lowering 66 abody front #72009
06/12/08 10:14 AM
06/12/08 10:14 AM
switzerland
denizch Offline OP
denizch  Offline OP
switzerland
well the possibilitiys to drop a mopar are not huge without major fabrication ,I wonder if any ones has a adress who sell dropped spindles for a 66 a body . If not i wonder how the intress would be about notched custom lower steering arms ?
a hi from switzerland
Re: lowering 66 abody front [Re: denizch] #72010
06/12/08 12:47 PM
06/12/08 12:47 PM
Well you can just turn down the T bars and lower the car. But if thats to easy you can get dropped spindals I believe for some mopars( help me here guys I've seen dropped spindals but not sure what they make them for B or F body I think) then its just getting the right ball joint combination and possible changing the upper control arm to the larger ball joint arm.
Re: lowering 66 abody front #72011
06/12/08 03:33 PM
06/12/08 03:33 PM
switzerland
denizch Offline OP
denizch  Offline OP
switzerland
okay anyone has a adress of the spindles ,because i like to have my car real low ,at the moment the car stands in my garage without the torsionbars mounted and it s still to high for me.
Re: lowering 66 abody front [Re: denizch] #72012
06/12/08 03:44 PM
06/12/08 03:44 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I think Fatman Fabrication has Mopar drop spindles.
Re: lowering 66 abody front [Re: denizch] #72013
06/12/08 04:28 PM
06/12/08 04:28 PM
NH
72challorange Offline
He's Game
He's Game
NH
Have any pics of how it sits?
I got my E-body t-bars turned down to give me 24 inches to the ground from the fender arch with 245/45/17's. Doesn't bottom out but I don't know how much lower you'd want to go and still drive it.
They make airbag suspensions but not sure if your a body is covered.
Tom
Re: lowering 66 abody front [Re: 72challorange] #72014
06/13/08 07:13 AM
06/13/08 07:13 AM
switzerland
denizch Offline OP
denizch  Offline OP
switzerland
i had one a valiant and it was realy low with only the t bars turned down , i will post a pic tomorow
