Totally Awesome .... works great.... use it full strength
but dont let it dry on you before you get it wiped off,
you will see the procedure when you get started... I
would do areas in a 2' wide starting at the top and
work down then move over and back to the top... it
works fast so dont dilly dally .... also I never used
the stuff with bleach
