727 question #720097
06/09/10 09:33 PM
06/09/10 09:33 PM
Peru
cbarracuda Offline OP
Peru
I build my own 727 about a year ago. Everything works well but my car is hard to push back. Not to long ago I build one for a friend and that car does not have that problem. Any one knows what causes that?
thank you
Re: 727 question [Re: cbarracuda] #720098
06/09/10 09:44 PM
06/09/10 09:44 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
What makes you suspect the trans?
Re: 727 question [Re: WILD BILL] #720099
06/09/10 09:48 PM
06/09/10 09:48 PM
Peru
Peru
I checked with the tires on the air and disconected the drive shaft. Also when I move the drive shaft, one way is easy ans the other is hard.
Re: 727 question [Re: WILD BILL] #720100
06/09/10 09:49 PM
06/09/10 09:49 PM
Richmond , Virginia
BEEQUIK Offline
BEEQUIK  Offline
Richmond , Virginia
Spool in the rearend??
Re: 727 question [Re: BEEQUIK] #720101
06/09/10 10:58 PM
06/09/10 10:58 PM
Walhalla, SC
BlueDart Offline
BlueDart  Offline
Walhalla, SC
one way clutch (sprag) is holding this is normal
Re: 727 question [Re: BlueDart] #720102
06/10/10 08:57 AM
06/10/10 08:57 AM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
The hard to turn one is normal.
Randy Brough 1967 440 Dart S/P 6.37 106mph best eighth 3150 lbs
Re: 727 question [Re: cbarracuda] #720103
06/10/10 11:05 AM
06/10/10 11:05 AM
thank you
It is normal for a 727(and probally a 904) for the driveshaft to turn harder in reverse than foward, I think it's that way. My trans. with a low Mopar brand low(2.77) gear set is harder to turn backwards than my standard low(2.45) gear trans is It is also harder to push the car backwards with the low gear trans. in it
Re: 727 question [Re: cbarracuda] #720104
06/10/10 01:57 PM
06/10/10 01:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
When turning the tailshaft backwards the planetaries are in an overdrive condition which makes the friction of the released clutches/band more pronounced.
Perfectly normal.
Re: 727 question [Re: cbarracuda] #720105
06/10/10 02:09 PM
06/10/10 02:09 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
thank you
You might want to check your friends trans because his should be like yours
Re: 727 question [Re: JohnRR] #720106
06/10/10 08:14 PM
06/10/10 08:14 PM
Peru
Peru
thank you for your answers. All the 727 that I had before feel the same way as my car does, but the one I built for my friend does not feel that way. The car is easy to push back and it raced last week and went 9.70 so I figured that if I could find the problem and fix it, then I could gain a couple tenths on mine. so thank you for the info, I know better know
