how many threaded plugs in a small block? #721632
06/11/10 05:34 PM
06/11/10 05:34 PM
florida
rxod Offline OP
rxod  Offline OP
florida
This may be a stupid question, but I just got my block back from the machine shop and all of the block's threaded plugs were removed and returned to me in a baggie. I can only find 4 plug holes and I got back 5 plugs. The ones in the sides of the block with hex head were not removed and are not being counted, only the allen head type. I have 3 on the back side, and one in the oil filter boss area. What am I missing?
Re: how many threaded plugs in a small block? [Re: rxod] #721633
06/11/10 10:23 PM
06/11/10 10:23 PM
That is not a stupid Q at all. Look inside the 2 threaded bosses on the rear bell face, the one on the drivers side is larger as you need to thread in a 3rd npt plug inside of this large boss to cap the dr side horizontle main oil gallery inside.
Re: how many threaded plugs in a small block? [Re: RapidRobert] #721634
06/11/10 11:05 PM
06/11/10 11:05 PM
Colorado
Leadfoot Offline
Leadfoot  Offline
Colorado
The one at the end of the lifter galleys is one you will only miss once.
When you find out the hard way you'll never do it again
Re: how many threaded plugs in a small block? [Re: rxod] #721635
06/11/10 11:06 PM
06/11/10 11:06 PM
Under My Car
Mopar_Country Offline
Under My Car
The only stupid question, is the question not asked.
Re: how many threaded plugs in a small block? [Re: Mopar_Country] #721636
06/12/10 07:30 AM
06/12/10 07:30 AM
scratchnfotraction Offline
check to make sure the little cup plug is in the oil passage below the oil sender also
thats a tricky one..machine shop might or might not have knocked it out
IIRC run a small wire down the oil sender unit and see if the cup is in there
if not IIRC it goes in from under the main bearing
Re: how many threaded plugs in a small block? [Re: scratchnfotraction] #721637
06/12/10 09:07 AM
06/12/10 09:07 AM
florida
rxod Offline OP
rxod  Offline OP
florida
Thanks, Of course the larger plug is the one I put in first, so I couldn't see the inner threads.
Could of been disasterous. You guys rock.
Re: how many threaded plugs in a small block? [Re: rxod] #721638
06/12/10 09:33 AM
06/12/10 09:33 AM
was the small cup plug that has to be tapped in like a core plug there???
I would deff check for it also
Re: how many threaded plugs in a small block? [Re: scratchnfotraction] #721639
06/12/10 01:11 PM
06/12/10 01:11 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Good point, without the plug the oil will bypass the oil filter.
Re: how many threaded plugs in a small block? [Re: 451Mopar] #721640
06/12/10 05:12 PM
06/12/10 05:12 PM
North East Missouri
E
express Offline
express  Offline
E
North East Missouri
What is this plug for? Don't recall seeing it before. What happens if it is left out?
cny25421@centurytel.net 70 Duster Turbo Charged 79 Lil Red Express Bonded Locksmith
Re: how many threaded plugs in a small block? [Re: express] #721641
06/12/10 05:31 PM
06/12/10 05:31 PM
the oil passage comes up vertical from the pump/rear cap then makes a 90 deg turn out horizontle to the filter/thru the filter then back in horizontle into the block & back to the same vertical passage and a 90 deg turn back into it & the oil continues further up vertical to the horizontle oil gallery. The vertical passage between the 2 horizontle passages is drilled so the oil would go strait up without going out to the filter and it needs a mini freeze plug driven in to a depth between these 2 passages. There's a cupped depression sort of there for it to seat at the right depth between the 2 horizontle passages. under the rear main cap are 4 holes, 2 for the main cap bolts, one for the intermediate shaft that drives the pump and one for the long vertical passage and that one is where you drive the mini plug in. EDIT to drive the old plug out so you can bristle brush clean all the galleries drive a rod into the oil psi sending unit hole above at the top rear of the block to drive the plug out the bottom aforementioned hole
Re: how many threaded plugs in a small block? [Re: express] #721642
06/12/10 05:42 PM
06/12/10 05:42 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Most shops never remove the plug, but it re-directs the oil flow to the oil filter. I hope this picture helps?
Re: how many threaded plugs in a small block? [Re: 451Mopar] #721643
06/13/10 11:51 AM
06/13/10 11:51 AM
North East Missouri
E
express Offline
express  Offline
E
North East Missouri
That worries me. I don't remember seeing that plug in my 340 block. I cleaned it out with oil galley brushes when I assembled it. I took all of the plugs out but don't remember a drive in plug at all. It runs fine but oil pressure is low at idle about 20 psi.
Doug
