anyone have a picture of monaco brakes on a "A" body??? #720795
06/10/10 06:48 PM
06/10/10 06:48 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline OP
we are finishing up putting 11.75 brakes on Jon's duster and the brake hose (where it bolts to the caliper)hits when we turn right(dr side), we have moved the hose to different spots and it still doesn't work, the caliper is mounted towards the front of the car as per the instructions on the BB dart site
"3. Replace Front Spindles with donor set, being careful not to mix up the left and right sides
(calipers to the front, steering arm/balljoint to the rear)"
so I would like to see a picture if any one has one to see how this should look.
also how does the spring clip go for the pin type caliper and pads Thanks in advance. Ron...
Re: anyone have a picture of monaco brakes on a "A" body??? [Re: Mopar Ron] #720796
06/10/10 08:04 PM
06/10/10 08:04 PM
here's a picture of the spring, how does it go ???
Re: anyone have a picture of monaco brakes on a "A" body??? [Re: Mopar Ron] #720797
06/10/10 11:12 PM
06/10/10 11:12 PM
AndyF Offline
AndyF  Offline
The calipers might not fit to the front, it depends on which calipers you are using and what vehicle you are putting them on.
Re: anyone have a picture of monaco brakes on a "A" body??? [Re: AndyF] #720798
06/11/10 12:39 AM
06/11/10 12:39 AM
Thanks Andy, could we just swap spindles and mount the calipers to the rear?
also we don't have the tie rods hooked up yet(so the spindles may be going to far) and I moved the braided hoses as close as I could to the spindle and it now clears(by about 1/8"). "but" the caliper just touches the LCA just below the shock, it might not go that far when the tire is on the ground.
its on a 71 duster, don't know what calipers they are, just that they are pin style and the hose comes in from the bottom. Ron...
Re: anyone have a picture of monaco brakes on a "A" body??? [Re: Mopar Ron] #720799
06/11/10 12:44 AM
06/11/10 12:44 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Put the calipers to the rear. Also it doesn't matter if the tires are on, the stops are the lower spindle bolts and the lower control arm , tires will only come into play if they are too big and hit the frame before you hit the steering stops , like my 69 dart does with F70-14's .
Re: anyone have a picture of monaco brakes on a "A" body??? [Re: Mopar Ron] #720800
06/11/10 01:51 AM
06/11/10 01:51 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
With 67-72 Style Kmember and sway bar
Close up of caliper hose: http://www.cpwclub.com/steve/auto/dart/oilpan/dscn0009.jpg
With 73-76 style K-member and sway bar...
Re: anyone have a picture of monaco brakes on a "A" body??? [Re: autoxcuda] #720801
06/11/10 02:04 AM
06/11/10 02:04 AM
Thanks for the pics Steve, it looks like putting the calipers on the back side would give us more room. are your calipers slider or pin style? Ron...
Re: anyone have a picture of monaco brakes on a "A" body??? [Re: Mopar Ron] #720802
06/11/10 02:13 AM
06/11/10 02:13 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The back gives you more room. You can shorten sway bar links to get them to work in the front.
Pin style. Like the style with the anti rattle clips you have. You don't need to put those in.
Re: anyone have a picture of monaco brakes on a "A" body??? [Re: Mopar Ron] #720803
06/11/10 02:19 AM
06/11/10 02:19 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The spring clips around the caliper and hooks to the two pins. The FSM should have a picture.
