Trailer cleaning, Simply Awesome or Totally Awesome? #721690
06/11/10 06:04 PM
06/11/10 06:04 PM
Cab_Burge Offline OP
I went to the local dollar store looking for some cleaning solution that I had read about on here several weeks ago, I should have done a search before going I bought some stuff called Totally Awesome, with bleach. Is this the same stuff as Simply Awesome or , if not, has anyone used this stuff on the sides of the enclosed traikers to remove streaks?
Re: Trailer cleaning, Simply Awesome or Totally Awesome? [Re: Cab_Burge] #721691
06/11/10 06:24 PM
06/11/10 06:24 PM
Lehigh Acres, Florida
rickstershemi Offline
Totally Awesome is all I will use on my enclosed....great stuff
Rickster
Re: Trailer cleaning, Simply Awesome or Totally Awesome? [Re: Cab_Burge] #721692
06/11/10 06:30 PM
06/11/10 06:30 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
LA,s "Totally Awesome"!
Be Carefull with it, at Full strength it will dissolve your paint making its own streaks.
Its recommended to dillute it. Ive used it full strength but had someone right beside me to rinse it off imediately after I scrubbed it clean to my liking. mike
Great Stuff!!, Ah I mean "Totally Awesome" mike
Re: Trailer cleaning, Simply Awesome or Totally Awesome? [Re: Cab_Burge] #721693
06/11/10 08:02 PM
06/11/10 08:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Totally Awesome .... works great.... use it full strength
but dont let it dry on you before you get it wiped off,
you will see the procedure when you get started... I
would do areas in a 2' wide starting at the top and
work down then move over and back to the top... it
works fast so dont dilly dally .... also I never used
the stuff with bleach
Re: Trailer cleaning, Simply Awesome or Totally Awesome? [Re: MR_P_BODY] #721694
06/11/10 09:14 PM
06/11/10 09:14 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Yeah...I picked up on this also several weeks ago and bought some LA Totally Awesome.... great stuff for motorhomes and trailers[white]. i used a soft brush on a stick and used it 50/50. What worked well was and old Windex Outdoor bottle with the built in nozzle[off...rinse...clean] at 50/50. Squirt it on brush it around....rinse. Tough to find some stuff that impresses these days.
The little old lady from Pasadena is back!
Re: Trailer cleaning, Simply Awesome or Totally Awesome? [Re: MR_P_BODY] #721695
06/11/10 09:59 PM
06/11/10 09:59 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
it
So dont Dilly Dally... Cabby, with it!
also I never used
the stuff with bleach.
Me neither, mike
Re: Trailer cleaning, Simply Awesome or Totally Awesome? [Re: Sport440] #721696
06/11/10 11:08 PM
06/11/10 11:08 PM
Adrian, Mi
P
pro6pakRR Offline
mopar addict
pro6pakRR  Offline
mopar addict
P
Adrian, Mi
Been using that for year's. It will clean all most any thing
Re: Trailer cleaning, Simply Awesome or Totally Awesome? [Re: pro6pakRR] #721697
06/11/10 11:48 PM
06/11/10 11:48 PM
Tampa Fl
K
kens avenger Offline
mopar addict
mopar addict
K
Tampa Fl
Can you use it on a Black trailer
Remember in here some don't think you should have a Opinion.. sad fact..
Re: Trailer cleaning, Simply Awesome or Totally Awesome? [Re: kens avenger] #721698
06/12/10 12:40 AM
06/12/10 12:40 AM
Adrian, Mi
P
pro6pakRR Offline
mopar addict
pro6pakRR  Offline
mopar addict
P
Adrian, Mi
We used it on a black one and a red one.
Re: Trailer cleaning, Simply Awesome or Totally Awesom [Re: pro6pakRR] #721699
06/12/10 12:47 AM
06/12/10 12:47 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
And?
Re: Trailer cleaning, Simply Awesome or Totally Awesom [Re: rowin4] #721700
06/12/10 01:45 AM
06/12/10 01:45 AM
Thanks to all of you for the help
Re: Trailer cleaning, Simply Awesome or Totally Awesom [Re: rowin4] #721701
06/12/10 08:25 AM
06/12/10 08:25 AM
Temperance, Mi.
GaryHemi Offline
GaryHemi  Offline
Temperance, Mi.
And?
My white one. All of them came out looking like new.
71 Road Runner 440 Auto 11.40 1/4 mile best
71 Road Runner 440 4 Speed
71 GTX 440+6 Auto
70 Road Runner 426 Hemi 4 Speed
70 Challenger 440 Auto
69 Dart GTS 383 Auto
69 Dart 270
62 Dart Convt.
13 Dodge Journey R/T
13 Ram 4X4 Crew Cab "Laramie Longhorn"
Re: Trailer cleaning, Simply Awesome or Totally Awesom [Re: GaryHemi] #721702
06/13/10 10:20 PM
06/13/10 10:20 PM
Russiaville, IN
mopar376d Offline
mopar376d  Offline
Russiaville, IN
I just started using Fastball. Hands down the best stuff I ever used.
You have to spray it on and wipe it off. It will take stains out that I used to buff.
I just got done with one side of my 48 footer. Then waxed it. Not looking forward to the other side. Lot of work.
Why does divorce cost so much? Because it is worth it!!!!!
