Re: Reproduction choke available for Holley on 383/440?
[Re: 1972Rallye]
#719165
06/10/10 03:27 PM
06/10/10 03:27 PM
Posts: 1,652 Calgary, Alberta Canada
m46rat
I can't find one anywhere (except NOS on e-bay) that's affordable... For '71 and '72 in my case -both take the same one. I know some '69 and '70 models had them too.
Could you tell us exactly what your application is? There are a lot of different Holley four bbl chokes for 70-72 cars. Please post specifics.
The '71 is a 383 Magnum, Auto, No A/C, No N96 - Holley carb number 4668
The '72 is a 440 Magnum, 4 Speed, No A/C. N96 - Holley carb number 6254
The parts books I have both call out 3512867
An NOS one on eBay is about 70.00. Do you consider that to be "affordable"? BTW, the choke for a 70 383+4 Holley is NOT the same as for a 71. The chokes are different, although they all have the word Holley stamped into them.
[Re: NANKET]
#719166
06/11/10 12:57 AM
06/11/10 12:57 AM
Posts: 75,047 U.S.S.A.
JohnRR
U.S.S.A.
If you were around Seattle area shows in the early 2000's then it would be painfully obvious that he did own a 1970 Road Runner 383 AT car. We were all so glad when he flipped it. It was advertised here on moparts.
I do remember the 70 he flipped , it was a stripped down coupe , bronze me thinks ?
[Re: JohnRR]
#719167
06/11/10 05:35 PM
06/11/10 05:35 PM
Posts: 434 sweden
cuda-sweden
sweden
[Re: ph23vo]
#719171
06/12/10 01:36 PM
06/12/10 01:36 PM
JohnRR
U.S.S.A.
my car was a very early 70 RR and had been swapped [possibly] to an AVS so i just used what it had.. it ran great and looked good... yes it should have had a holley factory according to the sheet, i bought it from the orig owner too.. and if owning a car for 10+ yrs is flipping it.... i guess i,m a flipper! i have never seen one of those big thermostats on a car so i guess some had em... always been 2 BBLs i,ve seen with em.. i know my 69 has the flat one.. RM23NOE129303 EV2 TX9 dan
dan , that is 1970/UP choke thermo. it's used on ALL 1970 Big block 4bbls , no matter what carb it had, there is obviously one specific to holley or carter as far as the rod that connects to the carb goes but they are all of the domed design because the 1970 manifold is different than 68/69 . If your 70 had a flat one then it also had the wrong intake, but it don't matter because you flipped it.
[Re: 1972Rallye]
#719173
06/13/10 08:09 PM
06/13/10 08:09 PM
Posts: 3,580 OH
junkyardmaxie
OH
i have 2 of these suppose to be for holley carb 68-69 it has holley on it with the #56 on it]big block -440 if its something you need or can use email me moparraceman@aol.com $25.00 plus shipping each thanks
