Correct Finish for Heat Riser Valve
#72132
06/12/08 04:29 PM
06/12/08 04:29 PM
Posts: 907 Mississauga, Canada
KARLN
Mississauga, Canada
What's the correct finish on the HP manifold heat riser valve counter weight for 1970?
B5 Challenger T/A
Re: Correct Finish for Heat Riser Valve
[Re: JohnRR]
#72134
06/12/08 05:10 PM
06/12/08 05:10 PM
KARLN
Mississauga, Canada
okay thanks. Should I spray it with some high heat clear to keep from looking like crap in a few months?
B5 Challenger T/A
[Re: gtx6970]
#72136
06/12/08 08:34 PM
06/12/08 08:34 PM
engine color
I believe the manifolds were painted engine color, then it burnt off, leaving the counterweight, spring and stop painted (spring ans stop look oversprayed).
#72137
06/12/08 08:49 PM
06/12/08 08:49 PM
Posts: 29,657 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
[Re: Alaskan_TA]
#72142
06/13/08 10:23 AM
06/13/08 10:23 AM
Barry, I have a 70 big block one that looks identical, but blue. The backside (spring and stop)looks as though not much effort was put into getting the paint in there, just overspray. I will get pix of the one on the low mile AAR when I get a chance.
