Re: how many threaded plugs in a small block?
[Re: rxod]
#721633
06/11/10 10:23 PM
06/11/10 10:23 PM
RapidRobert
That is not a stupid Q at all. Look inside the 2 threaded bosses on the rear bell face, the one on the drivers side is larger as you need to thread in a 3rd npt plug inside of this large boss to cap the dr side horizontle main oil gallery inside.
[Re: Mopar_Country]
#721636
06/12/10 07:30 AM
06/12/10 07:30 AM
Posts: 15,487 Florida
scratchnfotraction
check to make sure the little cup plug is in the oil passage below the oil sender also thats a tricky one..machine shop might or might not have knocked it out IIRC run a small wire down the oil sender unit and see if the cup is in there if not IIRC it goes in from under the main bearing
[Re: 451Mopar]
#721640
06/12/10 05:12 PM
06/12/10 05:12 PM
Posts: 314 North East Missouri
express
North East Missouri
was the small cup plug that has to be tapped in like a core plug there???
I would deff check for it also
Good point, without the plug the oil will bypass the oil filter.
What is this plug for? Don't recall seeing it before. What happens if it is left out?
[Re: express]
#721641
06/12/10 05:31 PM
06/12/10 05:31 PM
RapidRobert
the oil passage comes up vertical from the pump/rear cap then makes a 90 deg turn out horizontle to the filter/thru the filter then back in horizontle into the block & back to the same vertical passage and a 90 deg turn back into it & the oil continues further up vertical to the horizontle oil gallery. The vertical passage between the 2 horizontle passages is drilled so the oil would go strait up without going out to the filter and it needs a mini freeze plug driven in to a depth between these 2 passages. There's a cupped depression sort of there for it to seat at the right depth between the 2 horizontle passages. under the rear main cap are 4 holes, 2 for the main cap bolts, one for the intermediate shaft that drives the pump and one for the long vertical passage and that one is where you drive the mini plug in. EDIT to drive the old plug out so you can bristle brush clean all the galleries drive a rod into the oil psi sending unit hole above at the top rear of the block to drive the plug out the bottom aforementioned hole
