Posts: 637 Kokomo,IN
StripeHOG
Kokomo,IN
.030 over pistons .050 in the hole flat top's MP .528 solid 1.5 crane rollers 915 head's w/ max wedge port "very questionable area of my combo " 950 ProForm carb Torker intake w/ 2" open spacer car probably weigh's 3250-3350 w/ me 4.30 gear has ran a best of 11.139@117.??
Andrew Brough D372
1969 Dodge Dart GTS
1.43 60'best
6.82 1/8 98mph
"the light came on and I ran out of talent"
[Re: 67mprfan]
#723469
06/15/10 01:26 AM
06/15/10 01:26 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
.030 over 440 with all stock bottom end other then KB pistons. 906 heads I home ported that are 10.0 comp with the KB quench pad pistons. MP .557 solid cam and Comp dual valve springs. Holley Street Dominator intake with 850 DP. Mallory dist and orange MP ECU. Hedman 1-3/4 tube headers and 3" pipes. This is in my 63 Sport Fury with 4.30's and a Dynamic 9.5 convertor using 30 x 9 tires. At just over 3700 lbs and street driven all the time its best is 11.49 @ 116. Nothing fancy but a nice solid low buck 92 pump gas 11 second street driver. Ron
[Re: 67mprfan]
#723470
06/15/10 02:39 AM
06/15/10 02:39 AM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
i have the SRP,s in my 440 + 0.055 1978 block,stock rods,eagle stock stroke crank.stealth heads,pocket ported,78cc chamber - 10.78ish comp.M1 single plane,825 mighty demon 3.9 gears in a strange dana,tf727,dynamic 9 1/2 converter.flashes to 5000 according to the tach. best of 11.332@118.25.All with a purple 509 cam 1968 Satellite,about 3726lbs with driver Oh and this is my daily driver Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#723471
06/15/10 07:40 AM
06/15/10 07:40 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
HillBilly Conquest in this board has been 5.40's in the 8th mile all motor with a stock block and crank.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: 67mprfan]
#723475
06/15/10 07:27 PM
06/15/10 07:27 PM
Posts: 13 Chattanooga,Tn
Mopar Racer
Chattanooga,Tn
I had a stock stroke 440 that was a runner before the crankshaft broke..030 over/Ross flat tops.Manley H beam rods.Milodon windage tray & 7 quart low profile pan.Edelbrock RPM's ported by Todd Marsh at Marsh Performance.305 @.700 on intake/ 245 @.700 on Exhaust.Milled to 73 cc chamber.Piston down .014 in the hole.11.16 to 1 compression.Comp solid lift cam.Profiled by Todd Marsh..600 lift on intake and exhaust.269@.050 on Intake.273@.050 on Exhaust.Victor 440 intake.825 cfm Demon carb.1 7/8 TTi headers.727 T.F.with PTC 8 inch. Dana 60 w/4.56's.13x31 phoenix slicks.1966 Dodge Coronet 3,250 lbs. full of fuel and no driver.Steele,Al dragway best time.Fall weather,50 degrees,sunny,low humidity.230 lb. driver=6.62 @102 mph with 1.42 60 ft.eighth mile/footbraking.
[Re: 67mprfan]
#723476
06/15/10 07:30 PM
06/15/10 07:30 PM
BradH
anyone use srp piston and if so how do you like them good or bad was looking at a set of them
I don't like pistons w/ symmetrical valve reliefs (SRP, Wiseco Pro Tru, Probe). IMO the KB / Icon forged stuff is a better choice for the $$$.
[Re: Mopar Racer]
#723477
06/15/10 07:35 PM
06/15/10 07:35 PM
BradH
An OEM crank? How many runs on it before it let go?
[Re: 67mprfan]
#723478
06/15/10 07:59 PM
06/15/10 07:59 PM
BradH
Let's see if I can do this w/o turning it into a novel-ette: - 440 w/ Ross f-t pistons, Eagle rods & OEM crank, 452 c.i. - MP Stage VI heads (305/235 @ .600"), Victor intake, BG 825 carb, 10.8 CR - Comp XX 266 @ .050" x .600" solid on 108 LSA - TTI 2" headers w/ full 3" x-pipe system - 3750# E-body (w/ driver), 4.10s, 9.5" Dynamic - 10.5s @ 126 MPH w/ 1.45 60-ft
[Re: BradH]
#723479
06/15/10 08:08 PM
06/15/10 08:08 PM
Posts: 518 ny
greenmcode
ny
This is my stock stroke 440-6.. [image] [/image]
1969 A12 R.R. 11.61 117.96 F.A.S.T. STOCK STROKE..
