Big block A body valve covers #719940
06/09/10 05:10 PM
06/09/10 05:10 PM
Pennsylvania
craigerlitz Offline OP
Pennsylvania
Are there any painted versions of the chrome valve covers used on the Darts and Barracudas? I have seen a couple that look close to the chrome.
Thanks,
Craig
Re: Big block A body valve covers [Re: craigerlitz] #719941
06/09/10 06:39 PM
06/09/10 06:39 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
there is but IIRC they aren,t exactly the same look on ebay there,s lots of vaiety there dan
Re: Big block A body valve covers [Re: ph23vo] #719942
06/09/10 07:14 PM
06/09/10 07:14 PM
Pennsylvania
Pennsylvania
That's one reason I asked. There is a set there that is currently $50. They look very close to the chrome ones, except the bottom one is missing a tab.
Re: Big block A body valve covers [Re: craigerlitz] #719943
06/09/10 07:18 PM
06/09/10 07:18 PM
Pennsylvania
Pennsylvania
Here is a set of the chrome ones.
Re: Big block A body valve covers [Re: craigerlitz] #719944
06/09/10 11:44 PM
06/09/10 11:44 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have three sets of originals and there are two spark plug wire tabs on each cover. One has them on the side and the other has one on top and one on the side. I have two sets of 69's and one set of 68's.
JB Rhinehart, Realist
A-Body's RULE!
Re: Big block A body valve covers [Re: Rhinodart] #719945
06/10/10 12:03 PM
06/10/10 12:03 PM
Pennsylvania
Pennsylvania
What are the differences between the 68's and 69's?
Thanks,
Craig
Re: Big block A body valve covers [Re: craigerlitz] #719946
06/10/10 01:51 PM
06/10/10 01:51 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Thanks,
Craig
Both sets pictured in this thread are 68's , the chrome ones are actual 68 A body pieces , i'm 99.99% sure on that . The unpainted ones are 68 B body covers , C body and A body would have 2 more clips on the left cover for the #7 plug wire like the chrome one pictured .
There is an A body unpainted cover , it's 69 A body only used on the 440. I haven't seen an original cover up close to see if it's actually different than the run of the mill C body covers , but given the nature of the 440 A body and it's very limited production I'm guessing it's not.
Re: Big block A body valve covers [Re: craigerlitz] #719947
06/10/10 01:52 PM
06/10/10 01:52 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I would avoid these like the plague , the donkey that sandblasted them also sandblasted down the breather hole .
Re: Big block A body valve covers [Re: JohnRR] #719948
06/10/10 06:10 PM
06/10/10 06:10 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
So what John? Every valve cover I put on a motor I slit the baffle with my plasma cutter and clean all the junk out. When I'm done I fold the baffle back together and tack weld it together again. This stuff is 40 years old it's filthy up there you gotta clean em out
