Correct Finish for Heat Riser Valve #72132
06/12/08 04:29 PM
06/12/08 04:29 PM
Mississauga, Canada
KARLN Offline OP
KARLN  Offline OP
Mississauga, Canada
What's the correct finish on the HP manifold heat riser valve counter weight for 1970?
B5 Challenger T/A
Re: Correct Finish for Heat Riser Valve [Re: KARLN] #72133
06/12/08 05:02 PM
06/12/08 05:02 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
bare
Re: Correct Finish for Heat Riser Valve [Re: JohnRR] #72134
06/12/08 05:10 PM
06/12/08 05:10 PM
Mississauga, Canada
KARLN Offline OP
KARLN  Offline OP
Mississauga, Canada
okay thanks. Should I spray it with some high heat clear to keep from looking like crap in a few months?
B5 Challenger T/A
Re: Correct Finish for Heat Riser Valve [Re: KARLN] #72135
06/12/08 05:46 PM
06/12/08 05:46 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
engine color
Re: Correct Finish for Heat Riser Valve [Re: gtx6970] #72136
06/12/08 08:34 PM
06/12/08 08:34 PM
engine color
I believe the manifolds were painted engine color, then it burnt off, leaving the counterweight, spring and stop painted (spring ans stop look oversprayed).
Re: Correct Finish for Heat Riser Valve #72137
06/12/08 08:49 PM
06/12/08 08:49 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: Correct Finish for Heat Riser Valve [Re: Alaskan_TA] #72138
06/12/08 09:38 PM
06/12/08 09:38 PM
MD
floyd Offline
floyd  Offline
MD
Hey Barry - Is that manifold off your T/A? The counter weight looks like the "later style" - see this post: https://board.moparts.org/ubbthreads/show...e=0#Post4477721
Re: Correct Finish for Heat Riser Valve [Re: floyd] #72139
06/12/08 09:43 PM
06/12/08 09:43 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Nope.
Mine had headers on it when I got it.
The photo is from the low mile T/A.
Re: Correct Finish for Heat Riser Valve [Re: Alaskan_TA] #72140
06/12/08 10:01 PM
06/12/08 10:01 PM
MD
floyd Offline
floyd  Offline
MD
cool - That's good enough for me. I need to find that photo CD I got from you!
Re: Correct Finish for Heat Riser Valve [Re: floyd] #72141
06/12/08 10:52 PM
06/12/08 10:52 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
That photo is on the DVD.
Re: Correct Finish for Heat Riser Valve [Re: Alaskan_TA] #72142
06/13/08 10:23 AM
06/13/08 10:23 AM
Barry, I have a 70 big block one that looks identical, but blue. The backside (spring and stop)looks as though not much effort was put into getting the paint in there, just overspray.
I will get pix of the one on the low mile AAR when I get a chance.
