NEW DRAG SLICK BREAK-IN???!!! #719596
06/08/10 11:25 PM
06/08/10 11:25 PM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Just got my "brand new" GoodYear bias-ply slicks today. 1st NEW set I've ever owned! I was wondering what would be the proper technique to break them in? They're a D-3 compound! Thanks for your help guys! RandyB.
Re: NEW DRAG SLICK BREAK-IN???!!! [Re: Labratt] #719597
06/08/10 11:50 PM
06/08/10 11:50 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Smoke 'em if you've got 'em.
Old Geezer Racing
Re: NEW DRAG SLICK BREAK-IN???!!! [Re: SCATPACK 1] #719598
06/09/10 01:18 AM
06/09/10 01:18 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I always'ld just removed the stickers and lite em up
Re: NEW DRAG SLICK BREAK-IN???!!! [Re: WILD BILL] #719599
06/09/10 04:34 AM
06/09/10 04:34 AM
Mansfield,Ohio
Brandon70cuda Offline
Mansfield,Ohio
Always heard to make the first burnout alittle longer then normal. So give'em a John Force style burnout the first time.
Re: NEW DRAG SLICK BREAK-IN???!!! [Re: Brandon70cuda] #719600
06/09/10 06:39 AM
06/09/10 06:39 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
yeap thats right. about 5 minutes worth should do it.
Re: NEW DRAG SLICK BREAK-IN???!!! [Re: rebel] #719601
06/09/10 07:54 AM
06/09/10 07:54 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
They are peel and play as far as I know.
Re: NEW DRAG SLICK BREAK-IN???!!! [Re: Brandon70cuda] #719602
06/09/10 11:56 AM
06/09/10 11:56 AM
MR_P_BODY Offline
MR_P_BODY  Offline
just do one of your normal Randy burnouts,
it brings the resin to the surface (on the first burnout)
then just smoke them to clean and bring the temp up
Re: NEW DRAG SLICK BREAK-IN???!!! [Re: MR_P_BODY] #719603
06/09/10 12:07 PM
06/09/10 12:07 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
After 5 runs, swap them side for side, keep track of tire pressure and number of runs before switching sides again, usually 8 - 10 passes after the first switch.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: NEW DRAG SLICK BREAK-IN???!!! [Re: MR_P_BODY] #719604
06/09/10 12:08 PM
06/09/10 12:08 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Rich H.
Esse Quam Videri
Re: NEW DRAG SLICK BREAK-IN???!!! [Re: Brandon70cuda] #719605
06/09/10 12:14 PM
06/09/10 12:14 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Thats what Hoosier told me.------In a related question; Can you ruin an older set if you do too big of a burnout?
Yeah, it's got a smallblock.
Re: NEW DRAG SLICK BREAK-IN???!!! [Re: ZIPPY] #719606
06/09/10 12:15 PM
06/09/10 12:15 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Hey Randy
Did you notice if those Good Years were directional? The last few sets I have purchased didnt have a sticker on them to stagger the tires for installation etc.?
Re: NEW DRAG SLICK BREAK-IN???!!! [Re: Bob_Coomer] #719607
06/09/10 01:26 PM
06/09/10 01:26 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Bob...I hope they're not directional! I better go take a good look to make sure!
Re: NEW DRAG SLICK BREAK-IN???!!! [Re: Slingshot383] #719608
06/09/10 03:25 PM
06/09/10 03:25 PM
Rowlett, TX
74DusterP457 Offline
mopar addict
mopar addict
Rowlett, TX
I agree with this Slingshot383
BUT BEFORE YOU DO ANYTHING OTHER THAN MOUNT THEM - PUT TYPICAL AIR PRESSURE IN AND MEASURE CIRCUMFERENCE.
Not yelling - just making an important point.
If the two slicks are not within 1/2" of each other at inflated diameter, take them back. Leave the stickers on while you do this.
I have seen slicks be as much as an inch different "out of the box".
Don't forget to have them balanced.
Use screws as required on inside and out. Make sure screws are opposite each other inside and out, not staggered. Don't over-tighten screws.
Re: NEW DRAG SLICK BREAK-IN???!!! [Re: 74DusterP457] #719609
06/09/10 05:54 PM
06/09/10 05:54 PM
Sherman Texas
The Shocker Offline
The Shocker  Offline
Sherman Texas
Total crock .Kinda like the myth that if they get too cold they wont hook as well anymore.Im 60 footing almost a tenth faster than last year with mine(low 1.6 last year and low 1.5's now on 8 inch wide M/T's).They spent the winter in the elements in my driveway and a few days it dropped into the single digits and had ice and snow on them lots.They are rubber tires for gosh sakes not wives.Next people will be saying that you should give them a hug and a kiss before you mount them .Just mount them and go racing ...
http://www.youtube.com/watch?v=ykcsXMV3vfg My Dart ,and im just getting started...
Re: NEW DRAG SLICK BREAK-IN???!!! [Re: 74DusterP457] #719610
06/09/10 07:19 PM
06/09/10 07:19 PM
NC
440Jim Offline
440Jim  Offline
NC
In addition, and only when slicks are new with no use:
After mounting and setting running pressure, if one has a slightly larger circumference than the other, inflate to 20-30 psi then deflate and reset pressure. Measure again. This can stretch a new tire a little to better match the circumference. If it doesn't change, leave inflated (20-30 psi) for an hour, perhaps in the sun and retest.
Re: NEW DRAG SLICK BREAK-IN???!!! [Re: 440Jim] #719611
06/09/10 10:46 PM
06/09/10 10:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
..... then only one Randy burnout then back
to just heating and cleaning.... about 20* to 25*
above the track surface temp, no dry hops
Re: NEW DRAG SLICK BREAK-IN???!!! [Re: Labratt] #719612
06/10/10 08:22 AM
06/10/10 08:22 AM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
Unless goodyear slicks have changed in the last couple years they are directional.The slicks serial numbers both point to the right side when installed. For me rotating the goodyears was a no no as my sixty,s would fall off once rotated and never come back even if put back to their original sides. I ran them for over fifteen years but i have ran the other brands to,for me they all worked pretty good. Good luck
Randy Brough 1967 440 Dart S/P 6.37 106mph best eighth 3150 lbs
Re: NEW DRAG SLICK BREAK-IN???!!! [Re: moparmxz] #719613
06/10/10 08:26 AM
06/10/10 08:26 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Randy,THANK YOU very much for that info! I had no clue! I'll be sure to check out where the serial #'s are located,and install accordingly! RandyB
Re: NEW DRAG SLICK BREAK-IN???!!! [Re: moparmxz] #719614
06/10/10 08:34 AM
06/10/10 08:34 AM
Lehigh Acres, Florida
rickstershemi Offline
Yes Goodyear recommends this mounting procedure......once mine are mounted up correctly I John Force the initial burnout then just haze the from then on.....rotated approx every 10 runs with zero loss in performance (1.13 60')
Rickster
Re: NEW DRAG SLICK BREAK-IN???!!! [Re: rickstershemi] #719615
06/10/10 08:40 AM
06/10/10 08:40 AM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
I also know some guys who rotate with good results also,but it never seemed to work out for me.I always ran the 1984,s(stiff sidewall 14x32).
